TuffShell
Old April 10th 07, 02:04 AM posted to rec.aviation.homebuilt
bizguy
Default TuffShell
Has anyone experience with this stuff that they can share?
http://www.safestructure.com/industr..._m25/index.htm
Thank you,
Harold Hoffmann
Old April 10th 07, 03:33 PM posted to rec.aviation.homebuilt
Lou
Default TuffShell
I have to be honest, I thought this was the stuff you put on ice
cream.
Lou
Old April 10th 07, 04:50 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Default TuffShell
"bizguy" wrote in message
If you are suggesting it's use on an airplane, (which it seems certain you
are) the first thing I would want to know are about it's burn qualities.
Ignition temp, self extinguishing characteristics, byproducts produced from
combustion.
My bet is that at least 2 out of 3 have completely unacceptable
characteristics.
Anyone else wanna bet?
Old April 12th 07, 12:09 AM posted to rec.aviation.homebuilt
bizguy
Default TuffShell
combustion.
characteristics.
Hi Jim,
I am certain you are right - it is combustible. I want to build a
"common material" glider on the
order of the old MI glider or Harlan glider. No engine, gas or
smoking allowed.
I want to know if anyone has used the stuff or something similar.
Workability, durability etc.
I am thinking of a foam D cell leading edge with a covering or
coating, then possibly for the flat
sections of the wing using coroplast. Simple wood spar, if biplane,
then a wood frame.
At this point just a mental experiment.
Harold Hoffmann
