Press-To-Test Lamp
Old April 14th 07, 03:39 AM posted to rec.aviation.homebuilt
Ron Gordon
Default Press-To-Test Lamp
My Press-To-Test indicator light for my landing gear has three lugs on the
back for three separate wires. Can anyone explain the appropriate hookup for
these three lugs so that I'm sure to hookup the correct wire to each of the
lugs?
Thanks!
Old April 14th 07, 01:42 PM posted to rec.aviation.homebuilt
Ron Natalie
lugs?
One goes to the + bus, one goes to ground, one goes to whatever switch
illuminates the light.
The Press to Test feature needs power to light the light.
Old April 15th 07, 03:58 AM posted to rec.aviation.homebuilt
Dale Scroggins
"Ron Gordon" wrote in message
for these three lugs so that I'm sure to hookup the correct wire to each
of the lugs?
Thanks!
If the lamp assembly you are using is an MS25041 type, the solder lugs are
numbered. If you have a metal airplane, or intend to use negative ground
busses at various locations in the airframe, then wire the lamp assembly as
follows:
Lug 1: +
Lug 2: to switch(es). If you are only using one gear-down indicator, wire
the switches in series, with the last switch having one lug connected to
ground. If you have two or three gear down indicators, connect lug 2 of
each to a SPST NO switch, and the other switch lug to ground.
Lug 3: to ground.
The lug numbers are normally stamped on the lugs, or nearby. If you cannot
read them, looking from the back, with the center lug (#1) on bottom, #2 is
on the left and #3 is on the right.
Hope this helps.
Old April 15th 07, 04:37 PM posted to rec.aviation.homebuilt
Ron Gordon
Very helpful! Thanks to both of you. -Ron
"Dale Scroggins" wrote in message
news
the back for three separate wires. Can anyone explain the appropriate
hookup for these three lugs so that I'm sure to hookup the correct wire
to each of the lugs?
Thanks!
as
follows:
Lug 1: +
wire
Lug 3: to ground.
cannot
is
Hope this helps.
Cost of Sandel 3308 projection lamp? Dico Owning 1 May 8th 06 11:22 PM
A different lamp base Blanche Cohen General Aviation 15 December 9th 05 04:32 PM
A different lamp base Blanche Cohen Piloting 15 December 9th 05 04:32 PM
A different lamp base Blanche Cohen Owning 15 December 9th 05 04:32 PM
Robot Plane Drops Bomb in Successful Test The Associated Press Otis Willie Military Aviation 0 April 19th 04 09:50 PM
