ELT Antenna for Discus 2
Old April 18th 07, 04:49 PM posted to rec.aviation.soaring
Default ELT Antenna for Discus 2
I'm in the process of researching ELT's for my Discus 2. Problem is
with all that carbon fiber, I don't know were to install the antenna.
Any suggestions?
Zulu
P.S. Wags with alternate suggestions as to where to stick the
antenna, please remember this is a family site.
Old April 18th 07, 05:35 PM posted to rec.aviation.soaring
Tuno
I hope you solve this Zulu. I have an ELT sitting on the shelf because
I can't figure out where to put the antenna in my V2C.
2NO
Old April 18th 07, 05:44 PM posted to rec.aviation.soaring
Mike the Strike
Any suggestions?
Zulu
The previous owner of my Discus 2 installed a rubber duckie antenna
adjacent to the right rear canopy. While perhaps not a perfect
solution, it does appear to work.
Old April 18th 07, 06:36 PM posted to rec.aviation.soaring
Any suggestions?
Zulu
Jim Phoenix show installation on Nimbus III on his site. www.jimphoenix.com
UH
Old April 18th 07, 09:22 PM posted to rec.aviation.soaring
On Apr 18, 10:49�am, wrote:
I'm in the process of researching ELT's for my Discus 2. *Problem is
Any suggestions?
Zulu
P.S. *Wags with alternate suggestions as to where to stick the
On the D2b, left side on the 'seat back" bulkhead. It curves a little
to the contour of the turtle deck. The wire then passes thru the
bulkhead to the unit. I've seen this placement on several types of
gliders. R
Old April 18th 07, 11:34 PM posted to rec.aviation.soaring
Peter Scarpelli
I did a bit of testing with a meter that measured output of a rubber duckie
in my D2 using a variety of sites. Bottom line is that the antenna should
be ideally placed vetically in open site to the sky. Any place shielded by
the carbon fibre is useless. Two sites seemed ok. One is to mount it
along the canopy rail and the other is under the glare shield. Mine is
under the shield and mounted on a bracket and slightly tilted (about 45
degrees). Try to keep it away from any metal.
Any suggestions?
Zulu
Discus verus Discus 2, LS8, ASW 28 Roger Soaring 45 October 31st 06 04:43 PM
Discus 3 or Super Discus? Mirek Soaring 1 June 13th 04 10:28 AM
Discus 2C (18m) John Galloway Soaring 0 March 28th 04 11:56 PM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 02:15 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 09:42 AM
