Knowing when you are overflying something
Old April 18th 07, 06:40 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Knowing when you are overflying something
How do you know when you are exactly overflying a specific spot on the ground?
It's it just a matter of knowing your particular aircraft, or are there tricks
that can help to determine this? I know you can look off the tip of your wing
to see if you're abeam something (such as a runway), but how can you tell when
you're right over something? I presume there's no way to look straight down
from most aircraft, and it seems like the view over the nose is often several
miles away.
Old April 18th 07, 07:06 PM posted to rec.aviation.piloting,rec.aviation.student
Erik
miles away.
Crossing mid-field, you guess. If you tell everyone that you're going
to cross mid-field at 2000' and you're off a bit, they don't shoot you
down. You're just telling everybody where (in general) you are so that
they know where to look.
If I really need to know if I'm directly over something, I take into
account the wind and my velocity and start dropping golf balls and watch
where they land. Of course, by the time they hit the ground, I've
probably moved a couple hundred feet or so which then requires more golf
balls. It's a never-ending battle.
If you are trying to find yourself, use the VORs and triangulate
yourself on the sectional. This won't tell you exactly where you are,
but it'll tell you pretty close to where you were when you took the angles.
Old April 18th 07, 07:07 PM posted to rec.aviation.piloting
Ardup
Mxsmanic wrote in
ground?
You look kdown and there is is, moron.
Old April 18th 07, 07:09 PM posted to rec.aviation.piloting,rec.aviation.student
Orval Fairbairn
miles away.
You roll inverted and look straight "up". ;)
Old April 18th 07, 07:12 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Stewart
miles away.
LOL. I nominate this as the "best reply to Anthony"
for the week.
Old April 18th 07, 07:31 PM posted to rec.aviation.piloting,rec.aviation.student
Gig 601XL Builder
the ground? It's it just a matter of knowing your particular
aircraft, or are there tricks that can help to determine this? I
know you can look off the tip of your wing to see if you're abeam
something (such as a runway), but how can you tell when you're right
over something? I presume there's no way to look straight down from
several miles away.
I know you aren't going to like this answer Anthony but it just isn't that
critical that you pass over a specific point. Close enough is good enough.
So how do you get close enough you ask. Let's say you are flying from A to C
you want to pass over B. As you are approaching B you notice that D is
pretty much perpendicular to your course in line with B. So you head towards
B and keep D the same distance away.
Now there are special situations like aerial mapping or non-guided munitions
that will require better positioning but in those cases you would have
specialized equipment.
Old April 18th 07, 07:36 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Mxsmanic" wrote in message
ground?
tricks
wing
when
down
several
miles away.
Why would a pilot care?
Old April 18th 07, 07:41 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Jim Stewart wrote in
often several miles away.
for the week.
Do you think he's standging on his head with his little rudder pedals
balanced on his feet?
Old April 18th 07, 08:01 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Erik writes:
Seriously?
Old April 18th 07, 08:02 PM posted to rec.aviation.piloting,rec.aviation.student
Erik
ground?
tricks
wing
when
down
several
miles away.
You don't want to pelt noncombatants with errant golf balls!
overflying Canada along east coast of Lake Huron akiley Piloting 3 March 11th 07 08:25 PM
overflying Canada along east coast of Lake Huron akiley Piloting 0 March 11th 07 03:17 AM
[ATTN] Jim Weir or anyone knowing about old gyro compasses B.B. Home Built 1 November 22nd 04 05:49 PM
