I ran across this notice on the EAA website today regarding proposed
legislation in the state of Hawaii to exclude premium mogas from the 10% ethanol requirement. Please take a few minutes to read the Bill itself. This may be very useful if you live in an area where only E10 is sold, and there is no way to modify your engines or fuel systems to run ethanol. I don't personally have an aircraft that is affected by E10, and I'm planning to upgrade the fuel system on my boat, lawn mower, etc. But for those aircraft, boats, and chainsaws that can't be modified or STC'd for ethanol, this does sound like a working comprimise. It may pass in state legislatures without too much grief from the radical environmentalists or farmers. http://www.eaa.org/communications/ea...4_ethanol.html Harry "Teddy Roosevelt was a tree-huggung conservative" Frey |
wright1902glider wrote:
I ran across this notice on the EAA website today regarding proposed legislation in the state of Hawaii to exclude premium mogas from the 10% ethanol requirement. Please take a few minutes to read the Bill itself. This may be very useful if you live in an area where only E10 is sold, and there is no way to modify your engines or fuel systems to run ethanol. I don't personally have an aircraft that is affected by E10, and I'm planning to upgrade the fuel system on my boat, lawn mower, etc. But for those aircraft, boats, and chainsaws that can't be modified or STC'd for ethanol, this does sound like a working comprimise. It may pass in state legislatures without too much grief from the radical environmentalists or farmers. http://www.eaa.org/communications/ea...4_ethanol.html Harry "Teddy Roosevelt was a tree-huggung conservative" Frey What's required for an a/c to run on part ethanol? John |
"J.Kahn" wrote in message
... ... What's required for an a/c to run on part ethanol? John Seals, gaskets, O-rings, and and any hoses in the existing system may or may not hold up against ethanol - likely at least some will not. Corrosion of the fuel tank may also be an issue. If you want to go with more than 10-20% ethanol you will need to re-jet your fuel delivery system. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:3ZKdnTWzMOEfSLbbnZ2dnUVZ_i2dnZ2d@wideopenwest .com... "J.Kahn" wrote in message ... ... What's required for an a/c to run on part ethanol? John Seals, gaskets, O-rings, and and any hoses in the existing system may or may not hold up against ethanol - likely at least some will not. Corrosion of the fuel tank may also be an issue. If you want to go with more than 10-20% ethanol you will need to re-jet your fuel delivery system. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. There is also the problem of water in the fuel, and the overall loss of horsepower. Your previous take-off distances will not apply. Al G |
MoGas users: Ethanol replacing MTBE | John | Piloting | 167 | May 5th 06 08:31 PM |
MoGas users: Ethanol replacing MTBE | Javier | Piloting | 6 | May 4th 06 06:28 AM |
Ethanol mogas | john smith | Owning | 16 | May 2nd 06 01:30 PM |
Is EAA Working on an STC for Ethanol-laced MoGas? | Jay Honeck | Piloting | 43 | November 28th 05 03:39 AM |
Local Amoco now blending ethanol | Ben Smith | Owning | 5 | April 1st 04 04:37 PM |
