This is a follow-up to a message I sent to the group recently about the
Hartzell propeller AD. I flew out to the prop shop today and had them inspect my hub using the eddy current method. Interesting technology and quite accurate for finding the smallest of cracks on or very near the surface. The inspection only called for an evaluation of the areas surrounding the weight retaining holes but the tech surveyed the area around the blade shanks as well simply because it was easy to do while he had the spinner off. The good news is that my hub was fine (as I expected it to be). The bad news is that while that office hadn't failed any hubs, the Georgia office had apparently failed six so far. That's not a huge number, but it does prove it's not an isolated incident. There is now some "real world" data to support the issuance of the AD. I also took a look at the UK accident report the shop had handy and let me tell you -- the people in that airplane (a 1987 Tobago, IIRC) were EXTREMELY lucky. They applied maximum power on a touch and go and the blade let loose just as they were rotating. If it had failed in flight there is no way they would have survived. The engine was ripped off its mounts and came to rest facing about 70 degrees to the left and pitched upward about 30 degrees. The picture of the hub showed the blade took off and split the hub in half. When I asked the tech for his opinion of why some hubs fail and others don't -- like the one that's been in service on my airplane for 30 years -- he said it's probably a combination of things. There may (or may not) be a design and/or manufacturing process defect. Hartzell will never admit that, obviously. There may also be an installation-specific issue at hand -- like the coupling of this prop with an engine that produces high harmonic vibrations. The O-360 lacks a counterbalanced crankshaft and that fact is responsible for the red arc in the upper-middle portion of the RPM range. He seemed to think that the biggest factor is the fact that most people assume that their props are "smooth enough" and don't need dynamic balancing when in fact they could benefit from it. We looked back at the dynamic balancing history of my prop and found that it came out of the last overhaul with 0.04 IPS with no weights applied. I asked the tech "how common is that?" He said "very rare...we usually can improve the vibration specs of a freshly overhauled propeller". So, it looks like we're good to go for another 100 hours. Hartzell is offering new hubs at a 50% discount if ordered before September 2007, so that will be the next decision for us. $3K in parts and labor buys a lot of inspections and I still say there's something to be said for a regular propeller inspection -- new hub or old. Guess we'll make the call later this summer. -Doug -- -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
On Apr 20, 8:23 pm, Doug Vetter wrote:
This is a follow-up to a message I sent to the group recently about the Hartzell propeller AD. I flew out to the prop shop today and had them inspect my hub using the eddy current method. Interesting technology and quite accurate for finding the smallest of cracks on or very near the surface. The inspection only called for an evaluation of the areas surrounding the weight retaining holes but the tech surveyed the area around the blade shanks as well simply because it was easy to do while he had the spinner off. The good news is that my hub was fine (as I expected it to be). The bad news is that while that office hadn't failed any hubs, the Georgia office had apparently failed six so far. That's not a huge number, but it does prove it's not an isolated incident. There is now some "real world" data to support the issuance of the AD. I also took a look at the UK accident report the shop had handy and let me tell you -- the people in that airplane (a 1987 Tobago, IIRC) were EXTREMELY lucky. They applied maximum power on a touch and go and the blade let loose just as they were rotating. If it had failed in flight there is no way they would have survived. The engine was ripped off its mounts and came to rest facing about 70 degrees to the left and pitched upward about 30 degrees. The picture of the hub showed the blade took off and split the hub in half. When I asked the tech for his opinion of why some hubs fail and others don't -- like the one that's been in service on my airplane for 30 years -- he said it's probably a combination of things. There may (or may not) be a design and/or manufacturing process defect. Hartzell will never admit that, obviously. There may also be an installation-specific issue at hand -- like the coupling of this prop with an engine that produces high harmonic vibrations. The O-360 lacks a counterbalanced crankshaft and that fact is responsible for the red arc in the upper-middle portion of the RPM range. He seemed to think that the biggest factor is the fact that most people assume that their props are "smooth enough" and don't need dynamic balancing when in fact they could benefit from it. We looked back at the dynamic balancing history of my prop and found that it came out of the last overhaul with 0.04 IPS with no weights applied. I asked the tech "how common is that?" He said "very rare...we usually can improve the vibration specs of a freshly overhauled propeller". So, it looks like we're good to go for another 100 hours. Hartzell is offering new hubs at a 50% discount if ordered before September 2007, so that will be the next decision for us. $3K in parts and labor buys a lot of inspections and I still say there's something to be said for a regular propeller inspection -- new hub or old. Guess we'll make the call later this summer. -Doug -- -------------------- Doug Vetter, ATP/CFI -------------------- 1) Hartzell has admited that the current hub has a design flaw and is offering a beefed up hub to avoid the inspection. 2) The new hub deal requires you have servicable blades. They will not be able to put 30 year old blades on a new hub. Figure $6K to replace blades and hub. -Robert |
Robert M. Gary wrote:
1) Hartzell has admited that the current hub has a design flaw and is offering a beefed up hub to avoid the inspection. Where did they admit this? Improving a design is not the same as admitting that there is a design flaw in the previous version. I'm not defending them...just pointing that out. 2) The new hub deal requires you have servicable blades. They will not be able to put 30 year old blades on a new hub. Figure $6K to replace blades and hub. Since when does age have anything to do with it? If the blades meet serviceable limits (various physical criteria), they'll be fine. I've already been told that. In any case, the higher the cost the more I can justify routine inspections. We won't have the airplane forever. -Doug -- -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
On Apr 21, 5:19 am, Doug Vetter wrote:
Robert M. Gary wrote: 1) Hartzell has admited that the current hub has a design flaw and is offering a beefed up hub to avoid the inspection. Where did they admit this? Improving a design is not the same as admitting that there is a design flaw in the previous version. I'm not defending them...just pointing that out. The letter I received said that the current design is subject to blade separation and that the new design addresses this. 2) The new hub deal requires you have servicable blades. They will not be able to put 30 year old blades on a new hub. Figure $6K to replace blades and hub. Since when does age have anything to do with it? If the blades meet serviceable limits (various physical criteria), they'll be fine. I've already been told that. If the prop does not have enough metal left, it is illegal to reinstall it. I'm assuming if your prop is 30 years old enough metal has been removed during facing and O/H's that there will not be enough. If not, good for you. -Robert |
On Apr 21, 9:10 pm, "Robert M. Gary" wrote:
On Apr 21, 5:19 am, Doug Vetter wrote: Robert M. Gary wrote: 1) Hartzell has admited that the current hub has a design flaw and is offering a beefed up hub to avoid the inspection. Where did they admit this? Improving a design is not the same as admitting that there is a design flaw in the previous version. I'm not defending them...just pointing that out. The letter I received said that the current design is subject to blade separation and that the new design addresses this. 2) The new hub deal requires you have servicable blades. They will not be able to put 30 year old blades on a new hub. Figure $6K to replace blades and hub. Since when does age have anything to do with it? If the blades meet serviceable limits (various physical criteria), they'll be fine. I've already been told that. If the prop does not have enough metal left, it is illegal to reinstall it. I'm assuming if your prop is 30 years old enough metal has been removed during facing and O/H's that there will not be enough. If not, good for you. -Robert I just spoke with 1 prop shop that said the rejection rate for blades of those replacing just the hub under this AD is about 75%. Those guys pay extra because the shop had to verify them (vs just ordering an entire prop and R&R'ing) -Robert |
That's a prop shop policy, not regulation. If the blades are servicable, you
can find a shop that will put them on with a new hub. -- ------------------------------- Travis Lake N3094P PWK "Robert M. Gary" wrote in message ps.com... On Apr 20, 8:23 pm, Doug Vetter wrote: This is a follow-up to a message I sent to the group recently about the Hartzell propeller AD. I flew out to the prop shop today and had them inspect my hub using the eddy current method. Interesting technology and quite accurate for finding the smallest of cracks on or very near the surface. The inspection only called for an evaluation of the areas surrounding the weight retaining holes but the tech surveyed the area around the blade shanks as well simply because it was easy to do while he had the spinner off. The good news is that my hub was fine (as I expected it to be). The bad news is that while that office hadn't failed any hubs, the Georgia office had apparently failed six so far. That's not a huge number, but it does prove it's not an isolated incident. There is now some "real world" data to support the issuance of the AD. I also took a look at the UK accident report the shop had handy and let me tell you -- the people in that airplane (a 1987 Tobago, IIRC) were EXTREMELY lucky. They applied maximum power on a touch and go and the blade let loose just as they were rotating. If it had failed in flight there is no way they would have survived. The engine was ripped off its mounts and came to rest facing about 70 degrees to the left and pitched upward about 30 degrees. The picture of the hub showed the blade took off and split the hub in half. When I asked the tech for his opinion of why some hubs fail and others don't -- like the one that's been in service on my airplane for 30 years -- he said it's probably a combination of things. There may (or may not) be a design and/or manufacturing process defect. Hartzell will never admit that, obviously. There may also be an installation-specific issue at hand -- like the coupling of this prop with an engine that produces high harmonic vibrations. The O-360 lacks a counterbalanced crankshaft and that fact is responsible for the red arc in the upper-middle portion of the RPM range. He seemed to think that the biggest factor is the fact that most people assume that their props are "smooth enough" and don't need dynamic balancing when in fact they could benefit from it. We looked back at the dynamic balancing history of my prop and found that it came out of the last overhaul with 0.04 IPS with no weights applied. I asked the tech "how common is that?" He said "very rare...we usually can improve the vibration specs of a freshly overhauled propeller". So, it looks like we're good to go for another 100 hours. Hartzell is offering new hubs at a 50% discount if ordered before September 2007, so that will be the next decision for us. $3K in parts and labor buys a lot of inspections and I still say there's something to be said for a regular propeller inspection -- new hub or old. Guess we'll make the call later this summer. -Doug -- -------------------- Doug Vetter, ATP/CFI -------------------- 1) Hartzell has admited that the current hub has a design flaw and is offering a beefed up hub to avoid the inspection. 2) The new hub deal requires you have servicable blades. They will not be able to put 30 year old blades on a new hub. Figure $6K to replace blades and hub. -Robert |
"issue at hand -- like the coupling of this prop with an engine that
produces high harmonic vibrations. The O-360 lacks a counterbalanced crankshaft and that fact is responsible for the red arc in the upper-middle portion of the RPM range. He seemed to think that the biggest factor is the fact that most people assume that their props are "smooth enough" and don't need dynamic balancing when in fact they could benefit from it." Dynamic prop balancing won't reduce prop stresses very much. It will reduce the vibration transmitted to the engine and eventually to the airframe via the mounts & cowl etc, but not the hub or blade stress. Prop blade and hub fatigue is caused by the constant torsional pounding of the engine combining with a torsionally resonant crankshaft and propeller blade system. On some engines there is a dynamic absorber at the back that substantially reduces the resonant buildup of crank and propeller stress, but many versions of the 4 cylinder IO-360 Lycoming engine don't have these absorbers. Instead they placard the tachometer and expect the operator to not run at certain subharmonics of the crankshaft-propeller torsional resonance. To understand how this torsional vibration mode operates, you must imagine being an observer sitting on the spinner while the engine is running. When this mode is excited, you would see the prop tips oscillate to-and-fro while the rear of the crankshaft oscillated fro- and-to. There is a lot of high frequency (about 220 Hz) torque going through the prop hub and that's what this is all about. Most mechanics don't understand how the dynamic absorbers (they are not counterweights) on the crankshaft if included, are supposed to operate. |
![]() "nrp" wrote in message ups.com... : : Most mechanics don't understand how the dynamic absorbers (they are : not counterweights) on the crankshaft if included, are supposed to : operate. : Elaborate, please... |
![]() Elaborate, please... Check your PM. It is a big file. |
Hartzell 2 blade Prop for PA24-250 | kontiki | Aviation Marketplace | 1 | August 14th 11 10:21 PM |
annual - hartzell AD | Doug Vetter | Owning | 18 | February 24th 07 11:19 PM |
Hartzell prop hub AD 2006-18-15...results and our options | Jack Allison | Owning | 10 | December 27th 06 06:51 PM |
Followup to Tamed | [email protected] | Piloting | 1 | January 18th 05 05:43 PM |
Followup to Tamed | [email protected] | Piloting | 0 | January 17th 05 07:53 PM |
