localizer approach and gs intercept altitude
Old April 21st 07, 10:26 PM posted to rec.aviation.ifr
Matt
Default localizer approach and gs intercept altitude
Hi everyone. A quick question from an instrument student:
If I am flying a localizer approach where there is a glide slope intercept
alitude (lightning bolt) that is lower than the inbound altitude prior to
the final approach fix, can I descend to the gs intercept altitude although
I am flying the nonprecision approach?
For example, on this approach: http://204.108.4.16/d-tpp/0704/00446I20.PDF
Can I descend to 2200 prior to Wesie, or do I have to stay at 2400 until
crossing the non-precision FAF?
Thanks
Matt
Old April 21st 07, 10:43 PM posted to rec.aviation.ifr
Scott Skylane
Thanks
Matt
Matt,
In this case, the 2400 is the minimun altitude while in the hold/course
reversal. You are good to 2200 when inbound for the LOC approach, until
crossing WESIE.
As a side note, who else can spot the huge charting error on that plate?
Happy Flying!
Scott Skylane
Old April 22nd 07, 12:36 AM posted to rec.aviation.ifr
Steven Barnes
6 NM from runway threshold to MAP? Maybe I'm just tired.
"Scott Skylane" wrote in message
intercept
to
although
Thanks
Matt
Matt,
crossing WESIE.
Happy Flying!
Scott Skylane
Old April 22nd 07, 01:33 AM posted to rec.aviation.ifr
Matt
Yes, you are right. It should be 0.6, not 6.0.
"Steven Barnes" wrote in message
Old April 22nd 07, 01:28 AM posted to rec.aviation.ifr
Chris
"Matt" wrote in message
et...
although I am flying the nonprecision approach?
Thanks
Matt
Just follow the procedure
Old April 22nd 07, 01:36 AM posted to rec.aviation.ifr
Ron Rosenfeld
Thanks
Matt
You can descend to 2200 when inbound on the procedure turn, or after
crossing LEADS if you start the approach at GDM or EEN, but that has
NOTHING to do with the GS intercept altitude. 2200' is the charted
altitude for the intermediate segment of the localizer approach.
You may not descend below 2200' until after crossing WESIE.
Old April 22nd 07, 06:29 AM posted to rec.aviation.ifr
Jose
That doesn't make much sense to me. Since at WESIE, if you are on the
glideslope, you are at 1862, you'd be intercepting the glide slope from
above, which is a Bad Thing. Granted, you're probably only four or five
dots high (guessing from the graph) but it's still high.
Also, the underlined 2200 at teh lightining bolt is not at WESIE, it is
at the point where the slope of the course line in the glideslope view
changes. This implies to me that you can descend below 2200 once you
intercept the glide slope, and at WESIE you can expect to be at 1862.
Jose
Get high on gasoline: fly an airplane.
Old April 22nd 07, 04:24 PM posted to rec.aviation.ifr
ArtP
On Sun, 22 Apr 2007 05:29:33 GMT, Jose
The discussion is about the localizer approach (no glide slope). Until
you cross WESIE you don't know where you are so you stay at 2200 feet.
After crossing you can go down to 800 feet until you see the runway
environment. The glide slope will take you down to 521 but this is the
localizer approach so you can't descend below 800.
Old April 22nd 07, 04:31 PM posted to rec.aviation.ifr
Jose
Oh! Duh! Yes, of course stay above 2200 until past WESIE. The GS
intercept is of no consequence with no GS.
Jose
Old April 22nd 07, 06:16 PM posted to rec.aviation.ifr
Ron Rosenfeld
Jose
Jose,
It seems that you missed the beginning of this thread:
"If I am flying a localizer approach..."
When flying a localizer approach, by definition you do not have access to
GS information.
why is intercept altitude labeled "LOC only"? Gary Drescher Instrument Flight Rules 32 September 23rd 06 09:00 PM
Can a failed Glide Slope also void the Localizer approach? Jim Carter Instrument Flight Rules 17 August 24th 06 09:01 PM
Vector altitude for ILS below GS intercept altitude? M Instrument Flight Rules 23 May 20th 06 07:41 PM
Clear to intercept localizer [email protected] Instrument Flight Rules 18 October 8th 05 12:53 PM
Cleared for an approach, then given a different altitude assignment Peter R. Instrument Flight Rules 42 December 11th 04 04:44 PM
