"Jeremy Thomson" wrote
I put the 'use' in quotes becuase I believe TFR modes on radars have been around since the 50's. Vulcan bomber. TFR worked just fine. |
![]() I put the 'use' in quotes becuase I believe TFR modes on radars have been around since the 50's. Is there an activity more addicted to acronyms than flying? To me, TFR means Temporary Flight Restriction, as when Bush II visits Bush I at Kennebunkport and shuts down Cub operations within 30 miles. (Incidentally, I got permission to enter the Class D airspace that envelopes my home, so I could tour the area and show off my flying skills to an adoring family. ATC kept asking me things like: "Are you to the north?" "I just crossed Adams Point 2 miles west." "Is that you circling?" At this point it dawned on me that ATC was looking at his radar and simply couldn't see the Cub because it has no transponder and no aluminum except for the cowling.) all the best -- Dan Ford (email: info AT danford.net) see the Warbird's Forum at http://www.danford.net/index.htm Vietnam | Flying Tigers | Pacific War | Brewster Buffalo | Piper Cub |
![]() Cub Driver wrote in message ... I put the 'use' in quotes becuase I believe TFR modes on radars have been around since the 50's. Is there an activity more addicted to acronyms than flying? Computing. Oh yes. AI ASCII GB KB MB PCMCIA ISA PCI AGP EISA RAM ROM CPU MHz GHz SDR DDR IDE ATAPI SCSI SATA DOS CD CDR CDRW DVD DVDR DVDRW .... .... .... The list is seemingly endless. I could go on with the acronyms... Cheers Graeme |
![]() "S. Sampson" wrote in message ... Vulcan bomber. TFR worked just fine. Wasn't TFR a post-production modification to the Vulcan? |
rthlink.net "S. Sampson" wrote in message ... Vulcan bomber. TFR worked just fine. Wasn't TFR a post-production modification to the Vulcan? Didn't A6-A have TFR? Or am I thinking radar altimeter...? -- http://www.delversdungeon.dragonsfoot.org Remove the X's in my email address to respond. "Damn you Silvey, and your endless fortunes." - Stephen Weir I hate furries. |
"Bill Silvey" wrote...
Didn't A6-A have TFR? Or am I thinking radar altimeter...? The A-6 had TFR, but it wasn't connected to the autopilot. Terrain Following flight was done manually, with reference to the TFR display. |
"John R Weiss" wrote in message
news:JW2Na.97575$R73.10439@sccrnsc04 "Bill Silvey" wrote... Didn't A6-A have TFR? Or am I thinking radar altimeter...? The A-6 had TFR, but it wasn't connected to the autopilot. Terrain Following flight was done manually, with reference to the TFR display. "You so much as hiccup at that altitude and you're dead." Grafton resisted telling Parker he wasn't given to hiccups when flying over North Vietnam. -- http://www.delversdungeon.dragonsfoot.org Remove the X's in my email address to respond. "Damn you Silvey, and your endless fortunes." - Stephen Weir I hate furries. |
In article , Bill Silvey
writes "You so much as hiccup at that altitude and you're dead." Grafton resisted telling Parker he wasn't given to hiccups when flying over North Vietnam. Bit like Guy Gibson V.C. discussing flying 60ft over water at night in WWII "You only need to hiccup at that height and you'd be in the drink". -- John |
rthlink.net... "S. Sampson" wrote in message ... Vulcan bomber. TFR worked just fine. Wasn't TFR a post-production modification to the Vulcan? Yes, it was originally intended for high altitude bombing. Amazing how the aircraft was so versatile. The Raven |
"The Raven" wrote in message ...
"Steven P. McNicoll" wrote in message rthlink.net... "S. Sampson" wrote in message ... Vulcan bomber. TFR worked just fine. Wasn't TFR a post-production modification to the Vulcan? Yes, it was originally intended for high altitude bombing. Amazing how the aircraft was so versatile. The Raven The modification was introduced in 1966 to all the RAFs bombers; however, the previously cancelled TSR-2 would have had a highly advanced Ferranti TFR. One aircraft prototype minus the TFR performed low level terrain following at 250' at Mach .9 shadowed by a Lightning. Since 1962 RAF bomber pilots were being trained to fly low and fast at between 300-500 ft. The TSR-2 with the Ferranti TFR would have been a fantastic low level penetrator as its TFR was designed to allow the pilots to hug the earth at over Mach 1. Rob Rob Rob |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
