Well, there is this kit to boost your Tomahawk to 125 hp. However, so
far I could not find statements on speed gain and fuel burn. So my questions are o How fast do you go with it? o How much fuel do you burn? Thanks virtuPIC -- Airspace V - international hangar flying! http://www.airspace-v.com |
On Apr 27, 5:19 am, virtuPIC wrote:
Well, there is this kit to boost your Tomahawk to 125 hp. However, so far I could not find statements on speed gain and fuel burn. So my questions are o How fast do you go with it? o How much fuel do you burn? A 12hp gain over the factory engine would not do much for cruise speed (5kt?) or change fuel burn noticeably. The climb rate might be a bit better though |
On Apr 27, 10:25 am, Kingfish wrote:
On Apr 27, 5:19 am, virtuPIC wrote: Well, there is this kit to boost your Tomahawk to 125 hp. However, so far I could not find statements on speed gain and fuel burn. So my questions are o How fast do you go with it? o How much fuel do you burn? A 12hp gain over the factory engine would not do much for cruise speed (5kt?) or change fuel burn noticeably. The climb rate might be a bit better though Oops. That's a whopping *13* HP gain over the stock PA38-112. Weak math skills. My bad. |
Kingfish wrote:
On Apr 27, 5:19 am, virtuPIC wrote: Well, there is this kit to boost your Tomahawk to 125 hp. However, so far I could not find statements on speed gain and fuel burn. So my questions are o How fast do you go with it? o How much fuel do you burn? A 12hp gain over the factory engine would not do much for cruise speed (5kt?) or change fuel burn noticeably. The climb rate might be a bit better though You can soup up a VW, it's still a VW. |
On Apr 27, 8:31 am, Ron Natalie wrote:
Kingfish wrote: On Apr 27, 5:19 am, virtuPIC wrote: Well, there is this kit to boost your Tomahawk to 125 hp. However, so far I could not find statements on speed gain and fuel burn. So my questions are o How fast do you go with it? o How much fuel do you burn? A 12hp gain over the factory engine would not do much for cruise speed (5kt?) or change fuel burn noticeably. The climb rate might be a bit better though You can soup up a VW, it's still a VW. One of the best things about the Tramahawk is that you can sit aloft for hours on end on next to no gas. The 125hp engine must suck more gas. |
"Kingfish" wrote Oops. That's a whopping *13* HP gain over the stock PA38-112. Weak math skills. My bad. That is still around a 10% improvement in HP, so it should be noticeable, most likely in climb and in fuel burn. -- Jim in NC |
On Apr 27, 11:23 am, "Robert M. Gary" wrote:
One of the best things about the Tramahawk is that you can sit aloft for hours on end on next to no gas. The 125hp engine must suck more gas. I thought the best thing about that airplane was its sturdy landing gear. I can personally attest to its strength after several carrier landings when I was training for my PPL. Nowadays, the 125hp Conti-powered Katana is just the thing to buzz around in and not burn much gas - at 130kts to boot |
"virtuPIC" wrote in message ups.com... Well, there is this kit to boost your Tomahawk to 125 hp. However, so far I could not find statements on speed gain and fuel burn. So my questions are o How fast do you go with it? o How much fuel do you burn? Thanks virtuPIC -- Airspace V - international hangar flying! http://www.airspace-v.com I owned a Tomahawk for several years. Realistically, it was a 100-105 knot aircraft - the book said 108, but that was for a factory new airplane. Anyway, I just ran the numbers and you should expect to burn 7 gph at 75%, and you'll see maybe 4 additional knots of airspeed. The biggest improvement will be in climb performance. At sea level, you should see an additional 250 fpm... KB |
"Kingfish" wrote in message oups.com... On Apr 27, 11:23 am, "Robert M. Gary" wrote: One of the best things about the Tramahawk is that you can sit aloft for hours on end on next to no gas. The 125hp engine must suck more gas. I thought the best thing about that airplane was its sturdy landing gear. I can personally attest to its strength after several carrier landings when I was training for my PPL. I rattled my own teeth, and my instructor's, a few times; before the extended float float from a couple of faster than normal approaches gave me enough time to observe and learn. After that it was easy to be fairly smooth--even though the undercarriage is a bit stiffer than on a Cessna 152. OTOH, you definitely *can* break it. The FBO I rented from had two Tomahawks--until some fool stalled one much too high. (Truth be told, I never found out whether he simply slammed it down on the mains or let the nose drop as well--it happened at a remote field and IIRC there was additional damage from the recovery and transport.) Nowadays, the 125hp Conti-powered Katana is just the thing to buzz around in and not burn much gas - at 130kts to boot I am looking forward to trying the Katana, as well as the Sport Cruiser. Peter |
"Kyle Boatright" wrote in message . .. "virtuPIC" wrote in message ups.com... Well, there is this kit to boost your Tomahawk to 125 hp. However, so far I could not find statements on speed gain and fuel burn. So my questions are o How fast do you go with it? o How much fuel do you burn? Thanks virtuPIC -- Airspace V - international hangar flying! http://www.airspace-v.com I owned a Tomahawk for several years. Realistically, it was a 100-105 knot aircraft - the book said 108, but that was for a factory new airplane. Anyway, I just ran the numbers and you should expect to burn 7 gph at 75%, and you'll see maybe 4 additional knots of airspeed. The biggest improvement will be in climb performance. At sea level, you should see an additional 250 fpm... KB That confirms what I have long suspected: I could only justify it to operate from a higher altitude airport--which is just not in the cards. Peter |
| Thread Tools | |
| Display Modes | |
| Tomahawk Launch | niceguy | Aviation Photos | 0 | November 15th 06 10:48 PM |
| Tomahawk/ Skipper | W P Dixon | Piloting | 46 | November 18th 05 06:43 PM |
| Complex / High Performance / Low Performance | R.T. | Owning | 22 | July 6th 04 09:04 AM |
| New tactical tomahawk | BOB URZ | Military Aviation | 19 | June 23rd 04 08:22 PM |
| Are these Tomahawk Engines? | Peter Strong | Military Aviation | 9 | April 8th 04 02:41 PM |
