AOPA advocates in-flight mobile phone use
Old April 28th 07, 03:39 AM posted to rec.aviation.soaring
Eric Greenwell
Default AOPA advocates in-flight mobile phone use
A recent article highlights the AOPA's advocacy of in-flight cell phone use:
http://www.aopa.org/whatsnew/newsite...070426fcc.html
It references this March 2005 article,
http://www.aopa.org/whatsnew/newsite...50328cell.html
which states in part:
Despite the concern in some quarters that cell phones might cause
interference with aircraft radios and navigation equipment, the FAA
has never prohibited their use for aircraft operating under VFR. The
aviation agency always has given pilots the final authority on what
portable electronic devices could be used in the flight. And AOPA
talked with several major cell phone service providers and found no
restrictions on using their services in GA cockpits.
So, the FAA doesn't care if we use mobile phones in our gliders, and the
networks don't mind if we use mobile phones in our gliders, and with a
complete lack of reported problems from doing so, I'd like to suggest
using a mobile phone in a glider doesn't produce any victims. I further
suggest if safety or your spouses peace of mind is a stake, you can make
a call on your mobile without guilt.
Perhaps our discussions about in-flight use of mobile phones should
shift to why the FCC is so far behind the users and providers of mobile
phones.
Old April 28th 07, 12:57 PM posted to rec.aviation.soaring
Ray Lovinggood
The few times I've even thought about using my cell
phone while in the glider, I never could get a signal.
I was always flying over populated areas where, on
the ground, I usually get good signal coverage.
My service provider is Alltel. Is my lack of signal
in the air due to the phone I have, the service provider,
the cell phone tower locations and orientation?
Ray Lovinggood
Carrboro, North Carolina, USA
might cause
the FAA
under VFR. The
authority on what
And AOPA
and found no
gliders, and with a
like to suggest
victims. I further
phones should
providers of mobile
phones.
* Change 'netto' to 'net' to email me directly
* 'Transponders in Sailplanes' http://tinyurl.com/y739x4
* 'A Guide to Self-launching Sailplane Operation' at
www.motorglider.org
Old April 28th 07, 02:38 PM posted to rec.aviation.soaring
dwrobel[_2_]
Twice in the last couple of years, while flying local flights in the
glider, I have receieve cell phone calls from pilots that had landed
out during their cross country flights. They were far enough away
that they could not make radio contact with me but could get cell
coverage. Both times I was at between 10k and 12k MSL. I chose
Verizon as my service provider for the reason that they seem to have
the best coverage away from populated areas i.e. in the mountains and
in the desert, at least in Utah. I don't think I have as good of
coverage in the air as on the ground because my battery drains faster
in the air, probably because it is searching for a signal.
Dan Wrobel
Logan, Utah
Old April 28th 07, 03:47 PM posted to rec.aviation.soaring
Eric Greenwell
Your experience is a common one for the pilots I know. The phone and
provider are factors, but I think the biggest factor is population
density: the bigger it is, the smaller the cells. My explanation is
smaller cells means lower power for each cell and each cell uses a more
"focused" antenna, both of which means the signal stays closer to the
ground. In rural areas, the cells are bigger, power is higher, the
antennas are less focused, and the signal goes higher.
Asking other pilots about their experience might lead you to a better
combination of provider and phone. I don't know of any better way to
determine what's likely to work the best.
Old April 28th 07, 04:09 PM posted to rec.aviation.soaring
COLIN LAMB
Eric hit it right on the button - about focusing. Gain is attained at the
expense of directivity. The more gain, the further the signal transmits and
receives and the less power required. Assuming the cell tower is at the
same terrain height (or slightly higher), it will try to concentrate all of
the power along the horizon. Any signal going upwards will mean less signal
where people need it.
If the antenna is designed correctly, your signal will decrease as your
angle above the horizon increases. Directly above the cell tower would
likely have a total null. That means that at altitude you will likely have
the strongest signal from the cell tower furthest away - because it is the
lower angle.
Vhf omni-directional antennas have much less gain and directivity, so it is
much less of a problem on the aircraft frequencies - but still can be an
issue if you are directly over the station on the ground. I have seen
repeater antennas on mountain tops near the town they want to cover actually
invert the ground plane to provide better penetration into the town below.
Colin
Old April 28th 07, 05:45 PM posted to rec.aviation.soaring
Forest Baskett
As I understand it, each base station is tracking the
cell phones it can hear and is alert for a hand-off.
So the more base stations that a cell phone can be
heard by, the more load on the network. Thus a cell
phone in the air may put more load on the network than
one on the ground. I don't know how significant this
load is.
As per the example of the mountain top repeater, I
think that different base stations use different types
of antennas depending on the surrounding terrain they
are trying to cover. In flat areas the antennas have
very horizontal propagation characteristics. You can
see that if you watch your signal strength as you take
off as a passenger from a flat terrain airport. It
disappears after one or two thousand feet. But if
you are flying over rougher terrain, say Telluride,
the signal strength will be fine at 13,000 feet directly
over the town or many miles from it, for example.
Forest
decrease as your
- because it is the
lower angle.
I have seen
Colin
Old April 30th 07, 05:50 AM posted to rec.aviation.soaring
Mike Schumann
I suspect that the antennas used by the providers have very limited vertical
beam width. I have T-Mobile service, which is quite good in most areas.
However, I didn't have service on the observation deck of the Empire State
Building in New York last year.
Mike Schumann
"Ray Lovinggood" wrote in
message ...
Ray Lovinggood
might cause
the FAA
under VFR. The
authority on what
And AOPA
and found no
gliders, and with a
like to suggest
victims. I further
phones should
providers of mobile
phones.
www.motorglider.org
Posted via a free Usenet account from http://www.teranews.com
Old April 30th 07, 04:17 PM posted to rec.aviation.soaring
kirk.stant
Oh, great, now we'll have all those bugsmasher pilots talking on their
cells while flying VFR - forget about visual lookout anymore!
It's already been documented that driving a car while talking on a
cell is more dangerous that driving with a .08 blood alcohol level.
But I guess AOPA thinks pilots are different...
Turn the damn thing off until you need it!
Kirk
Old April 30th 07, 05:40 PM posted to rec.aviation.soaring
Eric Greenwell
Newsflash! The bug smashers are already doing it, and visual lookout is
surely suffering in a few cases. It's not clear that most of these
pilots were doing a lot of looking out before they turned on their cell
phones, however, so safety may not be affected much!
I haven't read AOPA's position any further than the two short articles I
referenced, so I can't speak for them; however, even if the pilots might
not be any different, the situation certainly is. Flying an airplane
simply does not involve the close attention driving a car does, except
close to airports, so I don't think we can apply studies done for
driving to flying.
Still good advice, except "need" means very different things to
different people. I suggest "you need it" should mean "safety will be
enhanced". Besides the obvious things like dealing with a radio failure,
I include calling my wife to make a position report if I can't get the
information to her by radio.
Old April 30th 07, 05:51 PM posted to rec.aviation.soaring
Jim Vincent
news:5_oZh.4359$r77.1770@trndny08...
surely suffering in a few cases. It's not clear that most of these pilots
were doing a lot of looking out before they turned on their cell phones,
I got Sporty's DVD on VFR commuication. It is a real world video of three
pilots communicating while flying VFR. Their VFR scan was to glance up
quickly perhaps once or twice...pretty scary.
AOPA phone survey? [email protected][_1_] Owning 8 March 26th 07 02:19 PM
Fighter simulation game depicting a real MFD on your mobile phone? [email protected] Naval Aviation 0 December 23rd 05 05:20 AM
AOPA urges allowing cell phone use in general aviation Eric Greenwell Soaring 7 March 30th 05 08:44 PM
Vario Sound for my mobile phone jorgie Soaring 1 October 18th 04 04:21 PM
FA: King KT96 Flight Phone VC Aviation Marketplace 0 October 13th 03 02:59 PM
