![]() Our EAA chapter is perpetually scheming for ways to acquire a hangar for member aircraft and for chapter activities. Obviously, any reasonably sized hangar requires a substantial outlay of funds. The cost issue seems to be the big hold-up right now. Anyway, we're looking at a variety of pre-engineered metal building options for a 50x60 (approx) hangar, but would consider a "homebuilt" alternative if we could come up with a design that would be functional (it would need to meet code and have decent aesthetics), more affordable than commercially purchased alternatives, and that could be built by your typical group of enthusiasts. Thoughts? Suggestions? By the way, the hangar would be at a public airport, and we've been directed by the airport authority that Quonset hut type shelters or bigger versions of portable garage type buildings will not get their approval. I suspect that what they really want us to build is a commercially purchased hangar, but until they rule out other alternatives, we're gonna pursue all viable options. |
Well, there may be a different way, but I can tell you that as a
carpenter I estimated building my own hanger instead of ordering one. The cost difference was minimal. The part that was a money saver was the hanger door. Instead of paying the big money for a folding door, I came up (on paper) with a panel system very similiar to the glass doors you see at malls that fold up into a pocket. The doors would be made of plywood and each one would have a barrel to set into the concrete floor. In other words, you will probebly be better off with a commercial building. Lou |
![]() "Lou" wrote in message ps.com... Well, there may be a different way, but I can tell you that as a carpenter I estimated building my own hanger instead of ordering one. The cost difference was minimal. The part that was a money saver was the hanger door. Instead of paying the big money for a folding door, I came up (on paper) with a panel system very similiar to the glass doors you see at malls that fold up into a pocket. The doors would be made of plywood and each one would have a barrel to set into the concrete floor. In other words, you will probebly be better off with a commercial building. Lou I tend to agree - a metal box on a concrete floor is a pretty basic and inexpensive structure, when you consider that it gives you something that should be windproof, waterproof, and should hold up well for a long time if basic maintenance is done. On the other hand, there is always the chance that someone has figured out a hangar design is labor intensive but not capital intensive. That might work for us. So I'm compelled to ask. KB |
![]() "Kyle Boatright" wrote On the other hand, there is always the chance that someone has figured out a hangar design is labor intensive but not capital intensive. That might work for us. So I'm compelled to ask. Something way different, seen in these links... Benifits are strong resistance to wind and earthquake, and different enough that you will generate some community interest. http://www.domtec.com/process.html http://www.greenhomebuilding.com/manufactured_systems.htm http://www.ysmforbuilding.com/domecrete1.htm -- Jim in NC |
("Morgans" wrote)
Benifits are strong resistance to wind and earthquake, and different enough that you will generate some community interest. http://www.domtec.com/process.html http://www.greenhomebuilding.com/manufactured_systems.htm http://www.ysmforbuilding.com/domecrete1.htm Well, that's two and a half hours of sleep I won't be getting tonight. Thanks a lot Jim in NC!!!! Montblack Must stop reading.... Must sleep....! |
![]() "Montblack" wrote Well, that's two and a half hours of sleep I won't be getting tonight. Thanks a lot Jim in NC!!!! chuckle So glad I could help! g There really is some interesting stuff, in those pages. The real trick is finding someone in the area that does that kind of construction. If I was younger, and still in commercial construction, I think I would look into building these domes. I was not able to find the exact page that I was looking for. I remember seeing a hangar that was a concrete dome, and had two doors, that were the same shape as the dome. They would stay in a down position, but rotate along the inside wall, thus taking up very little space. These buildings are the most wind resistant of any building shape ever tested. They can easily withstand a level 3 hurricane, and possibly more. -- Jim in NC |
Kyle Boatright wrote:
Our EAA chapter is perpetually scheming for ways to acquire a hangar for member aircraft and for chapter activities. Obviously, any reasonably sized hangar requires a substantial outlay of funds. The cost issue seems to be the big hold-up right now. Anyway, we're looking at a variety of pre-engineered metal building options for a 50x60 (approx) hangar, but would consider a "homebuilt" alternative if we could come up with a design that would be functional (it would need to meet code and have decent aesthetics), more affordable than commercially purchased alternatives, and that could be built by your typical group of enthusiasts. Thoughts? Suggestions? By the way, the hangar would be at a public airport, and we've been directed by the airport authority that Quonset hut type shelters or bigger versions of portable garage type buildings will not get their approval. I suspect that what they really want us to build is a commercially purchased hangar, but until they rule out other alternatives, we're gonna pursue all viable options. Kyle, 50X60 steel building will cost around $50,000 for the building. Erecting it would be around $30,000. check out R&M steel. http://www.rmsteel.com/ We have two of there building and will have a third soon. Michelle |
![]() "Michelle P" wrote in message ink.net... Kyle Boatright wrote: Our EAA chapter is perpetually scheming for ways to acquire a hangar for member aircraft and for chapter activities. Obviously, any reasonably sized hangar requires a substantial outlay of funds. The cost issue seems to be the big hold-up right now. Anyway, we're looking at a variety of pre-engineered metal building options for a 50x60 (approx) hangar, but would consider a "homebuilt" alternative if we could come up with a design that would be functional (it would need to meet code and have decent aesthetics), more affordable than commercially purchased alternatives, and that could be built by your typical group of enthusiasts. Thoughts? Suggestions? By the way, the hangar would be at a public airport, and we've been directed by the airport authority that Quonset hut type shelters or bigger versions of portable garage type buildings will not get their approval. I suspect that what they really want us to build is a commercially purchased hangar, but until they rule out other alternatives, we're gonna pursue all viable options. Kyle, 50X60 steel building will cost around $50,000 for the building. Erecting it would be around $30,000. check out R&M steel. http://www.rmsteel.com/ We have two of there building and will have a third soon. Michelle I'm helping a local EAA partnership put one of these up in RBG. It is an 80' X 80' and the receipt was for $47,500, delivered(I think we are getting the door from someone else). It is going together like a big erector set, and things fit very well. I've built pole barns before, and this is a piece of cake. Al G |
KyleOn May 9, 7:14�pm, "Kyle Boatright"
wrote: Our EAA chapter is perpetually scheming for ways to acquire a hangar for member aircraft and for chapter activities. *Obviously, any reasonably sized hangar requires a substantial outlay of funds. The cost issue seems to be the big hold-up right now. Anyway, we're looking at a variety of pre-engineered metal building options for a 50x60 (approx) hangar, but would consider a "homebuilt" alternative if we could come up with a design that would be functional (it would need to meet code and have decent aesthetics), more affordable than commercially purchased alternatives, and that could be built by your typical group of enthusiasts. Thoughts? Suggestions? By the way, the hangar would be at a public airport, and we've been directed by the airport authority that Quonset hut type shelters or bigger versions of portable garage type buildings will not get their approval. *I suspect that what they really want us to build is a commercially purchased hangar, but until they rule out other alternatives, we're gonna pursue all viable options. Kyle - Our chapter (www.eaa32.org) went through the same drama several years ago. While we were debating the budget vs. construction type issue, one of our members got a lead on an existing 40' X 100' metal building that was scheduled to be torn down for new highway construction. In fact, it had been the State DOT's field office for the project, and was on land owned by a local hotel chain. Being organized as a 501(c)3 not-for-profit corporation that made it possible for them to donate the building to us and take a tax right off. When we got the green light from the hotel firm, we put out the call for all able bodied members to come out to disassemble the building, and stuff the salvagable material into some rented trailers, and hauled them up to our county airport location. One member fortunately had access to a mobil crane which was needed to disassemble the metal frame and load onto a flatbed. Incredibly, we accomplished all this in less than three weeks with a bunch of part-timers. At this point everyone thought we were almost (in our) home. Reality set in when we discovered that before ground breaking, we had to: 1. Negotiate a favorable long term lease for the land with the county. 2. Hire a professional engineering firm to design a new foundation. 3. Make new plans for the interior. 4. Buy a fold-up door (included engineering modification to building frame) 5. Get plans approved by eight agencies, including FEMA because it is located in a flood plain. Because we decided to rebuild it ourselves, it took about two years to go through the above, and then about four years of Saturdays to get to where we could lock the door (like a homebuilt, we can't say it's really complete, but it's usable). Most of the building process is documented on our website under "ARC" which officially stands for Aviation Resource Center, but some wags opine that being in a flood plain suggests something else. One important caveat as part of the negotiation with the airport is that the ARC was not to be used of long term storage of airplanes. This turned out not to be an issue b/c we basically need all the available space for meetings and short term aircraft use at critical completion points. We learned a lot, many of us had to readjust our saturdays after the construction was complete, and in spite of the occasional ruffled feather, I would say that most found it an enjoyable experience. And, after years of yakking about it, we finally have a home. If any chapter wants to do anything like what I've described here, I will be glad to pass on our experience in the form of what to do, or not do, as the case may be based on our experience. BTW, if you can't find a friendly building donor, there are some buiding component companies around I can steer you to to get the lowest starting cost if you want to do it with "sweat equity" like we did. We ended up going to them for many components because some stuff just wasn't reusable. Doug Killebrew Construction Manager, EAA 32, (Ret) |
To second item #1 below..
An insufficiently long enough term lease bit our chapter badly at a city airport. Even though totally financing/constructing our shop/hanger/building, after 25 years we "lost" it to the city. Our rent went from $0 to almost $300/ month. Be aware that city airport commissions can change easily from GA/experimental friendly to not. We lost every discussion over the last 4 years and now spend most of our time chasing revenue to cover our expenses....As I understand, the land was leased for 20 years at no rent and our building became theirs afterwards for us to rent like other hangers on the field. ie: no "break" to EAA chapter. wrote in message ups.com... KyleOn May 9, 7:14?pm, "Kyle Boatright" wrote: Our EAA chapter is perpetually scheming for ways to acquire a hangar for member aircraft and for chapter activities. Obviously, any reasonably sized hangar requires a substantial outlay of funds. The cost issue seems to be the big hold-up right now. Anyway, we're looking at a variety of pre-engineered metal building options for a 50x60 (approx) hangar, but would consider a "homebuilt" alternative if we could come up with a design that would be functional (it would need to meet code and have decent aesthetics), more affordable than commercially purchased alternatives, and that could be built by your typical group of enthusiasts. Thoughts? Suggestions? By the way, the hangar would be at a public airport, and we've been directed by the airport authority that Quonset hut type shelters or bigger versions of portable garage type buildings will not get their approval. I suspect that what they really want us to build is a commercially purchased hangar, but until they rule out other alternatives, we're gonna pursue all viable options. Kyle - Our chapter (www.eaa32.org) went through the same drama several years ago. While we were debating the budget vs. construction type issue, one of our members got a lead on an existing 40' X 100' metal building that was scheduled to be torn down for new highway construction. In fact, it had been the State DOT's field office for the project, and was on land owned by a local hotel chain. Being organized as a 501(c)3 not-for-profit corporation that made it possible for them to donate the building to us and take a tax right off. When we got the green light from the hotel firm, we put out the call for all able bodied members to come out to disassemble the building, and stuff the salvagable material into some rented trailers, and hauled them up to our county airport location. One member fortunately had access to a mobil crane which was needed to disassemble the metal frame and load onto a flatbed. Incredibly, we accomplished all this in less than three weeks with a bunch of part-timers. At this point everyone thought we were almost (in our) home. Reality set in when we discovered that before ground breaking, we had to: 1. Negotiate a favorable long term lease for the land with the county. 2. Hire a professional engineering firm to design a new foundation. 3. Make new plans for the interior. 4. Buy a fold-up door (included engineering modification to building frame) 5. Get plans approved by eight agencies, including FEMA because it is located in a flood plain. Because we decided to rebuild it ourselves, it took about two years to go through the above, and then about four years of Saturdays to get to where we could lock the door (like a homebuilt, we can't say it's really complete, but it's usable). Most of the building process is documented on our website under "ARC" which officially stands for Aviation Resource Center, but some wags opine that being in a flood plain suggests something else. One important caveat as part of the negotiation with the airport is that the ARC was not to be used of long term storage of airplanes. This turned out not to be an issue b/c we basically need all the available space for meetings and short term aircraft use at critical completion points. We learned a lot, many of us had to readjust our saturdays after the construction was complete, and in spite of the occasional ruffled feather, I would say that most found it an enjoyable experience. And, after years of yakking about it, we finally have a home. If any chapter wants to do anything like what I've described here, I will be glad to pass on our experience in the form of what to do, or not do, as the case may be based on our experience. BTW, if you can't find a friendly building donor, there are some buiding component companies around I can steer you to to get the lowest starting cost if you want to do it with "sweat equity" like we did. We ended up going to them for many components because some stuff just wasn't reusable. Doug Killebrew Construction Manager, EAA 32, (Ret) |
3D design | island life | Rotorcraft | 4 | October 23rd 05 01:31 AM |
DR-107 One Design | [email protected] | Aerobatics | 0 | October 12th 05 09:45 PM |
3D design | island life | Rotorcraft | 0 | September 13th 05 02:36 PM |
old gyrocopter design? | E. Glaser | Rotorcraft | 1 | August 9th 05 03:52 AM |
Strop design | Edward Weaver | Soaring | 3 | July 20th 05 06:03 PM |
