Would like to learn to fly, but...
Old May 11th 07, 02:23 PM posted to rec.aviation.misc
Default Would like to learn to fly, but...
Having become dangerously addicted to MS Flight Simulator, I am
starting to develop a hankering to learn to fly for real. However I'm
having a bit of trouble reconciling this desire with my concern about
CO2 emissions and climate change. My wife and I tend to buy reasonably
fuel efficient cars and are soon to have a wind turbine installed on
our house, so to start burning aviation fuel just for fun would seem
like a bit of a step in the wrong direction.
Can anyone provide any insights to help me allay these concerns? I
don't even know how much fuel the average light aircraft consumes or
how much CO2 it puts out into the atmosphere. Is it comparable to a
car or is it a lot more? (My car gets about 50mpg, but then I spend a
lot more time driving it than I could ever afford to spend flying a
plane.)
Thanks in advance,
Colin
Old May 11th 07, 06:32 PM posted to rec.aviation.misc
B A R R Y[_2_]
Ron Hardin wrote:
Stay with the flight simulator. It's more fun,
Are you a licensed pilot who's kidding, or a wannabe?
Old May 11th 07, 07:26 PM posted to rec.aviation.misc
Ron Hardin
I have 1200 hours, from many years of flying, age 16 to 30, when
I gave it up out of boredom. ``Here I am at 2500 feet over the
Boonton reservoir again...'' Took up long distance bike riding, in
fact, which then expended the weekends where I had previously been
living in the air.
The flight sim gets rid of all the overhead, and the FAA doesn't mind
you hugging the ground as you skim the mountains inverted in a 737.
Ron Hardin
On the internet, nobody knows you're a jerk.
Old May 11th 07, 11:14 PM posted to rec.aviation.misc
B A R R Y
On Fri, 11 May 2007 18:26:50 GMT, Ron Hardin
Why didn't you move up? Do you have any advanced ratings?
living in the air.
I do the same, but I fly, too. G
No argument on that one.
Old May 12th 07, 01:25 PM posted to rec.aviation.misc
Peter R.
Two words: Angel Flight
Many have expressed that volunteering for Angel Flight has reinvigorated the
excitement of flying.
Peter
Old May 12th 07, 03:03 PM posted to rec.aviation.misc
Ron Hardin
Peter
In other words, in fact, mostly it becomes pointless, particularly when compared with
other uses for your time.
Points of contact between actual flying and what the childhood idea of it is, are
very few ; occasionally they meet again, but very infrequently, and in ways hard to
repeat.
Setting some goal is a help in maintaining interest. In my own case, I got really,
really good at gusty crosswind landings, and incredibly steep slip-to-landing approaches
when that wasn't available. But you run out of things you can perfect without killing
yourself, eventually.
Ham radio operators have the same burnout. The surviving ones often imagine themselves
serving in some vastly important communications role, which is hard for me to imagine but
they convince themselves, which is all that counts, I guess.
I happened to find that long distance bike riding was a better use of weekend time -
after a couple hundred miles on a weekend, which was typical, you actually feel you've
been somewhere.
Adding things up, I've accumulated about 100,000 miles flying and 300,000 miles biking.
The biking has a sort of build-in goal that you can commute to work with it, and do
every chore, just about, as well.
Hmm.. http://home.att.net/~rhhardin4/odyssy9.jpg
Ron Hardin
Old May 11th 07, 04:27 PM posted to rec.aviation.misc
Christopher Brian Colohan
writes:
plane.)
Sorry to say, but most small airplanes burn more fuel than your car.
Also, due to their older engine design, most burn leaded fuel.
One datapoint: the plane I am training in, a Piper Tomahawk, burns 6.5
gallons of 100LL fuel per hour, holds two people, and cruises around
110mph. So that is roughly 17mpg. There are more efficient planes
(for example, I think the Diamond Katana burns less gas), and there
are less efficient ones (to overgeneralize, faster == more gas, and
older plane == more gas).
I justify my flying to myself by arguing that I fly many fewer hours
per year than most people drive (I use my bicycle as my main form of
transportation). But it is somewhat hard to make a solid
environmental argument for any form of recreation which burns gas.
Chris
Old May 11th 07, 05:22 PM posted to rec.aviation.misc
Chris.Cheney
wrote in news:1178889791.422239.321860
@o5g2000hsb.googlegroups.com:
I am
However I'm
concern about
buy reasonably
installed on
would seem
concerns? I
consumes or
comparable to a
then I spend a
flying a
plane.)
Thanks in advance,
Colin
Have you considered flying a glider? The flight controls are
identical to powered aircraft but all those relating to the
engine are missing (so they don't distract one from the real
task of flying G). Although one typically consumes non-
renewable energy in the launch (by aerotow or winch), after
casting off at perhaps 2000 ft, one uses natural phenomena
(thermals, ridge lift, wave) to keep the force of gravity at
bay.
Have a look at the world gliding records
http://records.fai.org/gliding/) - you'll probably be
surprised.
There are two downsides: there is no possibility of
performing a go-around if one screws up on the landing and
the weather plays a much larger factor.
Old May 11th 07, 10:39 PM posted to rec.aviation.misc
Colin Caughie
Actually I've been there and done that. I went solo in a glider about 15
years ago, but fairly soon afterwards burned out on it in much the same
way that Ron appears to have done with powered flight. At that point I
switched to hillwalking, which was less weather dependent (if you didn't
mind getting wet) and allowed me to spend the entire day enjoying my
hobby instead of most of it pushing gliders around.
Fortunately never had a problem with landing (but then I never went
cross country, things get a bit different at that point), but living in
Scotland the weather plays an even larger factor than in most places. It
was considered a pretty good day if you managed more than about 10
minutes in the air.
Having said that I'll never forget the day I reached almost 10,000 feet
in wave. That day alone made it worth all the time, money and glider
pushing.
I'd imagined that with powered flight you'd be somewhat less at the
mercy of the weather, but I guess it comes with its own frustrations.
Maybe Ron's right and I should stick to simming.
Colin
a learn to fly contest Paul J. Lewis Aviation Marketplace 0 March 21st 06 11:53 PM
LEARN HOW TO WELD plumbcrazy Home Built 1 January 21st 06 06:28 AM
Learn To Fly - Chickasha, OK [email protected] Aviation Marketplace 0 August 5th 05 08:25 PM
Best Place to Learn to Fly? [email protected] Piloting 38 May 25th 05 10:34 AM
So...does KYLE ever learn How to Fly??... D. Reid Home Built 11 November 5th 04 04:43 PM
