GNS430 vs. GX60 - missing functions
Old May 13th 07, 07:04 PM posted to rec.aviation.ifr
Jim Carter[_1_]
Default GNS430 vs. GX60 - missing functions
This question particularly applies to the CAP mission pilots in the group:
we have been flying GX50 and 60s in our CAP birds, but I'm playing with
a GNS430 in a private aircraft. There doesn't seem to be a correlation of
the SAR functions in Garmin's unit like Apollo's.
I'd like to know how others handle the missing functions. Do you manually
create a flight plan with waypoints at the end of each grid leg? 30 years
ago we only had to use pencil and charts, but now we have to demonstrate
integration of the GPS into our search patterns. The Apollo makes it easy
with the SAR map page; what am I missing on the Garmin?
Jim Carter
Rogers, Arkansas
Old May 13th 07, 07:09 PM posted to rec.aviation.ifr
Roy Smith
My understanding is that Apollo put specific functionality into their boxes
to allow flying SAR grids specifically because they were chasing a big CAP
contract. So, it's not surprising it's not in the Garmin boxes.
Old May 13th 07, 09:42 PM posted to rec.aviation.ifr
Peter Clark
The CAP version of the G1000 182 has search grids.
Old May 13th 07, 11:40 PM posted to rec.aviation.ifr
Jim Carter[_1_]
I thought I read that the 1000 uses the 400/500 series logic to drive it. If
that's so, then I wonder why the macro to generate the flight plan isn't
retrofitted to the earlier units.
Jim Carter
Rogers, Arkansas
"Peter Clark" wrote in message
group:
with
of
manually
years
easy
boxes
Old May 14th 07, 11:25 PM posted to rec.aviation.ifr
Robert M. Gary
On May 13, 1:42 pm, Peter Clark
The CAP version of the G1000 182 has search grids.- Hide quoted text -
- Show quoted text -
Interesting because our G1000 CAP 182 does not. We program in the 4
points of the grid and then create a flight plan around it. In fact
that is one of the required exercies for observers to get signed off
in the squadron. The observer basically owns the right screen and the
pilot owns the left ( you can use the inset to see anything you would
have seen on the right screen).
Old May 14th 07, 11:39 PM posted to rec.aviation.ifr
Peter Clark
On 14 May 2007 15:25:19 -0700, "Robert M. Gary"
When you dial the range down sufficiently does your system not draw
grids? Or are we talking about two different things?
Old May 15th 07, 04:10 AM posted to rec.aviation.ifr
Robert M. Gary
On May 14, 3:39 pm, Peter Clark
It shows the same section grid lines that any G1000 does but it does
not allow you to flight plan to a CAP named grid like our GX60 (with
CAP database) did.
-Robert
Old May 15th 07, 01:47 PM posted to rec.aviation.ifr
Jim Carter[_1_]
The GX 50/60 series puts the grid lines on the quadrangle with WPTs at each
turnpoint. Does the G1000 do the same?
But back to any of the non-GX 50/60 class; does the aircrew just calculate
and program in the WPTs by hand, or do they use the old pencil and chart
method to layout the grid track?
Jim Carter
Rogers, Arkansas
Old May 17th 07, 05:03 PM posted to rec.aviation.ifr
Um... ours does not have it yet: N652CP, T182T/Nav III, Colorado Wing.
Did you get this with a software upgrade, or is there some
"bump and twist" of the knobs that I have not read about?
Please share how to turn on G1000 182 has search grids.
Thank you!
Best regards,
LtCol Jer/ Eberhard, Colorado Wing Checkpilot (airplanes and gliders),
Assistant Glider Program Manager, Colorado Wing, CAP
LtCol Jer/ Eberhard, CO-Wing, Thompson Valley CS., Ft Collins, CO
CELL/VM: 970 231-6325
EMAIL: jer'at'frii.com WEB: http://users.frii.com/jer/
C-206 N9513G, CFII Airplane&Glider FAA-DEN Aviation Safety Counselor
CAP-CO Mission&Aircraft CheckPilot BM218 HAM N0FZD 247 Young Eagles!
FOR ALL SAFETY AND HUMAN LIFE CRITICAL FUNCTIONS IN THE,UNITED STATESGOVERNMENT BiffClinton Piloting 2 May 4th 07 01:41 AM
GNS430 Without the IAF Jerry Instrument Flight Rules 25 February 23rd 06 12:48 PM
GNS430 on the Airway [email protected] Instrument Flight Rules 66 February 16th 06 04:59 AM
question on glide ratio functions in Garmin 96, 96C, 196 GPS Steve S Soaring 1 January 10th 06 07:43 PM
GNS430 vs 480 vs 530 pgbnh Owning 12 August 25th 05 07:04 PM
