Low performance climbs
Old May 17th 07, 04:40 AM posted to rec.aviation.piloting
kevmor
Default Low performance climbs
When flying a plane that doesn't have a lot of climbing power, is it
quicker to get to your destination if you climb at a slower rate, but
faster speed? Or is it quicker if you climb faster to your altitude?
For example, say I took off at sea level and want to cruise at 6,500.
I don't need to be that high for terrain clearance for some time. In
a fixed pitch plane, I could climb at Vy to get to the altitude using
full throttle, but this gives lesser engine cooling. If I climb at a
speed greater than Vy, I'll need to reduce the throttle more (fixed
pitch) to keep RPMs in range. When I do this, it seems like it'll
take forever to get to the altitude, however.
Old May 17th 07, 11:31 AM posted to rec.aviation.piloting
kontiki
Depends on the winds at any given altitude.
In the smaller fixed pitch AC you want to climb at full throttle.
After arriving at or above pattern altitude it is normal to push
the nose over a bit to increase airspeed to cruise climb.
Step climbs Mxsmanic Piloting 56 March 2nd 07 05:17 PM
ASW 19b performance Jim Crowhurst Soaring 1 July 8th 05 01:31 PM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
Climbs, Descents, and Approaches pdxflyer Aviation Marketplace 0 March 7th 04 01:37 AM
Climbs and Descents pdxflyer Piloting 0 March 1st 04 07:17 AM
