River retrieve
Old May 23rd 07, 06:51 PM posted to rec.aviation.soaring
Dan G
Default River retrieve
On May 23, 6:04 pm, Bob Kuykendall wrote:
Earlier, "Brian Glick" wrote:
The foam gets water logged...
Quite, quite unlikely.
The foam used in sandwich core composite construction is closed-cell
foam that does not admit water beyond the first layer of cells. And
even that layer is sealed by the sandwich skin so that very little if
any core foam is exposed.
History suggests that the majority of such water landings in composite
ships resulted in floating gliders.
GRP sinks like a stone if the airspaces flood. I'm not sure how much
of a wing is actually filled with foam, but certainly fuselages are
just big empty tubes. If water starts coming in through control rod
openings, any gaps around the undercarriage etc. you're going down.
Fast. I think it depends on the glider how long they float - K21s sink
very quickly, flooding through the main wheel well. On the other hand
I've heard that in Finland lake landings aren't uncommon, as in large
areas lakes are the only places without trees for miles around!
The truth is out there....
Dan
Old May 26th 07, 05:35 AM posted to rec.aviation.soaring
Mike Schumann
A lake landing in Finland sounds cold!
Mike Schumann
"Dan G" wrote in message
Dan
Posted via a free Usenet account from http://www.teranews.com
River retrieve Bob Kuykendall Soaring 0 May 23rd 07 06:04 PM
River retrieve Frank Whiteley Soaring 9 May 23rd 07 02:45 PM
Little River Airport, CA Robert M. Gary Piloting 2 March 21st 07 10:35 PM
Military plans to retrieve Navy pilot killed in 1944 Otis Willie Naval Aviation 0 March 20th 06 11:38 PM
