OT - the OT tag and the Re bug.
Old May 27th 07, 01:00 AM posted to rec.aviation.piloting
Jose
Default OT - the OT tag and the Re bug.
I first identified this problem in the sim group, but it happens here
too. I'm sure it happens everywhere, but since I live here, this is
where I'm concerned.
The subject line of a reply universally has the letters "r" "e" and a
colon in front. The software does this automatically. But to avoid an
infinite regress ("...") the software also senses a
pre-existing "" and eats it first. Most software is good at that.
Some isn't.
Seems one common bug is to simply eat everything in front of the colon.
(I presume the first colon) before prepending the "". This has an
unfortunate side effect for those who follow a prepend (such as "OT" or
"POL") with a colon. The prepend gets eaten, and replaced with "",
and newsreaders who sort by subject have that chain of responses mixed
in with their on-topic subjects, negating the effect of the prepend in
the first place. The reply is still of the same thread (defined by the
message ID) as the original "OT:" post, but sorting by threads doesn't
work well, especially when only unread posts are desired.
An example of this can be seen in the "OT: Electric cars?" thread.
A solution is for posters to =not= follow a prepend with a colon. Use a
dash, or nothing at all, and this won't happen.
Just a thought.
Jose
There are two kinds of people in the world. Those that just want to
know what button to push, and those that want to know what happens when
they push the button.
Old May 27th 07, 01:44 AM posted to rec.aviation.piloting
Jim Logajan
Some isn't.
The following newsreaders used for replies in the "OT: Electric cars"
thread "do the right thing":
Xnews, KNode, Trn, Forte
The following newsreader used for replies in that thread "do the wrong
thing":
MS Outlook Express
Another MS blunder.
Old May 27th 07, 03:27 PM posted to rec.aviation.piloting
Andrew Gideon
Pan and whatever I've used previously. I've never heard of this "common
bug". And I've been USENETing since the early 80s or so. I've also
long used a string followed by a colon in the subject line in various
situations (ie. "Q:") and never perceived a problem.
thing":
MS Outlook Express
Another MS blunder.
Ah. Dog Bites Man.
BTW, whats' wrong with displayed threading by threads instead of subject?
The latter can display messages in an invalid order (with "order" being
the partial ordering based upon the relationship reply-response); that
doesn't occur when "In-reply-to" or "References" are used.
- Andrew
Old May 27th 07, 05:21 PM posted to rec.aviation.piloting
Jose
I've also long used a string followed
The problem would be percieved by others.
Nothing, but there's something wrong with having to. Sorting gets
screwed up in some readers when one must sort by threads if one is only
viewing unread messages.
Jose
Old May 28th 07, 12:19 AM posted to rec.aviation.piloting
Neil Gould
Default OT - OT: (was: the OT tag and the Re bug.)
Recently, Jim Logajan posted:
thing":
MS Outlook Express
Interesting. How did you arrive at that?
Another MS blunder.
Perhaps so. But not nearly the blunder that exists in "MSMail", the Vista
replacement for OE.
Neil
Old May 28th 07, 12:26 AM posted to rec.aviation.piloting
Martin X. Moleski, SJ
On Sun, 27 May 2007 23:19:46 GMT, "Neil Gould" wrote in
thing":
MS Outlook Express
I'll bet he read the headers for the replies in the thread.
You sent your post with:
X-Newsreader: Microsoft Outlook Express 6.00.2800.1409
If you look in the headers for this post, you will probably
be able to find out what newsreader I'm using.
Marty
Big-8 newsgroups: humanities.*, misc.*, news.*, rec.*, sci.*, soc.*, talk.*
See http://www.big-8.org for info on how to add or remove newsgroups.
Old May 28th 07, 02:56 AM posted to rec.aviation.piloting
Andrew Gideon
On Sun, 27 May 2007 16:21:15 +0000, Jose wrote:
I've also long used a string followed by a colon in the subject line in
various situations (ie. "Q:") and never perceived a problem.
It would be perceived by me if anyone had replied to such a message, if I
followed the "bug" explanation correctly. More, USENET being what it is,
someone would have complained about it in the years I've been doing this.
subject?
Why? What's wrong with something being required to be done "the right
way" for that something to work properly?
Sorting gets screwed
up in some readers when one must sort by threads if one is only viewing
unread messages.
How? I see no such artifact of "screwed up" sorting, and I've been
sorting by thread for quite a while.
- Andrew
Old May 28th 07, 03:18 AM posted to rec.aviation.piloting
Jose
Go back to the thread I referenced, view all messages, sort by subject
line. Do you see one set of messages without the OT(colon) prepend and
another set with, probably sorted in different places in the alphabet?
More, USENET being what it is, someone would have complained
Ummmm... so?
Yanno, I don't have a problem with lines longer than 70 characters. My
newsreader wraps them for me. Why should I wrap my lines for other people?
Jose
Old May 28th 07, 05:16 AM posted to rec.aviation.piloting
Jim Logajan
That is indeed what I did.
Old May 28th 07, 12:09 PM posted to rec.aviation.piloting
Neil Gould
I was asking how you arrived at the conclusion that Outlook Express was
one of the apps that "did the wrong thing". As you can tell from the
headers, I'm using OE. Notice that I also modified the subject to include
a couple more colons, which, as you can see, were posted correctly. So...
how was it that you concluded that OE "did the wrong thing"?
Neil
