LCA goes supersonic
Old August 1st 03, 10:38 PM
Thomas J. Paladino Jr.
Default LCA goes supersonic
"Tuollaf43" wrote in message
om...
India's home built fighter aircraft went supersonic today for the first
time.
http://www.hinduonnet.com/stories/2003080205100100.htm
Thats a good achievement for them.
But, their wing commander should probably brush up on his aviation history:
"Later, Wg. Cdr. Vikram Singh stated that the maximum speed achieved by any
aircraft piloted by a human being was Mach 3, that is, three times the speed
of sound. An aircraft moving at Mach 1, which is the speed of sound, will
cover about 334 metres a second."
Which, to clarify, is not actually true. The SR-71 was capable of just over
Mach 3, and the X-15 got close to Mach 7. Technically, the space shuttle is
also an aircraft when it re-enters the atmosphere, and it does that at Mach
25 (though calling the space shuttle an aircraft is splitting hairs).
Old August 2nd 03, 01:08 AM
enlight
Tuollaf43 wrote:
India's home built fighter aircraft went supersonic today for the first time.
There is an interesting and picture rich article about the Indian LCA to
be found here.
http://almavijai.sphosting.com/India...ce/Air/LCA.htm
Take a look - It's well worth a read.
enlight
Old August 4th 03, 02:51 AM
The Enlightenment
"Thomas J. Paladino Jr." wrote in message
om...
time.
history:
any
speed
over
Mach 3,
Mach 3.6 which were reached in actual operations when outrunning a SAM.
Speed was limited by the shock wave cone moving back and impinging on the
engine inlets not engine power or thermal limitations.
Old August 4th 03, 06:14 AM
Mary Shafer
On Mon, 04 Aug 2003 00:51:26 GMT, "The Enlightenment"
Nope. 3.5 dash on a flight test. No SAM ever got that close.
Not so. Above Mach 3.5 you get shock impingement on the leading edge
of the wing, which is why you can only do it in a dash. And you'll
exceed the CIT limit, which is, usually, reached at Mach 3.23.
Mary
Mary Shafer Retired aerospace research engineer
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 07:19 PM
