Ground control vs. clearance delivery for VFR
Old June 16th 07, 01:59 PM posted to rec.aviation.piloting
B A R R Y
Default Ground control vs. clearance delivery for VFR
My local Delta base (HFD) will contact nearby BDL TRACON and obtain a
squawk code for VFR flight following or traffic advisories. This
service is "advertised" on the ATIS and is requested from ground
control on initial call up by departures. Ground calls you back with
a code and the proper departure frequency, similar to an IFR
clearance.
Last week, I was at a Charlie airport (PVD) during a very quiet
period. Upon calling ground with the usual VFR information, I also
requested a VFR flight following to my destination. This was the
first time I'd tried this outside of HFD. The controller mumbled
something unintellible, along with "since it's slow", and to stand by.
He honored my request and returned with my code and the current
departure frequency. My flight following commenced automatically as I
was handed off to that area's TRACON from the tower.
Should I have asked for this service via the clearance delivery
frequency as in IFR, or was I asking for a service not normally
available? I can't find the answer in the 2007 Jeppesen FAR-AIM.
In hindsight, I'm guessing I should have been on clearance delivery.
Old June 16th 07, 02:04 PM posted to rec.aviation.piloting
Kevin Clarke
squawk code for VFR flight following ...
I think you are supposed to call the clnc del for that at a charlie.
That has always been my experience at PVD as well. I tried w/ ground
before too and got the aeronautical equivalent of the finger. :-)
Come to think of it, I've had the same experience at BDL also. So yeah,
in my experience, clnc del is the way to go for VFR departure.
KC
Old June 16th 07, 02:09 PM posted to rec.aviation.piloting
B A R R Y
On Sat, 16 Jun 2007 13:04:49 GMT, Kevin Clarke
Thanks!
Even if I got the "radio finger", he did the extra work to honor my
request. G
Old June 16th 07, 02:19 PM posted to rec.aviation.piloting
Jay B
Contacting clerance delivery first is also the norm at Tucson, AZ
(Class C).
Jay Beckman
PP-ASEL
Chandler, AZ
www.pbase.com/flyingphotog
Old June 16th 07, 02:35 PM posted to rec.aviation.piloting
Larry Dighera
On Sat, 16 Jun 2007 12:59:45 GMT, B A R R Y
wrote in
clearance.
All VFR flights departing KSNA (a Class C airport) receive radar
advisories/flight following unless they indicate that it is not
desired by appending the word 'local' to the departure name they
request:
When departing Santa Ana/Orange County/John Wayne (KSNA) (Class
Charlie airspace) VFR it is customary to add the word 'LOCAL' to your
departure clearance request with Clearance Delivery to signify that
Radar Advisory Service (Flight Following) is not desired. IE:
"Cherokee 1234A is a PA28A/A at executive hangars east with
Oscar, request Mesa Local departure."
VFR departures and arrivals are published in the John Wayne-Orange
County Airport FIXED-WING CLASS-C VFR PROCEDURES manual by the John
Wayne tower Pilot/Controller Work Group, copies of which may be
obtained from the tower by telephone request.
That document contains the following information:
Requesting Class-C Departure Instructions From Clearance
Delivery - 121.85
Contact Clearance Delivery _prior_ to taxi. Include your
position on the airport in addition to the following
information as appropriate.
_Surface area service only:_ include type aircraft and
direction of flight or route name. _Example:_ JOHN WAYNE
CLEARANCE, CESSNA 12345, C172 (DIRECTION OF FLIGHT OR,
MESA/NEWPORT/ORANGE) LOCAL.
_Note:_ The term "LOCAL" advises the controller that surface
area service only is requested, Radar service will be
terminated at the boundary of the Class-C surface area.
*Remain outside Class-C airspace thereafter.* This should not
be confused with a local area flight in which the pilot
desires flight following with Socal Approach. In that case,
advise the clearance delivery controller of your specific
request as indicates below.
_For radar service/flight-following beyond the surface area:_
include destination of intentions and departure route name
(optional_:
_Example:_ JOHN WAYNE CLEARANCE, BARON 54321, BE58
DESTINATION (FAN NUYS/SOUTHWEST PRACTICE AREA/SENIC FLIGHT
SOUTHEAST ALONG SHORELINE/ETC.) REQUEST MESA/NEWPORT DEPARTURE
(OPTIONAL)
_Note 1:_ The pilot may request the desired route by name
(Newport, Mesa, etc.) if known. Of primary concern to the
tower is the destination/intentions. The controller will
assign the most appropriate initial heading, and forward the
destination/intentions to Socal Approach.
_Note 2: _ Avoid the use of the term 'LOCAL' which indicates
surface area service only, as described above.
Old June 16th 07, 02:57 PM posted to rec.aviation.piloting
Steven P. McNicoll
"B A R R Y" wrote in message
clearance.
Since it was slow, the same person was probably working ground control and
clearance delivery, so it wouldn't matter which you called.
The service you requested doesn't exist on a national basis.
Old June 16th 07, 03:45 PM posted to rec.aviation.piloting
Andrew Sarangan
clearance.
Clearence delivery is not just for IFR. See AIM 4-3-14. If they are
not busy, they might combine CD and Ground, but the controllers decide
that, not the pilot. Sometimes I have had one controller operate
approach, tower, ground and clearance. Separate frequencies, but it
was the same person.
Old June 16th 07, 04:19 PM posted to rec.aviation.piloting
Roy Smith
clearance.
The general rule is that anything that involves generating a flight strip
(IFR clearance or VFR flight following) should go through CD. Only if an
airport has no published CD freq (or if the ATIS says you should) that you
should ask the ground controller for this.
Old June 16th 07, 04:38 PM posted to rec.aviation.piloting
Mxsmanic
Roy Smith writes:
Does a VFR departure through Class B or C generate a flight strip?
Old June 16th 07, 05:38 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
Roy Smith writes:
strip (IFR clearance or VFR flight following) should go through CD.
Only if an airport has no published CD freq (or if the ATIS says you
should) that you should ask the ground controller for this.
Your fjukktardedness is boundless.
In any case, it doesn't matter. You will never fly.
Not VFR, not ifr. Not through class B, not through class C. Not on a
plane, nor on a train, not here nor there or anywhere
Bertie
AFSS Clearance Delivery Stan Prevost Instrument Flight Rules 2 January 4th 05 04:43 PM
clearance delivery question PaulH Instrument Flight Rules 13 November 19th 04 09:19 PM
Ground speed control Roger Long Piloting 2 July 7th 04 10:13 PM
Pop-up IFR from Clearance Delivery Andrew Sarangan Instrument Flight Rules 43 March 28th 04 07:20 PM
AFSS clearance delivery Dan Luke Instrument Flight Rules 7 February 9th 04 12:56 AM
