Would you do it?
Old June 19th 07, 11:21 PM posted to rec.aviation.owning
Dan Luke
Default Would you do it?
http://tinyurl.com/3dy4ot
As a new turbo owner, I'm leary of fixing what ain't broken.
Would you get the timing bumped 3 degrees if it were yours?
Dan
T-182T at BFM
Old June 19th 07, 11:23 PM posted to rec.aviation.owning
Dan Luke
Not Timothy...
"leery"
Old June 20th 07, 12:50 AM posted to rec.aviation.owning
Peter R.
I am a sucker for the words, "a slight increase in engine performance..." so
yes, I would.
In the hands of a competent mechanic I don't see the task of changing engine
timing as being risky, but then again I could be a fool.
Peter
Old June 20th 07, 02:13 PM posted to rec.aviation.owning
Matt Barrow[_4_]
"Dan Luke" wrote in message
Is the engine still under warranty?
Have you inquired, just for giggles, what Lycoming would have to say?
Old June 20th 07, 03:06 PM posted to rec.aviation.owning
El Maximo
"Matt Barrow" wrote in message
The link points to a Lycoming Service Instruction pdf.
Old June 20th 07, 06:01 PM posted to rec.aviation.owning
Matt Barrow[_4_]
"El Maximo" wrote in message
Missed that in all the blue text.
Thanks
Old June 21st 07, 12:48 AM posted to rec.aviation.owning
Blueskies
"Dan Luke" wrote in message ...
Dan
T-182T at BFM
Yes...did you check the data plate, maybe already done?
Old June 21st 07, 02:02 AM posted to rec.aviation.owning
Dan Luke
Nope. Will do Saturday.
Dan
T-182T at BFM
