DG300 horizontal stab. bolt saftey wire
Old June 25th 07, 05:14 PM posted to rec.aviation.soaring
Default DG300 horizontal stab. bolt saftey wire
The Horizontal Stab. is held in position by a captive bolt that is
prevented from backing out by a spring steel wire that slides through
a slot in that bolt. Mine just broke. Does anyone have experiance with
that little wire and it's replacement?
Old June 26th 07, 02:45 AM posted to rec.aviation.soaring
JJ Sinclair
I drilled a 1/32" hole in a new location and then shoved a short
length of bent music wire in the new hole so that it contacted one of
the bolt head slots. Kept it in place with tape over the wire and
bolt head. Its just a safety..... a properly tightened bolt isn't
going to come loose in one flight.
Worked for me,
JJ
Old June 26th 07, 03:35 PM posted to rec.aviation.soaring
Bob Kuykendall
length of bent music wire in the new hole...
Weren't you supposed to scarf that in at 400:1?
For Sale: 1-34 horizontal stab/elevator Mitch Deutsch Soaring 0 November 12th 06 03:46 PM
DG300 Tail weight John Schaffer Soaring 3 September 12th 06 09:36 AM
Horizontal Stab. rusted on stubs Michael Horowitz Restoration 5 April 8th 06 03:50 PM
Saftey Pilot Richard Ross Instrument Flight Rules 7 March 22nd 06 11:35 PM
Saftey of exposed wheel at 41,000 feet stephen Owning 32 December 12th 03 01:35 AM
