RAE42SNB42
Old July 7th 07, 12:01 AM posted to rec.aviation.piloting
Dallas
Default RAE42SNB42
Why does the FAA persist in using a coded system for printed weather
reports and forecasts?
They act like kilobytes are expensive to transmit today... The last time I
saw a teletype machine was in 1974.
And the codes aren't even consistent, M for minus degrees in a METAR and -
for minus degrees in a PIREP. Am I wrong in thinking this old system is
confusing and therefore unsafe?
Dallas
Old July 7th 07, 12:29 AM posted to rec.aviation.piloting
B A R R Y
Default RAE42SNB42
On Fri, 06 Jul 2007 23:01:09 GMT, Dallas
Your subject line is an easy one, and I get plain English DUATS
briefings. G
FWIW, there's cheapie whiz wheels and cheat sheets available for
checking the less common abbreviations.
Old July 7th 07, 12:33 AM posted to rec.aviation.piloting
Dan Luke[_2_]
Default RAE42SNB42
You're asking for a rational explanation for something the FAA does?
You might as well ask why Donald Duck doesn't wear pants.
Dan
"Don't make me nervous when I'm carryin' a baseball bat."
- Big Joe Turner
Old July 7th 07, 12:53 AM posted to rec.aviation.piloting
Jim Logajan
Default RAE42SNB42
Snow forecast in July in the U.S.?
Or did I decode that wrong?
Old July 7th 07, 01:05 AM posted to rec.aviation.piloting
Default RAE42SNB42
Because it's an international standard and all the stuff is in place
to handle it.
Use DUAT or DUATS if you want plain English.
Jim Pennino
Remove .spam.sux to reply.
Old July 7th 07, 01:52 AM posted to rec.aviation.piloting
Peter R.
Default RAE42SNB42
Yes, you did decode that wrong. That is not from a forecast.
Peter
Old July 7th 07, 01:56 AM posted to rec.aviation.piloting
Peter R.
Default RAE42SNB42
In my experience the more you use it, the easier it is to read. In DUATs I
choose the option to decode the briefing into plain English but I only read
the English version for the area forecast and NOTAMs. I actually find it much
faster to read the METARs and TAFs in their coded format.
Peter
Old July 7th 07, 02:37 AM posted to rec.aviation.piloting
Bob Gardner
Default RAE42SNB42
One more time...it is ICAO that dictates these things, not the FAA. The FAA
just conforms to ICAO standards.
Bob Gardner
"Dallas" wrote in message
I
Dallas
Old July 7th 07, 02:38 AM posted to rec.aviation.piloting
Bob Gardner
Default RAE42SNB42
Looks like "rain ended at 42, snow began at 42." What is the problem?
Bob Gardner
I
Dallas
