Sticky Dipstick -- PA28
Old July 7th 07, 01:55 AM posted to rec.aviation.owning
Don Tuite
Default Sticky Dipstick -- PA28
As MO, I've taken to warning club members not to tighten the dipsstick
on the '74 Challenger even slightly. Even a little extra torque makes
it very difficult to unscrew. Last week somebody torqued the entire
plastic tube off the engine just loosening the dipstick.
Something's goofy. What?
Don
Old July 7th 07, 03:41 AM posted to rec.aviation.owning
Drew Dalgleish
On Fri, 06 Jul 2007 17:55:58 -0700, Don Tuite
Don
Probably the o-ring at the top is worn to the point that it gets
caught in the threads instead of just sitting on the flat top. BTW on
my engine there's a safety wire at the bottom of the dipstick tube so
that it can;'t unscrew.
Old July 7th 07, 04:29 AM posted to rec.aviation.owning
El Maximo
"Don Tuite" wrote in message
Don
On the Cherokee I fly, it is not possible for the dipstick to come out when
the cowl is closed. As long as the cowl is closed during flight, I don't
worry about the dipstick. I just snug it against the o-ring when I check the
oil.
Old July 8th 07, 02:34 AM posted to rec.aviation.owning
Paul kgyy
On Jul 6, 7:55 pm, Don Tuite
I have an Arrow with the IO360, and the vibration pattern of the
engine tends to tighten the dipstick rather than loosen it. So I just
turn until I start to feel resistance and let it be. At the end of
the flight it's always just about right. When I have the oil changed
I always find it over-tightened by the shop.
If you have a club machine, put something in the walk-around checklist
about "just snug, not tight".
Sticky DG and DME distance question A Lieberman Owning 17 July 11th 05 01:32 AM
sticky valve or Dick Home Built 18 May 25th 05 07:50 PM
sticky valve or Dick Owning 18 May 25th 05 07:50 PM
Sticky Altimeter Kyle Boatright Home Built 2 April 18th 05 03:14 AM
Corrosion on oil dipstick. Bad? Ben Jackson Owning 4 March 10th 04 07:12 AM
