Learning to fly
Old July 7th 07, 08:11 PM posted to rec.aviation.piloting,uk.rec.aviation,rec.aviation.soaring
Larry Dighera
Default Learning to fly
On Sat, 7 Jul 2007 17:23:32 +0100, "GB"
wrote in :
40 years or so ago, I learned to fly, at least a bit. I did some solo
circuits in gliders. I would like to come back to flying, and I was
wondering about whether to learn on powered or unpowered planes?
The answer to that question depends on what sort of flying you want to
do once you have your airmans certificate, and how much you can afford
to spend on flying. Glider instruction can be very inexpensive if you
join a soaring club, and you will get some fundamental experience in
aerodynamics and meteorology that powered flyers only get a smattering
of. However, you will be mostly limited to summer days, and costs
will be about as low as possible.
Powered flight is less of a sport, and can be useful for air touring,
but the cost of flight instruction and aircraft operation is
significantly more that soaring.
If I learn on gliders, will this be any help towards getting a PPL?
It should make your transition to powered flight significantly easier,
if that's what you meant. Actually there are several private pilot
licenses: Single Engine Land and sea, Multiengine, Glider, Lighter
Than Air, ...
I apprecaite that it's all good experience, but I have a feeling that the PPL
only counts hours in a powered plane. Is that right?
A Private Glider certificate requires instruction in gliders.
Also, any recommendations for places to learn to fly, powered or unpowered,
near North London?
I'll cross post this follow up article to the uk.rec.aviation and
rec.aviation.soaring newsgroups, and you should receive some replies
from knowledgeable folks in that location.
Finally, I am very overweight (over 18 stone). Does that rule out gliders
unless I lose quite a bit of weight?
I'll leave that question to the airmen in rec.aviation.soaring.
Thanks very much.
You may want to consider inquiring at one of the soaring advocacy
groups like the Soaring Society of America; you'll find a lot of good
information on their web site: http://www.ssa.org/ . I can also
recommend the Aircraft Owners and Pilots Association web site for more
power oriented information: http://www.aopa.org/ . Unfortunately, I
unable to provide information for the similar European organizations.
Learning to fly GB Piloting 19 July 17th 07 09:40 AM
Question about Learning to fly? Dwayne Smith Piloting 11 November 27th 05 03:51 PM
Learning to fly... JohnWN in Burke, VA Soaring 7 October 25th 04 01:09 PM
Learning To Fly? John General Aviation 2 June 20th 04 01:53 PM
Re-learning IFR Jim Instrument Flight Rules 9 November 25th 03 07:38 PM
