P-51 question.
Old August 21st 03, 02:07 AM
Mortimer Schnerd, RN
Default P-51 question.
JStONGE123 wrote:
Why was the P-51 not used on aircraft carriers during WWII? Beside
the obvious no tail hook.....ect.
No tail hook. No extra heavy duty landing gear for carrier "landings". No
folding wing. No need.... the F6F was quite capable in its place.
http://www.mortimerschnerd.com
Old August 21st 03, 02:16 AM
And no round engine. Lots of good reasons why the USN preferred
air-cooled over liquid-cooled engines.
-Mike Marron
Old August 21st 03, 02:36 AM
Peter Stickney
"Mortimer Schnerd, RN" writes:
A liquid cooled engine, with all the plumbing and coolant requirments
that that entails. Wasn't it Admiral Apollo Souchek, or his brother
Zeus, who stated that "Putting a water-cooled engine on a carrier
aircraft is like putting an air-cooled engine in a submarine."
It should be noted that a P-51D was, in fact, fitted with a tailhook,
and did successfully complete a series of traps & takeoffs from a
carrier at sea, late in the war. North Americal also did the same
with a PBJ (Marine Corps B-25)
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old August 21st 03, 03:42 AM
MLenoch
Stick and rudder wise.........the F6F was far easier to fly than the P-51.
After having flown one, you could easily see why the Hellcat was an ACE maker,
even if you were an Ensign!!
VL
Old August 21st 03, 08:24 AM
Guy Alcala
JStONGE123 wrote:
Why was the P-51 not used on aircraft carriers during WWII? Beside the obvious
From "Duels in the Sky," by Eric Brown:
"Landing the Mustang required concentration, for at an approach speed of 105 mph
the view was bad, and high-rebound-ratio landing gear made a three-point landing
tricky. This state of affairs was exacerbated by the aircraft's lack of
directional stability on the landing run. The U.S. Navy abandoned the Mustang's
deck-landing trials on an aircraft carrier for this reason."
BTW, all USAAF fighters were fitted with catapult spools for at least a while in
the late war years, to allow them to be delivered to bases by flying them off
escort carriers, instead of having to crane them off.
Guy
Old August 21st 03, 03:07 PM
Dudley Henriques
"Guy Alcala" wrote in message
obvious
105 mph
landing
Mustang's
while in
off
Hi Guy;
HiGuy;
I would agree with Brown, but with a serious caveat !!!! 105 would be the
absolute minimum I'd use, and even that would be at the extreme low end of
the GW range for the airplane, say about 8000 lbs, which is real low for a
combat loaded Stang. At 12000lbs that final approach airspeed has to go up
to somewhere around 135mph or you're courting disaster in a Mustang.
About his comment on rollout, I personally consider the 51 to be just about
the best tailwheel fighter on rollout I've ever flown. It tracks straight as
an arrow. About the visibility problem; at full flaps, it's not all that
bad, but he's right about slowing it down. The more you slow it down on
final, the less you see. At 105, you wouldn't see much !!! :-)))
I agree with Brown generally though. The 51 is NOT the airplane to put on
the boat!!
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/CFI
Retired
Old August 21st 03, 03:16 PM
OXMORON1
obvious
Missed most of this thread, BUT the USN had decided to go with aircooled rather
than liquid cooled engines for various reasons.
Oxmoron1
MFE
Old August 22nd 03, 02:09 AM
At what point did the USN decide they preferred twin-engined a/c?
What's the evolution of that philosophy? Did it come out of the
sometimes questionable reliability of early turbine powerplants? Before
the advent of jets, was there ever any similar preference expressed for
piston twins?
Good questions. The RCAF seems to prefer twin-engined fighters too.
Anyone?
-Mike Marron
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
