FSX Crashing /freezing !
Old July 19th 07, 12:24 AM posted to rec.aviation.simulators
Kekke
Default FSX Crashing /freezing !
Howdy guys'n girls. I have a problem here
My FSX Freezes randomly, sometimes in seconds after the graphics start
rolling...
Sometimes i can enjoy flying 1 hour or so...but it eventually
freezes/crashes
After the crash i have to alt tab to windows and kill the process from
taskmanager.
after that i cant start fsx anymore before reboot, if i do so, it will
try to start, after it has allocated 50megs off ram, the process stops
using any cpu resources and hangs there.
I have clean installed xp with all updates / Sp2 / DirectX / newest
forceware
FSX is clean installed and updated to sp1 + c++ redist sp1
Note that the exactly same freeze/crash happens also when i tried this
with clean installed 64bit xp. with all the updates and ....yada yada....
I have tried to run the game in different scenery settings, with and
without AA, i have tried every combination that i can figure. also tried
it in windowed mode...
have run dxdiag, everything passes, all ok according to that.
Have tried to lower my direct sound accel.....no use.
I dont have any heat issues what so ever with my comp. i have 500w
purepower feeding the juice...
No overclocking done what so ever.
I have installed other games like Oblivion, Wow, HL2, BF2 and played
these for hours with extreme settings they work well and fast, no
crashing, not a single one.
my comp is as follows......----------
Processor
Model: Intel® Core™2 CPU 6600 @
2.40GHz
Speed: 2.40GHz
Performance Rating: PR8160 (estimated)
Cores per Processor: 2 Unit(s)
Threads per Co 1 Unit(s)
Type: Dual-Core
Internal Data Cache: 2x 32kB Synchronous, Write-Thru, 8-way set,
64 byte line size
L2 On-board Cache: 4MB ECC Synchronous, ATC, 16-way set, 64 byte
line size, 2 threads sharing
L3 On-board Cache: 2x 4MB Synchronous, Write-Back, 16-way set,
64 byte line size
Mainboard
Bus(es): PCI PCIe USB
MP Support: 1 Processor(s)
MP APIC: No
System BIOS: Award Software International, Inc. 255.255
System: Gigabyte Technology Co., Ltd. P35-DS3P
Mainboard: Gigabyte Technology Co., Ltd. P35-DS3P
Total Memory: 2.7GB
Chipset 1
Model: Giga-Byte Technology P35 (29C0)
Front Side Bus Speed: 4x 267MHz (1068MHz data rate)
Video System
Monitor/Panel: Plug and Play Monitor
Adapter: NVIDIA GeForce 7950 GX2
Physical Storage Devices
Removable Drive: Floppy disk drive
Hard Disk: ST3320620AS (298GB)
Hard Disk: DELL Array SCSI Disk Device (466GB)
Hard Disk: BUFFALO USB Flash Disk USB Device
CD-ROM/DVD: LITE-ON DVDRW SOHW-1673S (CD 126X Rd, 126X
Wr) (DVD 16X Rd, 16X Wr)
SB X-Fi Audio [C000]
General Information
Device Name: SB X-Fi Audio [C000]
Manufacturer: Microsoft
Version: 5.10
Product ID: 101 / 1
Operating System(s)
Windows System: Microsoft Windows XP/2002 Professional
5.01.2600 (Service Pack 2)
System
Manufacturer: Gigabyte Technology Co., Ltd.
Model: P35-DS3P
System Chassis
Type: Desktop
Can be locked: No
Mainboard
MPS Version: 1.40
Model: P35-DS3P
System BIOS: 05/11/2007-P35-ICH9-6A79OG0HC-00
Primary Display Driver (display)
Video Adapter
Model: NVIDIA GeForce 7950 GX2
Chipset: GeForce 7950 GX2
RAMDAC: Integrated RAMDAC
Video BIOS: Version 5.71.22.24.08
VGA Compatible: No
Total Memory: 512MB (505MB Video)
Texture Memory: 689MB
Video BIOS
Date of Manufactu 14. huhtikuuta 2006
Version: 5.71.22.24.07
Current Video Mode
Mode: 1920x1200 16M+ TrueColour (32-bit)
Current Refresh Rate: 60Hz
Virtual Desktop Size: 1920x1200
Video Driver
Model: nv4_mini.sys
Version: 6.14.10.9424
Expected Windows Version: 4.00
Video Acceleration: Yes
Screen Saver Active: No
Low Power Saving Active: 20 minutes(s)
Power Off Saving Active: 20 minutes(s)
PnP/DDC Monitor Data
Manufacturer: Samsung
Serial Number: xxxxxxx
Date of Manufactu 26. helmikuuta 2006
Type: RGB colour
CRT/Panel Size: 24 inch
Horizontal/Vertical CRT/Panel :520 mm / 320 mm
Gamma Factor: 2.60
DPMS Modes Supported: Off
EDID Version: 1.03
If Any of you know how to solve this, i'm more than gratefull.
As said, other programs / games work fast and flawlessly.
Any suggestions are welcome too, i have fought so long with this that i
may miss something obvious.
Thx alot in advance.
Kekke
Finland
Old July 19th 07, 09:54 AM posted to rec.aviation.simulators
zx[_2_]
Hello,
Not easy,
The SP1 FSX boost effectly FSX, but it is not
realy stable, i need to reinstall 2 time my one.
Do you activate specficic dual core option experiment into FSX SP1 ?
that is absolutly not stable in FSX.
Randomize freze memory error, may be, look
nvidia driver update with your 7950 GX2 series
when specfic graphic action is asked.
I have 8800 GTX nvidia with Directx 10, i have no more problem, after
update driver.
Try to test with all setting graphic to low, just for see.
if no crash, up the setting step by step.
Regards
"Kekke" a écrit dans le message de
rolling...
freezes/crashes
taskmanager.
after that i cant start fsx anymore before reboot, if i do so, it will try
to start, after it has allocated 50megs off ram, the process stops using
forceware
I have installed other games like Oblivion, Wow, HL2, BF2 and played these
for hours with extreme settings they work well and fast, no crashing, not
a single one.
Processor
2.40GHz
Speed: 2.40GHz
Type: Dual-Core
64 byte line size
64 byte line size
Mainboard
MP APIC: No
Total Memory: 2.7GB
Chipset 1
Video System
General Information
Version: 5.10
Product ID: 101 / 1
Operating System(s)
System
Model: P35-DS3P
System Chassis
Type: Desktop
Can be locked: No
Mainboard
MPS Version: 1.40
Model: P35-DS3P
Video Adapter
VGA Compatible: No
Video BIOS
Current Video Mode
Video Driver
Model: nv4_mini.sys
Type: RGB colour
Gamma Factor: 2.60
EDID Version: 1.03
Kekke
Finland
Crashing on takeoff... how odd [email protected] Piloting 165 August 31st 06 04:30 AM
Planes that are afraid of crashing? Jim Fisher Piloting 20 May 27th 05 02:20 AM
GPS_LOG freezing and freezing cernauta Soaring 4 May 8th 05 06:39 PM
Motorgliders burning after crashing? stephanevdv Soaring 0 January 20th 05 03:23 PM
Crashing a '12 Mark Grubb Soaring 14 November 7th 04 03:32 PM
