B-70 Paint scheme
Old September 1st 03, 05:08 PM
TWINMAKER
Default B-70 Paint scheme
Here is a good "what if" question. If the B-70 had gone into widespread SAC
use in the 60s and beyond, what is the best guess as to how it would have been
painted for operational use? Black like the SR, white like the two XB models,
gray, etc? I doubt it would have had the SAC cammo scheme, since it would not
have done any low level flying.
W. Woodruff
Old September 2nd 03, 07:49 PM
B2431
The TBC (Toss Bomb Computer) settings for the weapon, airspeed,
altitude, etc. included calculation for safe separation from the
blast. When the aircraft were painted in camo for the SEA war, the
entire nuclear delivery manual had to be re-calculated, because the
dark paint absorbed the flash much more than the reflective bare
metal. Greater safe separation distance was required.
Frankly that scared the hell out of me. Hard to realize the whole
business was calculated to such close tolerances.
Ed Rasimus
How much more distance did you need with the camo paint scheme?
I remember watching F-4s heave practice bombs in Spain simulating nukes. I
assume the nukes simulated, this was in the late 70s, were a bit smaller that 1
MT, but even so the F-4 seemed to not be very far away at time of detonation.
Dan, U. S. Air Force, retired
Old September 3rd 03, 06:23 AM
Scott Ferrin
You're right. It wasn't just the strategic aircraft either. When I
entered training for the F-105, the airplanes were still polished bare
metal. The nuclear weapon of choice was the B-28 or B-43, each of them
rated at 1 MT. Deliveries were usually programmed for some sort of low
altitude low-angle toss with a wing-over escape maneuver to run away
at about 135 degrees from original run-in heading.
Ed Rasimus
Fighter Pilot (ret)
***"When Thunder Rolled:
*** An F-105 Pilot Over N. Vietnam"
*** from Smithsonian Books
ISBN: 1588341038
Seems like the RAF "V" bombers were all white and so was the B-1A.
Old September 3rd 03, 04:12 PM
av8r
Hi Scott
The RAF V-Bomber Force's high-level role changed in 1965 to a low level
one. The Valiants, Victors and Vulcans were subsequently camouflaged
from that point on. I was stationed at Goose Bay, Labrador when the
transition took place. You've never seen anything prettier than a
Vulcan flying at tree top-level. Especially when you are on a hill
looking down on it!!!!!!!!!!!!!
Cheers...Chris
Old September 3rd 03, 06:35 PM
Smartace11
Always wondered what a camo B-58 might look like.
Cheers...Chris
Old September 4th 03, 03:36 AM
Gary Watson
Tha Canadian CF104s that were tasked to the Nuclear Strike role in Germany
in the 1960s were bare aluminum except for the wings which were white.Teh
cockpit had a special aluminized /retractible canopy shield and the pilot
wore a gold-visored helmet.
Ed, I am curious about the Bomb Toss computer in your a/c. We had a simple
dual timer setup in the CF104. One clock was started at the run-in fix (or
whatever it was called) and when it annunciated, the pilot performed the
pitch-up/toss maneuver. At the appropriate time in this manuver the second
timer went to zero and released the bomb.
Seemed like a very simple (read cheap) system and I know the guys were often
putting the 2,000 lb cement shaped charge within 100 mtrs of the dead centre
on the range in Sardinia. Close enough with a nuke IMHO.Depending on the
mission profile, the clocks were set to the appropriate number of seconds.
Gary Watson ex RCAF
"Ed Rasimus" wrote in message
Cheers...Chris
Like a fast moving forest.
Ed Rasimus
Fighter Pilot (ret)
ISBN: 1588341038
Old September 4th 03, 04:52 AM
Les Matheson
Your Toss bombing computer sounds just like the one in the backseat of the
F-4 (it was built by my father while he was at GE). Quite interesting to
fly with something my dad built.
It worked well, so long as you had all the points plotted correctly and flew
the planned airspeeds, altitudes and the pull was done to the proper g-load
and onset rate.
I have also done toss bombing using only the hack clock in the back seat,
and gotten comparable scores. When you have to salvage a check ride you can
think of lots of tricks.
Les
F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret)
"Gary Watson" cf104@ihate spam.shaw.ca wrote in message
news:dGw5b.591$J6.146@pd7tw3no...
often
centre
Gary Watson ex RCAF
Cheers...Chris
Ed Rasimus
Fighter Pilot (ret)
ISBN: 1588341038
Old September 7th 03, 01:53 AM
Ron
One of my friends showed me a video of him in an F-16 dropping one of those
Special shapes, from an F-16 at Tonapah. Did a 40 degree loft, got the bomb
within 20 m.
Ron
Tucson AZ
C-421 air ambulance
spinner paint scheme Dick Home Built 3 January 27th 05 10:58 PM
Aircraft Paint Scheme Designer?? [email protected] Aviation Marketplace 0 December 28th 04 05:52 PM
Paint Stripper? PETER H. OUELLETTE Home Built 9 November 30th 04 07:12 PM
Choice of Paint for use over Copper foil Antennas Charlie Precourt Home Built 1 December 2nd 03 03:51 AM
Velocity Paint scheme Ezaviator Home Built 0 July 31st 03 05:09 AM
