Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aviation Marketplace
Solar Powered Hour Meter
Old July 20th 07, 06:20 PM posted to rec.aviation.marketplace
wayne
Default Solar Powered Hour Meter
I am thinking about importing some little meters as I think they would be
very valuable to the aviation community as a whole. I am trying to gain a
little insight, before I make a large purchase of these meters, whether
you guys and gals see a benefit and would be interested in purchasing one
for around around $80.
They are solar powered UV hour meters, that count the hours it is exposed
to UV radiation. They are very thin, about as thin as a uniform patch,
and about 3" square. They can be glued , epoxied, or even velcroed to
the wing or dash. The meter has an area around it of thick, flexible
plastic, like Naugahyde. This facilitates stitching to surface of
paraglider wings, which they were originally designed for. I think they
would be beneficial to the GA community as well. It has a solar panel at
the top and an LCD screen below the panel. When it is exposed to sunlight,
it starts counting the minutes to hours. When the plane is hangared or
covered, the meter is off, no batteries to change ever. These meters are
the smallest UV meters on the market, currently, only offered overseas. At
$80, they would be the cheapest UV detectors with the added benefit of an
hour meter! Please let me know if you all think it's worth it. Thank you
for your time!
Also: How about a Universal Low Fuel Warning System! ...with bright
flashing LED to alert you when your fuel reaches a predetermined level. I
put these kits together for the powered paragliding community but every
vehicle without a fuel gauge could certainly use one of these.
www.winggear.com
Old July 23rd 07, 01:38 PM posted to rec.aviation.marketplace
El Maximo
"wayne" wrote in message
to UV radiation.
I don't know what I would do with that information. I don't think many
certified aircraft are affected by UV radiation. It may fade the interior,
but a cabin cover will solve that.
Every vehicle without a fuel gauge could certainly use one of these.
I'm pretty sure a fuel gauge is required.
www.winggear.com
Solar Powered Hour Meter wayne Home Built 3 July 24th 07 09:10 PM
Solar Powered Hour Meter wayne General Aviation 1 July 20th 07 09:04 PM
Solar Powered Hour Meter wayne Restoration 0 July 20th 07 06:24 PM
Solar Powered Hour Meter wayne Products 0 July 20th 07 06:23 PM
Solar Powered Hour Meter wayne Owning 0 July 20th 07 06:21 PM
