Spain chooses Euro
Old September 9th 03, 02:21 PM
Jordi Usó
Default Spain chooses Euro
There has been some noise in the media about Spanish military finally
choosing Eurocopter as their attack helo of choice instead of Apache.
The reason the most quoted for this was that Tiger could easily operate
in Ceuta and Melilla while based in mainland Spain, which Apache couldn't
Is there really such a big difference in operating radius between those
two birds?
Regards to the group.
J.
Old September 9th 03, 06:04 PM
John Mullen
"Jordi Usó" wrote in message
om...
two birds?
J.
'The combat radius of the AH-64 is approximately 150 kilometers. The combat
radius with one external 230-gallon fuel tank installed is approximately 300
kilometers'
http://www.fas.org/man/dod-101/sys/ac/ah-64.htm
(Tiger) 'Range 800 km-432 n.m.'
http://www.fas.org/man/dod-101/sys/ac/row/tiger.htm
A surprisingly big difference!
HTH
John
Old September 10th 03, 03:04 AM
Guy Alcala
om...
two birds?
J.
kilometers'
Without knowing the loads each a/c is carrying, or the profiles of the missions,
it's hard to say. The 800km/432nm range is probably ferry range, which will
result in a combat radius considerably less than 400km / 216nm. And different
sources give different numbers. Here's Flug Revue's, often more specific than
what you find on fas.org:
http://www.flug-revue.rotor.com/FRTypen/FRTiger.htm
You'll note that range on internal fuel is given as 670/725 km, depending on the
model. Here's the data on the AH-64D, same source:
http://www.flug-revue.rotor.com/FRTypen/FRAH-64D.htm
You'll note that it can carry twice the number of ATGMs as Tiger, and is
considerably larger and heavier. Also note that the 30mm cannon only comes on
some models of the Tiger, while it's standard on the AH-64. Basic range of the
AH-64 is less, but it can carry two tanks and the same number of missiles as the
Tiger, so the numbers get even more tenuous. all of this isn't to say that the
Tiger may not have a better range for what the Spanish intend to use it for,
equipped how they want it, but the answers tend to be a lot less straightforward
than the glossy brochures handed out to press types would have you believe.
Guy
Old September 11th 03, 06:14 PM
John Mullen
"Guy Alcala" wrote in message
om...
operate
couldn't
those
two birds?
J.
combat
300
kilometers'
missions,
will
different
than
on the
comes on
of the
as the
that the
for,
straightforward
believe.
Not to mention the political faqctors which may have informed the decision
as well.
John
Urgent: 5000 Euro Reward Steven P. McNicoll Instrument Flight Rules 2 March 9th 04 07:32 PM
Interesting Flying Books from Germany ArtKramr Military Aviation 2 September 19th 03 07:55 AM
