Glider add on.....
Old August 13th 07, 08:42 PM posted to rec.aviation.soaring
Scruiser
Default Glider add on.....
.....from the Sport Pilot certificate? I'm currently working on my
Sport Pilot certificate and when that's done I want to add glider
"approval". I've heard rumors about a "light-sport" category of
glider, but I'm interested in the full monty. Question: Can I "add
on" gliders to a Sport Pilot ticket in the same way I would to a ASEL
certificate?
Old August 14th 07, 12:41 AM posted to rec.aviation.soaring
Michael Ash
certificate?
First, a warning: I don't know jack about squat when it comes to these
things.
Now, the relevant CFR just refers to "at least 40 hours of flight time as
a pilot in a heavier-than-air aircraft". Perhaps this is more specific
than it sounds or I'm missing another applicable CFR, but this certainly
sounds like not only would Sport Pilot apply, but so would Student Pilot.
This seems odd to me, but I see no mention of a particular rating, just
time logged.
The regs in question are CFR 61.109 accessible from
http://www.access.gpo.gov/nara/cfr/w...4cfr61_07.html
Michael Ash
Rogue Amoeba Software
Old August 14th 07, 12:50 AM posted to rec.aviation.soaring
BT
I believe the answer to that is no.. I remember reading it someone either on
the EAA LSA web pages or on the AOPA Web.
I will preface this with.. AFAIK (As Far As I Know)
There is no Light Sport Pilot - Glider designation, there is no "approval"
endorsement available from a CFIG.
There are questions on the Private Glider Written Test that are not covered
under the Light Sport Pilot written test. Remember that LS Pilots are
limited to 10,000MSL and below, gliders are not.. so enter airspace
questions, and Oxygen requirements etc.
An "add-on" rating usually means no written required, you will need to
complete the Glider Private Written Test and complete the full FAA Check
Ride for the Private Pilot Glider. I believe your Pilot Certificate would
then read "Private Pilot - Glider", Light Sport Aircraft Privileges with the
LSA endorsements you currently hold. Completing the Private Pilot Glider is
actually a step above Light Sport Pilot.
The number of training hours required per FAR as mentioned by M. Ash are
relevant.. but easily surpassed with proper training.
BT
CFI-G
"Scruiser" wrote in message
certificate?
Old August 14th 07, 01:55 AM posted to rec.aviation.soaring
Scruiser
BT
CFI-G
certificate?
Good information. Thanks!
Old August 14th 07, 05:22 AM posted to rec.aviation.soaring
Question: Can I "add on" gliders to a Sport Pilot ticket in the
same way I would to a ASEL certificate?
The short answer is yes.
In order to obtain the privileges to operate an additional category or
class of light-sport aircraft (and quite a few glider models do meet
the definition of "light-sport aircraft," as defined in FAR 1.1), a
sport pilot must receive appropriate training, a proficiency check,
and related logbook endorsements from authorized instructors, as well
as complete some paperwork. The FAR to reference is 61.321.
Privileges to operate each additional make and model within the glider
category are obtained with training and endorsements specific to that
make and model, per FAR 61.323.
The primary difference between the sport pilot "transition" from the
airplane to glider category and transitioning from PPL-ASEL to PPL-G,
for example, is that with the PPL a check ride with a FAA examiner is
required whereas the sport-pilot requires a "proficiency check" (and
endorsement) from an instructor other than the one who provides the
training endorsement. (Of course training requirements, experience
minimums, and operating restrictions differ as well.)
Anecdotally, I have heard of a holder of a sport pilot certificate
(light-sport airplane) who went through exactly this process to "add
on" a glider endorsement. The endorsements were received, paperwork
prepared, and everything was in order, but in the end the pilot
decided to just go ahead and complete the few remaining additional
requirements for a PPL-G rating.
The page at the following URL contains a good synopsis of the Light
Sport Aircraft / Sport Pilot Rule. http://www.sportpilot.org/learn/fina..._synopsis.html
See the condensed rule: http://www.sportpilot.org/learn/sp_rule.pdf
See complete rule: http://www.sportpilot.org/learn/final_rule.pdf
Also note that part of what BT mentioned is certainly true. The sport
pilot with an endorsement for the glider category will have more
operating restrictions than a pilot with a PPL-G rating.
I've heard rumors about a "light-sport" category of glider, but I'm
It seems that as long as a glider meets the definition of light-sport
aircraft (see FAR 1.1), then it may be flown by a sport pilot who has
received training and a logbook endorsement from an authorized
instructor for the category, class, and make and model of aircraft.
Note that for the sport pilot, training and an endorsement for each
specific make and model of aircraft may be required, as summarized in
FAR 61.323.
Many "older" gliders meet the definition of "light-sport aircraft,"
but it appears that most of the more modern (glass) ships do not,
primarily due to the Vne restriction.
I'm currently working on my Sport Pilot certificate and when
that's done I want to add glider "approval".
Fly safe, have fun, and finally, IANAL.
Old August 14th 07, 06:13 AM posted to rec.aviation.soaring
It should be noted that a person with a Sport Pilot (Glider) ticket may not
fly above 10,000 ft MSL. This makes the ticket useless in the Western US
where the valley floors are commonly above 5,000 ft MSL and the mountain
ranges are above 12,000 feet.
http://www.soaridaho.com/
s.com...
FAR 61.323.
Glider art Mal Soaring 2 December 13th 06 06:54 PM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Glider tie down. Serge Serfaty Soaring 10 May 4th 06 03:59 AM
Looking for new glider Bill Daniels Soaring 12 August 19th 03 03:22 PM
