Tost brake bolt shears off
Old September 1st 07, 02:40 PM posted to rec.aviation.soaring
Jack Glendening[_2_]
Default Tost brake bolt shears off
I am wondering if others have experienced the shearing of a Tost brake
bolt resulting in brake failure - I'm speaking about the bolt which
extends from the hub and is secured to the aircraft frame (not
the bolt which extends for the wire lever attachment). I experienced
such a failure on my latest landing with a month-old Tost unit - I was
puliing more strongly than usual on the brake but not nearly as hard
as I could, and certainly not as hard as I would if it had been an
emergency situation. I was amazed that such could produce a bolt
shear - I would have thought that some other brake part would fail
before such a
relatively thick bolt would, but I am no mechanic. It makes me wonder
about the quality of the parts Tost is using. Is this a known/common
point of failure?
Jack Glendening
FS Tost E85 Release scooter Soaring 0 March 7th 06 03:31 AM
FS Tost E85 Release scooter Soaring 0 November 22nd 05 02:11 AM
TOST E85 RELEASES [email protected] Soaring 2 March 6th 05 05:21 PM
Cessna 182 Tost 337? [email protected] Soaring 6 May 15th 04 04:24 PM
Tost springs Lord Struthers Soaring 1 October 10th 03 11:49 PM
