Does anyone know if the plane had a fixed ELT installed?
FARs said it should have had one.
91.207, unless it was exempt according to 91.207 (f)(3), training operations within 50nm of where training began. BT "Brian Milner" wrote in message ... Does anyone know if the plane had a fixed ELT installed? |
On Sep 6, 9:38 pm, "BT" wrote:
FARs said it should have had one. 91.207, unless it was exempt according to 91.207 (f)(3), training operations within 50nm of where training began. BT "Brian Milner" wrote in message ... Does anyone know if the plane had a fixed ELT installed? Well, the alternatives in this situation are pretty simple: A] No ELT signal has been detected, therefore perhaps 1: It failed to function (dead battery; destroyed in crash) 2: The aircraft did not experience an 'impact' strong enough to activate it 3: Mr. Fossett did not or was unable to activate it manually. B] No radio distress calls have been heard, therefore perhaps 4: The aircraft's battery was destroyed in the crash 5: The radios were destroyed in the crash 6: Mr. Fossett exited the airplane and was unable to return to it (lost, incapacitated) 7: The battery shorted out. 8: Mr. Fossett has been incapacitated or had sudden cardiac death, without a crash. 9: (hardly likely) Mr. Fossett has deliberately disappeared. Or some combination (e.g., 2 + 6 -- landing on a dry lake that was crusty, the wheels fell through; Mr. Fossett exited the aircraft to investigate and fell through himself and was incapacitated thereby; not very likely, especially in August) But none of this helps find the airplane, a tough thing to do if it's not on level ground. DJ |
Immersed in water?
Bagger |
| Thread Tools | |
| Display Modes | |
| Steve Fossett missing? | Rob Turk[_2_] | Home Built | 32 | September 8th 07 01:53 AM |
| Steve Fossett | [email protected] | Owning | 15 | September 7th 07 09:45 PM |
| Steve Fossett - Missing | [email protected] | Soaring | 18 | September 6th 07 09:16 PM |
| Steve Fossett missing? | Wayne Paul | Soaring | 0 | September 6th 07 04:29 PM |
