Not 1, but 2 reports
Old September 9th 07, 11:22 PM posted to rec.aviation.piloting
Kevin Clarke
Default Not 1, but 2 reports
2 reports on the evening news today (Boston area) on small plane
crashes. A C172M crashed at Mansfield, Ma. 4 people on board, 2
fatalities. This was on Saturday, a day that produced record high
temperatures for the area. Density altitude/overloading problem?
Then we had a C150 emergency land on Route 3. Ran out of gas. No
injuries, no damage. Tied up traffic though.
Incident 2 was certainly avoidable, incident 1 was most likely as well.
We're the stewards of GA's reputation. Take care out there. Being sloppy
is not only dangerous but it injures all of us. Preaching to the choir...
KC
Old September 10th 07, 12:22 AM posted to rec.aviation.piloting
Bob Noel
The 95 degrees only put the DA near 2500'. Assuming they weren't
using the 2200' turf runway, shouldn't 3500' have been enough runway
for a properly loaded/properly functioning 172M?
Bob Noel
(goodness, please trim replies!!!)
Old September 10th 07, 12:33 AM posted to rec.aviation.piloting
Kevin Clarke
From reports, they got airborne, so the runway length wasn't the issue.
Their climbout would have been reduced due to weight and higher than
normal DA. I'm guessing a stall on climbout with a higher gross weight
and a CG aft of "normal". The pilot couldn't recover. Like I said,
guessing. There is no NTSB report yet, obviously. Either way, it is sad.
KC
Old September 10th 07, 12:50 AM posted to rec.aviation.piloting
Jon
crashes. [...]
Just saw a news report. Apparently, he took off from ME, ran into some
weather in NH, landed, then took off again. His destination was
Hopedale.
Route 3 can be a fairly dense with traffic, so it was a good thing it
wasn't on a weekday, say during rush hour. They said he touched down
in the Tyngsboro area. It must have been quite the site to be driving
in a car.
Regards,
Jon
Old September 10th 07, 12:51 AM posted to rec.aviation.piloting
B A R R Y
On Sun, 09 Sep 2007 19:22:13 -0400, Bob Noel
News reports state 4 mid-30's male occupants were aboard and "at least
2 golf bags" were in the wreckage. Rented airplane from Maine, pilot
has had his ticket around a year.
I read a quote from a pilot witness who was attending an EAA fly-in
who thought that the plane took a long time to gain speed, although
the engine sounded fine, and failed to gain much altitude, then
turned, stalled, and went straight in. The photos are awful, and
bear out the straight-in reports.
Another report I read stated that the pilot made a mayday call that he
couldn't "clear the trees", and was turning back to the field.
Apparently, the plane arrived in Mansfield with three aboard, and the
forth (maybe with a golf bag?) boarded there, for trip over to Cape
Cod for a golf trip. Since most courses worth flying to usually don't
allow sharing clubs, you have to wonder if the plane had four guys and
four golf bags. Mansfield is a 30 minute or so hop to pretty much
anywhere on the Cape with an airport, so he wouldn't have needed lots
of fuel.
On a side note, Skylune might live in that area...
Old September 10th 07, 01:04 AM posted to rec.aviation.piloting
KC
Four, 30 somethings males + 4 sets of golf clubs (off to play on the
Cape) + 90+F + humidity + ? in a 172M. EAA fly in going on at the
time so lots of good witnesses. Pilot made a radio call that he could
not clear the trees and was turning back - this was followed by stall/
spin. Very tragic in that there were several accounts that he could
have indeed cleared the trees if he would have continued, also tragic
that so many members of the general public witnessed this as the fly-
in is a popular local event. jeff
Old September 10th 07, 03:29 AM posted to rec.aviation.piloting
On Sep 9, 9:54 pm, Judah wrote:
wrote in news:1189382647.136590.257600
@r34g2000hsd.googlegroups.com:
How much, exactly, did each of the 30-something males weigh?
How much fuel was aboard the plane?
I think it is best to reserve judgement until all the facts are available.
Sorry you read a judgment somewhere, please re-read - just stating
facts as reported and expressing the tragedy of the scene - I happened
to be there and I am based there. Fly safe.
Old September 10th 07, 03:49 AM posted to rec.aviation.piloting
John Clear
Using FAA standard 170 pound passengers, 50 pounds for the golf
clubs (probably way low) and just 20 gallons of fuel, and the W&B
numbers from a 172M I'm familiar with, I calculate the weight to
be just over MGTW, and the CG to be towards the aft end of the
envelope.
Even if the passengers where FAA standard 170 pounders, the golf
clubs likely weighed more, and there was likely more then the bare
minimum of fuel on board.
John
John Clear - http://www.clear-prop.org/
Old September 10th 07, 04:38 AM posted to rec.aviation.piloting
Andrew Sarangan
KC
I have found that heat has an adverse effect on piloting ability as
well. When it is 90F outside, the cockpit could be 110 or higher. All
that heat and sweat and makes me irritable and impatient, and wanting
to get airborne as quickly as possible to get some cool air flowing.
It is easy to make poor takeoff decisions under those circumstances.
Accident reports Dave Kearton Aviation Photos 0 April 28th 07 03:21 AM
Accident reports Dave Kearton Aviation Photos 0 April 28th 07 03:20 AM
Thanks for the Sun 'n fun reports Tedstriker Home Built 16 April 19th 05 03:10 PM
SSA Convention reports? John H. Campbell Soaring 17 February 23rd 05 09:45 PM
U.S. Team Day Reports John Seaborn Soaring 0 July 30th 03 08:33 PM
