Sunglasses for soaring
Old September 14th 07, 06:13 PM posted to rec.aviation.soaring
Default Sunglasses for soaring
I have heard from time-to-time that Sun Tiger sunglasses work well for
soaring. Since I fly within 30 miles of the 1/10th busiest airport in
the world, anything that will increase my chances of seeing another
aircraft is something I want to take advantage of. It also turns out
that Sun Tigers are local, and not particularly expensive.
Opinions either pro or con are welcomed.
Old September 14th 07, 07:16 PM posted to rec.aviation.soaring
Kloudy via AviationKB.com
I have always been xtremely pleased with the performance of Revo lenses.
If you have a chance, I highly recommend giving them a try. I swore by
Serengeti until my instructor passed his Revos to me up front one day and I
was amazed.
Admittedly a little pricey ($250) but I place at least that much value in the
ability to see and avoid and the UV protection for my eyes.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...aring/200709/1
Old September 14th 07, 08:29 PM posted to rec.aviation.soaring
AlexBerberich
I'm a huge fan of Serengetis, don't think you can go wrong with those.
Old September 14th 07, 09:20 PM posted to rec.aviation.soaring
Nyal Williams
If they are local, why not go there and try out a pair?
I've used nothing else since they hit the market and
were reviewed in Soaring back in the mid-80s. They
can even do tri-focals! You can probably find Serengetis
locally, also. Try them both before you decide.
At 17:18 14 September 2007,
work well for
busiest airport in
seeing another
It also turns out
Old September 14th 07, 10:54 PM posted to rec.aviation.soaring
Since sunglass type has only a marginal effect on detecting threatening
aircraft, I'm curious: is this the start of a search for improved
separation from other aircraft, or near the end of it, because your
glider already has in it a transponder, Zaon MRX, and a pilot
well-trained in scanning techniques, ATC communications, and
arrival/departure paths?
* "Transponders in Sailplanes"http://tinyurl.com/y739x4
* "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org
Even a small effect may be helpful. I have been working on improving
my scanning habits, (which are similar but not identical to scanning
required to stay alive riding a motorcycle, which I've been doing for
36 years) but still often visually pick up traffic that is already
closer than I'd like. One of the local pilots (25 years working
McCarren tower) is also trying to help me learn which directions the
threats are most likely to appear from in what location at which
altitudes.
To answer your question, radio monitoring yes, MRX and Transponder no.
I will add both if and when I can afford to.
Also, I need new sunglasses and thought this would be a good time to
'ping' the RAS for recommendations.
Old September 17th 07, 07:28 PM posted to rec.aviation.soaring
01-- Zero One
" wrote in
message news
(Peter Nyffeler) wrote:
In article . com,
I've been using Suntigers for at least 10 years now. For me they work
great. In spite of blue being black, color distorsion never got in my
way. It is amazing how well the brain compensates. I wear bifocals.
Suntiger just makes them to my prescription (I did send them a frame
and a drawing where to put the split). I also have nothing but
positive things to say about how they deal with customers.
Cheers,
Henryk Birecki
Interesting, Henryk,
My experience was not so good. I bought a pair a couple of years ago.
Used them very little. Recently they broke, obviously from a defective
solder joint. I contacted them and they refused to do anything except
repair or replace them for the cost of new ones.
I am not satisfied.
Larry
Old September 18th 07, 04:55 PM posted to rec.aviation.soaring
Henryk Birecki
"01-- Zero One" wrote:
" wrote in
message news
In article . com,
Cheers,
Henryk Birecki
I am not satisfied.
Larry
When I got my first pair of glasses from Suntiger they had some
serious internal problems due to employee caused fraud. I did not hear
from them for a while after placing order, and could not find them
when I tried. Let's say I was not happy about that. At this point I do
not remember details, but after a while they found me. Explained what
happened and provided me with glasses. Since then I had no problems
what so ever either with quality or service.
Cheers,
Henryk
Sunglasses [email protected] Soaring 24 May 18th 10 04:32 AM
sunglasses [email protected] Soaring 24 January 22nd 06 03:49 PM
HDL-3CT Sunglasses Icebound Piloting 5 August 18th 05 07:30 AM
Sunglasses? Greg Butler Piloting 17 October 27th 04 01:40 AM
FS: Sunglasses you need Great Deal Aviation Marketplace 0 October 10th 03 04:51 AM
