Does glide ratio change with altitude?
Old September 19th 07, 03:43 PM posted to rec.aviation.ifr
Jim Carter[_1_]
Default Does glide ratio change with altitude?
During a recent discussion about calculating glide ratio, I began to wonder
what the effects of pressure altitude were on the glide ratio of an
aircraft. Since air is 50% as dense at FL180 as at sea level, would the
glide ratio increase (glide further) as altitude decreases? AND if there is
a difference in glide ratio as altitude changes, then what values do most
manufacturers use when they publish their numbers (if they do)?
Oh yeah, I do understand that glide ratio changes to 0:0 upon impact, so the
wags can skip that part of the reply...
Jim Carter
Rogers, Arkansas
Old September 19th 07, 04:45 PM posted to rec.aviation.ifr
FredGarvinMaleProstitute
Ratio math is good only if terrain is perfectly flat in a
perfect world. You got to figure in the geography to get the
actual ratio. Or...... splat
A little calculus anyone???
Old September 20th 07, 02:25 AM posted to rec.aviation.ifr
Jim Carter[_1_]
"FredGarvinMaleProstitute" wrote in message
wonder what the effects of pressure altitude were on the glide ratio of
an aircraft. Since air is 50% as dense at FL180 as at sea level, would
the glide ratio increase (glide further) as altitude decreases? AND if
there is a difference in glide ratio as altitude changes, then what
values do most manufacturers use when they publish their numbers (if they
do)?
the wags can skip that part of the reply...
Ratio math is good only if terrain is perfectly flat in a perfect world.
You got to figure in the geography to get the actual ratio. Or...... splat
Ok Fred - that's a new one. What does terrain have to do with glide ratio? I
already noted that impact has an impact on the ratio, but only at point of
impact. Other than that one point on the continuum, what effect could
terrain have on glide ratio? And don't get started on turbulence, or wind
shear, or any number of other weather anomalies, because I'm asking about
glide ratio, not glide distance.
Jim Carter
Rogers, Arkansas
Old September 20th 07, 04:26 PM posted to rec.aviation.ifr
Dan Luke[_2_]
LOL. Still got a way to go to catch Mxsmanic, though.
Dan
"Did you just have a stroke and not tell me?"
- Jiminy Glick
Old September 19th 07, 06:27 PM posted to rec.aviation.ifr
Matt Barrow[_4_]
"Jim Carter" wrote in message
t...
wonder what the effects of pressure altitude were on the glide ratio of an
is a difference in glide ratio as altitude changes, then what values do
most manufacturers use when they publish their numbers (if they do)?
As you descend, drag increases.
Remember that the purpose if having an engine (thrust) is to overcome
weight, but also DRAG.
Okay...I'll skip that point! :~)
Matt Barrow
Performance Homes, LLC.
Cheyenne, WY
Old September 20th 07, 02:30 AM posted to rec.aviation.ifr
Jim Carter[_1_]
"Matt Barrow" wrote in message
t...
do)?
Yes, (induced) drag increases as a factor of lift caused by the higher air
density, and parasitic drag increases as a factor of speed which isn't
changing. So back to my original question - sort of, does the lift created
by denser air at lower altitudes vary the glide ratio for any significance?
Or is the airfoil performance at a given speed static across the entire
flight profile?
Matt Barrow
Cheyenne, WY
Jim Carter
Rogers, Arkansas
Old September 25th 07, 04:58 AM posted to rec.aviation.ifr,rec.aviation.piloting
Andrew Sarangan
Jim Carter
Rogers, Arkansas
This is a very good question. As others have mentioned, max (L/D) and
best glide IAS remain the same regardless of altitude. But that does
not immediately lead to the conclusion that glide ratio also remains
constant. L/D and best glide speed is about indicated airspeeds. At
higher altitudes, the best glide speed (IAS) wll result in a higher
true airspeed. So one might be tempted to conclude that the airplane
may be able to glide father, which is why I suspect you asked the
question in the first place.
It is not sufficient to argue that L/D remains constant, but you also
have to show that L/D is equal to the glide ratio. Glide ratio is the
physical horizontal distance traveled over still air for a unit
vertical altitude lost. Therefore, it is the ratio between the true
airspeed and the true vertical speed (TVS). I am sure there are many
ways to do this, but I find the energy argument the most intuitive.
Consider the power lost to drag, which is (D*TAS). This should be
equal to the rate of energy given up by the airplane due to its
descent. The rate of energy lost due to the descent is W*TVS, where W
is the weight of the airplane. We also know that W=L under
unaccelarated flight. Therefore, D*TAS = L*TVS and we can TAS/TVS =
glide ratio = L/D.
This might be obvious to some, but I had to do this step by step in
order to convince myself that L/D is indeed equal to the glide ratio.
Pehaps you might find it useful.
trivia: highest glide ratio [email protected] Soaring 10 August 4th 06 09:47 PM
So you think you have a low glide ratio! COLIN LAMB Soaring 30 January 12th 06 02:47 PM
question on glide ratio functions in Garmin 96, 96C, 196 GPS Steve S Soaring 1 January 10th 06 07:43 PM
GPS glide ratio calculations james Soaring 0 May 4th 04 09:00 PM
GPS glide ratio calculations Jason Armistead Soaring 16 September 12th 03 04:50 AM
