After reading this, I uploaded the latest Google Earth freeware on WinXP
and hit Control ALT A which brought up an SR22 and an F16 as choices. The same sequence exited the Google Earth Flight Simulator. I had trouble controlling the airplane until I found the following settings by QWERTY keyboard trial and error. I'd start at Moffett Field at runway R32 heading 320 degrees. http://maps.google.com/?q=37.4064203...04305827617645 The comma & period controlled my left & right brake respectively. - The C centered both the ailerons and the rudders. - LeftBracket and RightBracket controlled the flaps. - PageUp and PageDown controlled the throttle. - UpArrow and DownArrow controlled the elevators. Once airborne: - G retracted the landing gear. - Shift F retracted the flaps. - LeftArrow and RightArrow controlled the ailerons. - Shift LeftArrow and Shift RightArrow controlled the rudders. When I got out of control, - Spacebar paused the simulation so I could catch my breath. - The h toggled the heads up display on and off. - Alt LeftArrow and Alt RightArrow turned the pilot's head. To land, - G extended the landing gear. - The f key extended the flaps. - Simultaneously pressing comman & period braked to a halt. best kcat |
settings by QWERTY keyboard trial and error. At the start up screen, if you would have clicked on the HELP button you get the complete list of controls on the keyboard. Could have saved yourself a lot of time. :-) Happy flying!!! |
On Sep 22, 7:53 pm, KCat wrote:
After reading this, I uploaded the latest Google Earth freeware on WinXP and hit Control ALT A which brought up an SR22 and an F16 as choices. The same sequence exited the Google Earth Flight Simulator. I had trouble controlling the airplane until I found the following settings by QWERTY keyboard trial and error. I'd start at Moffett Field at runway R32 heading 320 degrees.http://maps.google.com/?q=37.4064203...04305827617645 The comma & period controlled my left & right brake respectively. - The C centered both the ailerons and the rudders. - LeftBracket and RightBracket controlled the flaps. - PageUp and PageDown controlled the throttle. - UpArrow and DownArrow controlled the elevators. Once airborne: - G retracted the landing gear. - Shift F retracted the flaps. - LeftArrow and RightArrow controlled the ailerons. - Shift LeftArrow and Shift RightArrow controlled the rudders. When I got out of control, - Spacebar paused the simulation so I could catch my breath. - The h toggled the heads up display on and off. - Alt LeftArrow and Alt RightArrow turned the pilot's head. To land, - G extended the landing gear. - The f key extended the flaps. - Simultaneously pressing comman & period braked to a halt. best kcat Hardly hidden, its right on the menu bar. |
| Thread Tools | |
| Display Modes | |
| Mini-Flight Sim in Google Earth | [email protected] | Soaring | 3 | September 6th 07 12:26 AM |
| Google Earth fun | Al Denelsbeck | Aviation Photos | 4 | January 11th 07 05:31 PM |
| C5 in-flight refueling by KC135, satellite photo via Google earth | Morgans | Aviation Photos | 0 | November 13th 06 01:48 AM |
| Google Earth - Glider | David Pye | Soaring | 1 | June 8th 06 05:39 PM |
| Google Earth | ttaylor at cc.usu.edu | Soaring | 8 | September 22nd 05 01:07 PM |
