Hey all. Been meaning to post this for awhile (almost done with the annual now), but campus news
server has been down. Anyway... I've got a 180hp O-360-A3A Lycoming in my Cherokee. The engine has always been just a bit weak since we've owned it. We've now got about 500 hours on it since we bought it with what I now know was a "service limits overhaul." It's always been at the very bottom end of the static RPM allowance on the TCDS (2250 RPM is the bottom of the range). Very occasionally (approx 1 out of 25 takeoffs), the power output is even more decreased for the first 60 seconds after takeoff. Not enough to notice under normal conditions ("Geez... only getting 500 fpm instead of 650"), but definately enough to get your attention at high density altitudes and/or heavily loaded. While it's not always obvious it's happening, when I suspect it is I've done mag checks, looked at EGT, looked at manifold pressure.... nothing unusual and everything is running smoothly. Things we've checked over the years: - Compression is always good (77-80/80 on all four) - Propeller is correct and brand new when we bought it... pitched the standard 60" - Tach has been checked with calibrated strobe-tach. - Muffler baffles checked and fine... nothing loose inside - Mags have had fresh points/condensers, internally and externally timed. - Plugs have been replaced, cleaned, gapped, rotated multiple times, etc. - Done "wobble test" on valve guides. Worn, but within the limits. So, while we were doing the annual this year, we figured we'd check to make sure the hydraulic lifters were OK. They checked out fine, but when we put it back together noticed that a number of the valves had excessive dry-tappet clearance. Book calls for 0.028-0.080. We had only two barely within that spec, and 6 with clearances ranging from 0.090-0.130. We've got some longer pushrods on the way to get them all within spec. The question is, will the hydraulic lifters take up the slack, or could the longer extension cause increased bleed-down that would reduce valve travel? If the former, then it would just make the valves noisy for a bit after startup, but takeoff/climb/cruise would be unaffected. If the latter, then maybe it would affect the power at all RPMs? Another thing we checked while we had the lifters out was the cam lift. Putting a dial indicator on the tappets directly, we measured anywhere from 0.355-0.360" on all lobes. After calling a half-dozen shops to find out what the book specification is for a Lycoming cam (apparently not published anywhere), I measured a friend's new ECI AEL-18840 cam at 0.353. Since all of my lobes are the same, and apparently the same as a new ECI cam, I figure the cam is fine. Thoughts? Comments? If this fixes the chronic low power, I'll be ecstatic, but I'm skeptical that it will affect anything. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
On Sep 25, 6:53 am, wrote:
Hey all. Been meaning to post this for awhile (almost done with the annual now), but campus news server has been down. Anyway... The dry tappet clearance might be part of the problem. The clearances can increase as the cylinder lengthens with heat, and a few valves might not be opening all the way. But it should be a consistent lack, not 1 out of 25 takeoffs. I would suspect that carb icing might be your problem. It's way more common than many folks think. What are the atmospheric conditions when this happens? Look for small temperature/dewpoint spreads. It doesn't have to be cold outside; ice can appear at temps up to 100°F. Lycomings are ice-resistant because their carbs are mounted on the oil sump, but if the oil isn't really hot yet, or if the temps are cooler and the dewpoint isn't far away, ice will form. Sometimes even if the oil's hot, and even in the full-throttle climb. Does the engine stumble once in a while in the climb? Probably ice. We see ice all the time here, even in a dry climate and on Lycomings and on warm days. Got to know what to watch for. Check the carb heat immediately before takeoff, at around 12 or 1400 RPM. Should get a drop that stays dropped; any rise after that with carb heat on, or excessive roughness before it rises, indicates ice. There have been accidents where engines didn't generate enough power to sustain a climb, and the cause was pegged as ice that formed during the taxi, after the runup. Dan |
: The dry tappet clearance might be part of the problem.
: The clearances can increase as the cylinder lengthens with heat, and a : few valves might not be opening all the way. But it should be a : consistent lack, not 1 out of 25 takeoffs. I may not have been completely clear in my zeal to describe my frustration... ![]() power issues we're trying to resolve. There's a chronic loss of power (never made more than the very bottom of the static RPM). The occasional loss is so subtle, infrequent, and irreproduceable, that's it's very difficult to track down. We thought maybe gunk in one of the lifters that occasionally prevented pumping up which is why we decided to look. I'm now wondering if the 1-in-25 thing is the lifter spring snapping out of its little shoulder due to the excessive clearance. Then it might occasionally snap back in. : I would suspect that carb icing might be your problem. : It's way more common than many folks think. What are the atmospheric : conditions when this happens? Look for small temperature/dewpoint : spreads. It doesn't have to be cold outside; ice can appear at temps : up to 100?F. Lycomings are ice-resistant because their carbs are : mounted on the oil sump, but if the oil isn't really hot yet, or if : the temps are cooler and the dewpoint isn't far away, ice will form. : Sometimes even if the oil's hot, and even in the full-throttle climb. : Does the engine stumble once in a while in the climb? Probably ice. We : see ice all the time here, even in a dry climate and on Lycomings and : on warm days. Got to know what to watch for. : Check the carb heat immediately before takeoff, at around : 12 or 1400 RPM. Should get a drop that stays dropped; any rise after : that with carb heat on, or excessive roughness before it rises, : indicates ice. There have been accidents where engines didn't generate : enough power to sustain a climb, and the cause was pegged as ice that : formed during the taxi, after the runup. I've gotten carb ice a few times... even in fairly warm temps. I'm skeptical that this is the cause because it doesn't seem to be temperature related. It's done it on nice cold (35) dry, winter days, as well as hazy hot (95) summer days. Also, I've got a manifold pressure gauge on this plane even though it's fixed pitch. Manifold pressure indicates correctly when it's acting up... if it were carb ice it'd indicate less MP. I'm glad to hear someone agreeing that chronic loss might be due to valve clearance. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() How old are your sparkplugs? We've had a lot of trouble over the years with Champions, and used to buy the Auburns before Champion bought them up and shut them down. They were an excellent plug and almost always eroded to limits before the internal resistor failed. With Champs, we've had the internal resistor misfiring at 50 hours. One didn't work right out of the box. The Unison plugs are no better. A poorly-firing plug will cause a slight RPM drop. They need to be tested under pressure to see that they continue to fire up to at least 120 psi. Dan |
On Sep 25, 6:34 pm, wrote:
wrote: : How old are your sparkplugs? We've had a lot of trouble over the : years with Champions, and used to buy the Auburns before Champion : bought them up and shut them down. They were an excellent plug and : almost always eroded to limits before the internal resistor failed. : With Champs, we've had the internal resistor misfiring at 50 hours. : One didn't work right out of the box. The Unison plugs are no better. : A poorly-firing plug will cause a slight RPM drop. They need : to be tested under pressure to see that they continue to fire up to at : least 120 psi. It's done the intermittent thing with new plugs, as well as freshly gapped and cleaned. Besides, if a plug wasn't firing, the mag drop would show it (it doesn't... runs smoothly on each mag by itself). Nice thought though. We've already done all the easy and normal stuff.... ![]() -Cory The plugs will fire during the runup, one mag at a time, but during flight when both mags are firing, there may be one or two that don't. Engines that have both mags timed at the same point BTDC need to be set as accurately as possible so that both plugs fire at the same time or very close. If one fires well before the other, the cylinder pressures may rise to a point that the other plug, being a little weak, can't fire and now we get a bit of roughness and loss of power. There are a few engines that specify a significant difference in their mag timing. I don't know how they handle spark blowout with that setup. Some of them were pretty old models that used resistorless plugs; perhaps they didn't suffer the same way that plugs with resistors do. Dan |
I would suspect that carb icing might be your problem. It's way more common than many folks think. What are the atmospheric conditions when this happens? Look for small temperature/dewpoint spreads. It doesn't have to be cold outside; ice can appear at temps up to 100°F. Lycomings are ice-resistant because their carbs are mounted on the oil sump, but if the oil isn't really hot yet, or if the temps are cooler and the dewpoint isn't far away, ice will form. Sometimes even if the oil's hot, and even in the full-throttle climb. Does the engine stumble once in a while in the climb? Probably ice. We see ice all the time here, even in a dry climate and on Lycomings and on warm days. Got to know what to watch for. Check the carb heat immediately before takeoff, at around 12 or 1400 RPM. Should get a drop that stays dropped; any rise after that with carb heat on, or excessive roughness before it rises, indicates ice. There have been accidents where engines didn't generate enough power to sustain a climb, and the cause was pegged as ice that formed during the taxi, after the runup. http://www.ez.org/carb_ice.htm I don't know whether carb ice is Cory's problem, but I agree many Cherokee pilots don't appreciate the probability of carb ice, probably due to Piper's checklist not specifying carb heat for all landings / descents as Cessna's checklist does. You *can* get carb ice in a cherokee. Watch out during those long, slow instrument approaches through visible moisture. Sorry for the slight thread misdirection. Dave |
I've have discovered just-barely-out-of-limits pushrod lengths on one
cylinder can cause a loss of 2-3 knots cruise speed. Excessive clearance changes the effective valve timing, retarding the opening and thus decreasing power. This is one area that blueprint engine builders pay much attention to. I have a suspicion that since the field overhaul ignored the pushrod lengths, they probably ignored the testing of the lifter hydraulic units. There is a spec for the bleed-down rate. You need to fix this soon. Excessive clearance is hard on the camshaft. I know where find the camshaft specs. I'll post them here. Kent Felkins Tulsa wrote in message ... Hey all. Been meaning to post this for awhile (almost done with the annual now), but campus news server has been down. Anyway... I've got a 180hp O-360-A3A Lycoming in my Cherokee. The engine has always been just a bit weak since we've owned it. We've now got about 500 hours on it since we bought it with what I now know was a "service limits overhaul." It's always been at the very bottom end of the static RPM allowance on the TCDS (2250 RPM is the bottom of the range). Very occasionally (approx 1 out of 25 takeoffs), the power output is even more decreased for the first 60 seconds after takeoff. Not enough to notice under normal conditions ("Geez... only getting 500 fpm instead of 650"), but definately enough to get your attention at high density altitudes and/or heavily loaded. While it's not always obvious it's happening, when I suspect it is I've done mag checks, looked at EGT, looked at manifold pressure.... nothing unusual and everything is running smoothly. Things we've checked over the years: - Compression is always good (77-80/80 on all four) - Propeller is correct and brand new when we bought it... pitched the standard 60" - Tach has been checked with calibrated strobe-tach. - Muffler baffles checked and fine... nothing loose inside - Mags have had fresh points/condensers, internally and externally timed. - Plugs have been replaced, cleaned, gapped, rotated multiple times, etc. - Done "wobble test" on valve guides. Worn, but within the limits. So, while we were doing the annual this year, we figured we'd check to make sure the hydraulic lifters were OK. They checked out fine, but when we put it back together noticed that a number of the valves had excessive dry-tappet clearance. Book calls for 0.028-0.080. We had only two barely within that spec, and 6 with clearances ranging from 0.090-0.130. We've got some longer pushrods on the way to get them all within spec. The question is, will the hydraulic lifters take up the slack, or could the longer extension cause increased bleed-down that would reduce valve travel? If the former, then it would just make the valves noisy for a bit after startup, but takeoff/climb/cruise would be unaffected. If the latter, then maybe it would affect the power at all RPMs? Another thing we checked while we had the lifters out was the cam lift. Putting a dial indicator on the tappets directly, we measured anywhere from 0.355-0.360" on all lobes. After calling a half-dozen shops to find out what the book specification is for a Lycoming cam (apparently not published anywhere), I measured a friend's new ECI AEL-18840 cam at 0.353. Since all of my lobes are the same, and apparently the same as a new ECI cam, I figure the cam is fine. Thoughts? Comments? If this fixes the chronic low power, I'll be ecstatic, but I'm skeptical that it will affect anything. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Fly fly at Tulsaconnect.com wrote:
: I've have discovered just-barely-out-of-limits pushrod lengths on one : cylinder can cause a loss of 2-3 knots cruise speed. : Excessive clearance changes the effective valve timing, retarding the : opening and thus decreasing power. : This is one area that blueprint engine builders pay much attention to. : I have a suspicion that since the field overhaul ignored the pushrod : lengths, they probably ignored the testing of the lifter hydraulic units. : There is a spec for the bleed-down rate. : You need to fix this soon. Excessive clearance is hard on the camshaft. : I know where find the camshaft specs. I'll post them here. : Kent Felkins : Tulsa It sure seems like the lifters would have plenty of adjustment to take up the slack. The bleed-down rate would have to be affected pretty significantly to affect the effective valve lift at 2500 RPM though, I'd think. From what I've been able to google up on the subject, bleed-down shouldn't affect high-RPM valve operation much. It's pretty much a low-RPM thing. Then again, you can't believe everything you read online... much better to appeal to random folks on USENET. ![]() As far as the lifters go, we did the "squeeze" test as mentioned in the overhaul engine manual. Nothing out of spec as far as that was concerned, but it's probably not too accurate. If you could find the camshaft specs, it would be absolutely the only place they're posted on the 'net as far as I've been able to find. That'd be great... ![]() -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Ball Valve,Needle Valve,Snubber,Gauge Cock Sale on good price | valvetom | Piloting | 0 | November 28th 06 02:32 AM |
Brass Ball Valve,Gas Valve,Needle Valve,Angle Valve,Hose Bibcock Sale on good price | valvetom | Piloting | 0 | November 28th 06 02:25 AM |
Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 02:44 AM |
sticky valve or | Dick | Home Built | 18 | May 25th 05 07:50 PM |
sticky valve or | Dick | Owning | 18 | May 25th 05 07:50 PM |
