I have a friend with a Ercoupe whose steering knuckle/assembly has been
worn to where it is too sloppy. It's about 2.20 inches in diameter and rotates on the nose strut assy. It's what the scissors are attach to. It either needs to be bushed or trued up and add a bearing sleeve to the mating surface. Are there any machine shops in the DFW area that can do this kind of work for a decent price? Thanks Dave |
![]() Dave wrote: Are there any machine shops in the DFW area that can do this kind of work for a decent price? Thanks If Lone Star is still in business over at Meacham, I think they can. Otherwise, head to Breckenridge and Nelson Ezell can do it. BTW, it's always worth a run to Nelson's place to see what warbirds he's got in the shop. Craig C. |
Dave wrote in news:tDVLi.2948$yc5.2028
@nlpi069.nbdc.sbc.com: I have a friend with a Ercoupe whose steering knuckle/assembly has been worn to where it is too sloppy. It's about 2.20 inches in diameter and rotates on the nose strut assy. It's what the scissors are attach to. It either needs to be bushed or trued up and add a bearing sleeve to the mating surface. Are there any machine shops in the DFW area that can do this kind of work for a decent price? Thanks Dave emachineshop.com |
I just read an article that said these things are going to be consumerized
soon. Essentially, they take a PC CAD drawing and, using plastic resin, make a 3Dpart. I'm not sure what kind of resin but there are engineering expoxies that can be hardened with a UV LED or laser. My question is will they be useful for homebuilders. I can see making plastic sand cast cores and maybe custom knobs but could they make structural items? Bildan "Judah" wrote in message .. . Dave wrote in news:tDVLi.2948$yc5.2028 @nlpi069.nbdc.sbc.com: I have a friend with a Ercoupe whose steering knuckle/assembly has been worn to where it is too sloppy. It's about 2.20 inches in diameter and rotates on the nose strut assy. It's what the scissors are attach to. It either needs to be bushed or trued up and add a bearing sleeve to the mating surface. Are there any machine shops in the DFW area that can do this kind of work for a decent price? Thanks Dave emachineshop.com |
No, they can't make structural parts. One company demonstrated did
demonstrate the strength of their material by building a skateboard sans trucks, added the trucks and rode it for a bit-no fancy stuff though. You are right about using the printed part for a sandcasting core. One company makes a material specifically for this use. A company in germany makes a 3D printer that uses powdered metal melted by a laser to make parts. I wouldn't trust them for structural purposes either though. However, in all cases, the material isn't cheap!! The 3D printer we use costs just 1.23 a cubic inch for the material, plust cost of the binder (glue), electricity, maintainence, etc would be closer to 3 or 4 bucks a cubic inch. Bill Daniels wrote: I just read an article that said these things are going to be consumerized soon. Essentially, they take a PC CAD drawing and, using plastic resin, make a 3Dpart. I'm not sure what kind of resin but there are engineering expoxies that can be hardened with a UV LED or laser. My question is will they be useful for homebuilders. I can see making plastic sand cast cores and maybe custom knobs but could they make structural items? Bildan "Judah" wrote in message .. . Dave wrote in news:tDVLi.2948$yc5.2028 @nlpi069.nbdc.sbc.com: I have a friend with a Ercoupe whose steering knuckle/assembly has been worn to where it is too sloppy. It's about 2.20 inches in diameter and rotates on the nose strut assy. It's what the scissors are attach to. It either needs to be bushed or trued up and add a bearing sleeve to the mating surface. Are there any machine shops in the DFW area that can do this kind of work for a decent price? Thanks Dave emachineshop.com |
![]() "Richard Riley" wrote in message ... On Tue, 2 Oct 2007 21:27:02 -0600, "Bill Daniels" bildan@comcast-dot-net wrote: I just read an article that said these things are going to be consumerized soon. Essentially, they take a PC CAD drawing and, using plastic resin, make a 3Dpart. I'm not sure what kind of resin but there are engineering expoxies that can be hardened with a UV LED or laser. My question is will they be useful for homebuilders. I can see making plastic sand cast cores and maybe custom knobs but could they make structural items? Bildan This isn't going to help much, but "it depends." The FDM (Fused Deposition Modeling) machine I use at work is usually set up to work with ABS plastic. The parts are pretty fragile, I wouldn't even want to use them for knobs. But it can also work with polycarbonate - lexan - and that's useful. You're not going to make gear legs out of it, but ducts and lids would be fine. OTOH, the same basic concept is used to scinter powdered steel with lasers, or powdered titanium with electron beams. So it's probably just a matter of time. Actually, after I started the thread I realized that I was thinking of wax casting cores. If the 3D printer could make 3D parts out of wax that could be used in 'lost wax' aluminum casting that might indeed be useful. |
The company at http://www.desktopfactory.com/ is starting production
of a relatively inexpensive home 3D printer. If I was not taking flying lessons, I would probably be getting one of these. On Oct 3, 10:18 am, "Bill Daniels" bildan@comcast-dot-net wrote: "Richard Riley" wrote in message ... On Tue, 2 Oct 2007 21:27:02 -0600, "Bill Daniels" bildan@comcast-dot-net wrote: I just read an article that said these things are going to be consumerized soon. Essentially, they take a PC CAD drawing and, using plastic resin, make a 3Dpart. I'm not sure what kind of resin but there are engineering expoxies that can be hardened with a UV LED or laser. My question is will they be useful for homebuilders. I can see making plastic sand cast cores and maybe custom knobs but could they make structural items? Bildan This isn't going to help much, but "it depends." The FDM (Fused Deposition Modeling) machine I use at work is usually set up to work with ABS plastic. The parts are pretty fragile, I wouldn't even want to use them for knobs. But it can also work with polycarbonate - lexan - and that's useful. You're not going to make gear legs out of it, but ducts and lids would be fine. OTOH, the same basic concept is used to scinter powdered steel with lasers, or powdered titanium with electron beams. So it's probably just a matter of time. Actually, after I started the thread I realized that I was thinking of wax casting cores. If the 3D printer could make 3D parts out of wax that could be used in 'lost wax' aluminum casting that might indeed be useful. |
Machine shop information needed. | Dave[_16_] | Owning | 8 | October 14th 07 04:16 AM |
deHavilland Devon VP 979 Information needed | [email protected] | General Aviation | 0 | July 8th 06 01:29 PM |
Pirep needed for Gulf Shores (JKA) Paint Shop | David | Owning | 0 | July 1st 04 02:12 PM |
CH/MH-53E information needed - Maintainers? | Sherman C | Rotorcraft | 0 | June 27th 04 02:17 AM |
NEEDED: Aircraft Ground Handling Information | Jarry Clausing | Products | 0 | August 9th 03 03:24 PM |
