Hard Water Deposits
Old October 10th 07, 12:24 AM posted to rec.aviation.soaring
Default Hard Water Deposits
The only negative thing I can think about when flying from Moriarty,
NM is that unless you want to spend big bucks on distilled water, you
have to use the local stuff which leaves hard water deposits on the
glider.
Does anyone have any good solutions, (yes, pun intended) for this
problem?
Zulu
Old October 10th 07, 12:34 AM posted to rec.aviation.soaring
Kloudy via AviationKB.com
Someone once mentioned that dish spot stuff can help with hard-water spotting.
"Jet-dry" I think it is.
I've used it when I would hand-wash my car when I was a kid. Seemed to help
with reducing spotting. But our water was not as hard back east.
glider.
problem?
Zulu
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...aring/200710/1
Old October 10th 07, 01:01 PM posted to rec.aviation.soaring
Fabric softener (for doing laundry) works great. Just put 1-2 cap-
fulls in the wing tanks and fill as normal with water ballast
Steve (PSU)
Old October 10th 07, 02:19 PM posted to rec.aviation.soaring
Steve (PSU)
I've got the same problem and have also considered what the deposits
are doing to the water meter. Maybe there could be a water filter
added to the supply side of the meter. Other than the meter I'll bet
the fabric softener would do the trick for the glider and the valves
etc. I used to use that in my swamp cooler and it worked great for
that too.
Bob
Old October 10th 07, 08:20 PM posted to rec.aviation.soaring
Andy[_1_]
glider.
problem?
Zulu
When there was still water at Estrella it was very salty. The
solution there was to fill a tranfer tank, add a cup of white vinegar,
and then transfer to the glider. The salts settle in the bottom of
the transfer tank and have to be cleaned out later.
Other pilots wipe down the glider as soon as they land and that seems
to help.
Andy
Old October 10th 07, 08:30 PM posted to rec.aviation.soaring
Steve (PSU)
Adding a pint of glycerine/soap solution each side also
produces amazing results ;-)
See ya, Dave "YO"
Old October 11th 07, 04:55 PM posted to rec.aviation.soaring
Herb
Steve (PSU)
See ya, Dave "YO"
Thanks Steve and Dave,
How to I get the fabric softener goo into the LS8 through the dump
openings that also serve to fill the wings? Well, I got the entire
winter here in Chicago to figure it out...
Herb
Old October 12th 07, 01:55 PM posted to rec.aviation.soaring
I fly Schempp-Hirth Hardware so it is easy to just pour the fabric
softener into the wing tanks. If that option is not available to you,
why not just pour the fabric softener straight from the bottle into
your garden hose? Then simply connect the hose to the supply and
start fillling. Repeat for wing two.
Steve (PSU)
SATANIC AMERICA - 911 "truthers" don't want to address the hard evidence like the clear as day video of steel running like water from the WTC towers, for, as Humanity witnesses, they'd rather watch silently, children murdered indiscrimi Ian MacLure Naval Aviation 0 April 25th 07 06:11 AM
winter is hard. Bruce Greef Soaring 2 July 3rd 06 06:31 AM
It ain't that hard Gregg Ballou Soaring 8 March 23rd 05 01:18 AM
Water, water, everywhere, but none for thirsty wings.... Chris OCallaghan Soaring 0 November 21st 04 03:14 PM
Who says flying is hard? Roger Long Piloting 9 November 1st 04 08:57 PM
