AIRCRAFT IGNITION SYSTEM
Old October 15th 07, 08:59 AM posted to rec.aviation.homebuilt
Default AIRCRAFT IGNITION SYSTEM
From the blogs archive http://ma3naido.blogspot.com/2007/10...-altitude.html
The ignition system provides the spark that ignites the fuel/air
mixture in the cylinders and is made up of magnetos, spark plugs, high-
tension leads, and the ignition switch.
Exhaust Gas Discharge Waste Gate
This controls the amount of exhaust through the turbine. Waste gate
position is actuated by engine oil pressure.
Turbo charger
The turbo charger incorporates a turbine, which is driven by exhaust
gases, and a compressor that pressurizes the incoming air.
Throttle Body
This regulates airflow to the engine.
................. continued on http://ma3naido.blogspot.com/2007/10...-altitude.html
System Operation of Aircraft System [email protected] Instrument Flight Rules 1 October 12th 07 06:50 AM
Screw It's Aircraft Tie Down System User Home Built 20 November 28th 06 05:31 PM
Fire protection system for homebuilt aircraft [email protected] Home Built 0 February 22nd 05 12:57 AM
FA: AIRCRAFT/RACE CAR HALON FIRE EXT SYSTEM N329DF Aviation Marketplace 0 August 16th 03 03:11 PM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
