What's Inside Aircraft Jumper Cables?
Old October 18th 07, 02:24 PM posted to rec.aviation.piloting
Paul Dow (Remove Caps in mail address)
Default What's Inside Aircraft Jumper Cables?
A friend of mine has some very nice aircraft auxiliary power cables, and
he was going to take it apart and remove the insulation for the scrap
copper. After seeing how nice it is (4/0 stranded cable), he put it back
together, but he noticed something strange. Inside the plug connector
was a 50 ohm resister in series with a diode connected across the two
cables. Copper pins were inserted into the braided wire to make the
connection.
Does anyone know what that is for?
Thanks
Old October 18th 07, 04:17 PM posted to rec.aviation.piloting
Eduardo K.
connection.
Reverse polarity protecion? Connect it wrong and diode shorts and fuse
upstream blows?
Eduardo K. | Darwin pone las reglas.
http://www.carfun.cl | Murphy, la oportunidad.
http://ev.nn.cl |
| Yo.
Old October 18th 07, 04:46 PM posted to rec.aviation.piloting
GeorgeB
On Thu, 18 Oct 2007 15:17:33 +0000 (UTC), Eduardo K.
connection.
upstream blows?
I'd guess either a zener or transzorb with 50 ohms to limit current?
50 ohms, 25 volts, 0.5 amp ...
Old October 18th 07, 06:31 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 18 Oct 2007 09:24:42 -0400, "Paul Dow (Remove Caps in mail
address)" wrote in
connection.
Thanks
It sounds like a surge suppressor or snubber circuit to me.
Old October 19th 07, 04:28 PM posted to rec.aviation.piloting
That seems to make sense. I wasn't familiar with snubber circuits, nor
even the word snubber, until I looked it up now. You wouldn't want the
voltage spike hitting the aircraft when plugging in the outside power,
so that probably limits the rate of voltage change.
I don't think it protects against reverse polarity since it doesn't look
like something that gets replaced easily if it breaks. The parts are
quite small for current limiting too.
Thanks everyone.
I'll put it back in.
FS: Piper Jumper Cables Video Man Aviation Marketplace 1 January 29th 07 12:27 AM
Request: RT459 14V illumination jumper settings mikem Owning 0 October 17th 06 04:37 PM
FA: Piper Aircraft Booster Cables Sk8hard Aviation Marketplace 0 June 13th 06 09:04 PM
Gen Jumper praises Eurofighter John Cook Military Aviation 6 July 22nd 04 04:37 PM
MiG-29 cables alcatraz Military Aviation 0 March 1st 04 10:01 PM
