Pressure & temperature
Old October 21st 07, 01:57 AM posted to rec.aviation.ifr
Terence Wilson
Default Pressure & temperature
I'm confused about what determines the local altimeter setting. My
understanding is that there is a barometer in the tower that measures
the weight of a column air extending up into the atmosphere. What
factors affect its weight? Is it purely temperature variations caused
by uneven heating by the Sun or is there something else?
In a similar vein, I understand that winds are caused by pressure
discrepancies which lead to winds moving from high to low pressure
areas. Again, are the pressure differences caused by temperature only?
Thanks.
Old October 21st 07, 03:12 AM posted to rec.aviation.ifr
Andrew Sarangan
Thanks.
Uneven solar heating is the primary cause of all weather on earth.
There could be other sources, such as fluctuations in the earth's
magnetic field and gravity of the moon, but solar heating is the
primary source.
Old October 21st 07, 09:51 AM posted to rec.aviation.ifr
Bee
Thanks.
primary source.
What about varying ocean temperatures?
Old October 21st 07, 06:55 PM posted to rec.aviation.ifr
Andrew Sarangan
Thanks.
primary source.
What about varying ocean temperatures?- Hide quoted text -
Oceans are heated by the sun. This is why oceans near the equator are
warmer than at higher lattitudes. However, there could bea minor
effect from underwater volcanoes which are not directly related to the
sun, at least not since the earth separated from the earth billions of
years ago.
H2O, O2, Nutrients, Temperature Stewart Kissel Soaring 0 January 27th 07 05:35 PM
OT? National Gas Temperature Map Dave Piloting 0 January 21st 07 11:28 PM
Outside air temperature probe dlevy Owning 9 November 7th 06 05:14 PM
'Room Temperature' Anthony Home Built 11 August 23rd 04 07:36 PM
temperature sensor Philippe Vessaire Home Built 2 March 3rd 04 03:37 AM
