I have owned two LS1-F gliders. Both have factory wingroot
fillets. I would like to talk to other LS1-F owners that have the same factory fillets. Thanks, Sam |
On Nov 10, 9:55 am, Sam Giltner
wrote: I have owned two LS1-F gliders. Both have factory wingroot fillets. I would like to talk to other LS1-F owners that have the same factory fillets. Thanks, Sam Sam, Have you flown an "f" without the fillets? If so, what is the difference in handling? By the way, did you end up keep your "f"? |
On Nov 11, 2:55 am, Sam Giltner
wrote: I have owned two LS1-F gliders. Both have factory wingroot fillets. I would like to talk to other LS1-F owners that have the same factory fillets. Thanks, Sam Sam, I fly an LS1f in Australia for the past year. It has the factory fillets which are rather small and I suspect do not contribute too much, but then I would have to cut them off to find out for sure. I have a very nose heavy glider and even at a low cockpit weight and lead in the tail I can still only manage about 75% to the rear of the CG range. I provide this info as I think it contributes more to the slow speed thermal handling than the fillets do. Yesterday while pulling tight at 50deg bank in a thermal with 9.4knots on the averager (sorry could not help brag) I was getting the stick shake I belive from the turbulent air hitting the tail. Pull any more at this point and she just gives up flying and drops the nose dramatically. My old Libelle would politely say please don't do that but it would just hang in the turn and let you get away with it. The extra lead in the tail improved the point at which it all drops away but I am keen to try some turbulator tape under the wing at 60% and also some small bits of tape on the fuz and wing top high point in front of the fillet junction. I am liking the LS1f more each time I fly it but I do miss the Libelle's ability to haul around in a thermal core without dropping off the left margin of the polar curve. Anything I can do to improve this on the LS1f , and I am very interested. Scott |
