Carrier Islands
Old November 16th 03, 07:15 AM
Thomas W Ping
Default Carrier Islands
Are there aviation-related reasons why the starboard side is favored
for the island, or is it a purely naval issue? If the latter, did the
practice come about because the first pioneering carriers were
arbitrarily drawn up that way and the configuration simply stuck as a
matter of tradition, or were there more significant reasons for the
convention?
Thomas Winston Ping
Old November 16th 03, 02:17 PM
Pierre-Henri Baras
AFAIK it's mainly because landing approaches (both land & sea) include a
final left turn. If the islands were on the port side of the ship the LSO
would loose sight of the plane (blocked by the island) and the pilote would
loose sight of the deck for a second or two, and that's enough to have a
major screw-up.
Any other explanation??
_________________________________________
Pierre-Henri BARAS
Co-webmaster de French Fleet Air Arm
http://www.ffaa.net
Encyclopédie de l'Aviation sur le web
http://www.aviation-fr.info
"Thomas W Ping" a écrit dans le message de news:
convention?
Thomas Winston Ping
Old November 16th 03, 03:11 PM
William Hughes
On Sun, 16 Nov 2003 15:17:32 +0100, in rec.aviation.military "Pierre-Henri
convention?
major screw-up.
Remember, the LSO was stationed behind the island, so losing sight of the
aircraft was not a problem.
Early piston aircraft had a lot of torque generated by the engine. In a wave-off
situation, the sharp increase in power would roll the aircraft slightly to port.
Combined with pulling back on the stick to gain altitude, this would result in a
climbing left turn. Having an island in the way when doing this could ruin your
whole day. Hence, the island was placed on the other side of the filght deck.
Old November 16th 03, 09:37 PM
Cub Driver
If so, then British carriers would have the island to port. Do they?
all the best -- Dan Ford
email: (put CUB in subject line)
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old November 16th 03, 11:04 PM
William Hughes
On Sun, 16 Nov 2003 16:37:15 -0500, in rec.aviation.military Cub Driver
Why would they? Their aircraft engines rotated in the same direction as the
American's, thus generating the same port-biased torque.
Old November 17th 03, 10:44 AM
Cub Driver
No, British aircraft engines turned the other way. Still do, I
believe.
They famously emasculated the Lightning by burdening it with two
left-turning engines.
Old November 17th 03, 03:22 AM
So what does one do in an a/c which has an engine turning the
opposite way?...
-Gord.
Old November 17th 03, 04:01 AM
William Hughes
On Mon, 17 Nov 2003 03:22:34 GMT, in rec.aviation.military "Gord Beaman"
opposite way?...
And which aircraft would that be? AFAIK, all aircraft engines rotated the same
way - clockwise from the pilot's point-of-view. At least on single-engine birds;
some twins may have had counter-rotating props, but I don't think they operated
from carrier decks all that much.
Old November 17th 03, 04:07 AM
Tarver Engineering
"William Hughes" wrote in message
wave-off
to port.
result in a
ruin your
deck.
opposite way?...
same
birds;
operated
What, like a P-3?
Old November 17th 03, 05:30 AM
opposite way?...
You think so?...amazing indeed...you sound most assured...I'd
have felt damned uneasy if it had been me making that big bald
statement to the whole world. WooHoo.
-Gord.
B-29s & P-51s Strike Japan plus "Carrier Franklin" at Zeno's Drive-In zeno Home Built 1 October 4th 04 11:19 PM
B-29s & P-51s Strike Japan plus "Carrier Franklin" at Zeno's Drive-In zeno Instrument Flight Rules 0 October 4th 04 05:32 PM
Can the F-14 carry six AIM-54s and land on carrier? Matthew G. Saroff Military Aviation 1 October 29th 03 08:14 PM
C-130 Hercules on a carrier - possible ?? Jan Gelbrich Military Aviation 10 September 21st 03 04:47 PM
launching V-1s from an aircraft carrier Gordon Military Aviation 34 July 29th 03 11:14 PM
