Sears Tools
Old November 16th 07, 04:15 PM posted to rec.aviation.rotorcraft
Stuart & Kathryn Fields
Default Sears Tools
I recently purchased the Sears "Professional" Lithium batteried driver
drills. I purchased two because I was in the process of erecting a metal
building. The batteries and charger worked good but the keyless chuck on
both drills exhibit what I call "Auto Loosen". I have several other keyless
chucks in my shop and none of these exhibit the same characteristics. I
called Sears Customer Service to complain and they told me to visit my local
Sears dealer. The local Sears dealer told me to call Customer Service.
Whoa!! I've been a victim of that before. I will now look for my tool
requirements somewhere else.
Stu Fields
Old December 14th 07, 09:26 AM posted to rec.aviation.rotorcraft
Andrew P.
Default Sears Tools
While I wandered about the Web aimlessly, I heard Stuart & Kathryn
Fields say:
Stu Fields
If the chuck uses a standard thread, can't you put a regular
key-operated Jacobs chuck on the drill instead?
Andrew P.
[Post replies to this message on forum only]
Old December 14th 07, 09:34 PM posted to rec.aviation.rotorcraft
Default Sears Tools
Andrew: I've started looking at McMaster catalog and there are a bunch of
keyless chucks to choose from. I've got three other keyless chucks, one on
a makita cordless and haven't had any problems with them so I was surprised
to experience the "auto loosen" feature found in the Sears units. Yep after
dropping drill bits from on top of the roof and having to get all the way
down to retrieve it, I'm going to switch rather than fight.
The thing that caught my attention the most is the "run around" I received
when I voiced my complaint to Sears. All they would have had to do was
thank me and tell me they were assigning the problem to someone; blow some
smoke up my butt and I would have left thinking that Sears really supports
their customer. But no
Well there are other tool sources.
"Andrew P." null@null wrote in message
While I wandered about the Web aimlessly, I heard Stuart & Kathryn Fields
say:
keyless chucks in my shop and none of these exhibit the same
characteristics. I called Sears Customer Service to complain and they
told me to visit my local Sears dealer. The local Sears dealer told me
to call Customer Service. Whoa!! I've been a victim of that before. I
will now look for my tool requirements somewhere else.
Stu Fields
If the chuck uses a standard thread, can't you put a regular key-operated
Andrew P.
Old December 16th 07, 09:25 PM posted to rec.aviation.rotorcraft
D Peter Maus
Default Sears Tools
I had a similar problem with a B&D keyless. I simply replaced the
chuck with a Jacobs keyless. If you like the drills, this is an
inexpensive solution. I liked the results so much, I replaced the chucks
on all my drills. Cost me less than $100 to do 5 of them.
say:
Stu Fields
Andrew P.
Sears tools Stuart & Kathryn Fields Home Built 36 November 22nd 07 05:09 AM
Tools ORVAL FAIRAIRN Home Built 24 September 12th 05 08:03 PM
BRS and other tools 2Poor2Fly4Real Piloting 1 April 23rd 04 06:41 PM
What tools do you take? Michael Horowitz Owning 31 March 8th 04 02:53 AM
What tools do you take? Michael Horowitz Home Built 14 March 4th 04 02:07 PM
