Busses and braking.
Old November 21st 07, 02:15 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default Busses and braking.
From a friend at Airbus.
It all sounds about right. Also, since it took them so long to close the
thrust levers, I'm guessing this was not a flight crew, but a
maintenance crew. The parking brake is either on or off on that
airplane.
The reference to EPR's of 1.25-ish would pe about 30% of max thrust,
maybe a tad more. Probably enough to get it going with the brakes set on
a wet slippery area.
Subject: FW: A340-600 - MSN 856 - INCIDENT IN PRODUCTION
________________________________
Sent: Tue 20/11/2007 14:46
To: undisclosed-recipients
Subject: A340-600 - MSN 856 - INCIDENT IN PRODUCTION
SUBJECT: A340-600 - MSN 856 - ACCIDENT IN PRODUCTION OUR REF.: F-WWCJ
AIT 2
DATED 20th OF NOVEMBER 2007 PREVIOUS REF: F-WWCJ AIT 1 DATED 16th OF
NOVEMBER 2007
THIS AIT IS AN UPDATE OF PREVIOUS AIT N°1 CONCERNING THE A340-600
PRODUCTION
AIRCRAFT MSN 856 INVOLVED IN AN ACCIDENT IN AIRBUS PRODUCTION FACILITIES
IN
TOULOUSE ON THE 15TH NOVEMBER 2007 AT 17:00 LOCAL TIME.
THE FOLLOWING IS THE SEQUENCE OF EVENTS ACCORDING TO THE RECORDERS,
WHICH
HAS BEEN APPROVED FOR RELEASE BY THE FRENCH INVESTIGATION AUTHORITIES
(BEA).
FOR ABOUT 3 MINUTES BEFORE THE END OF THE EVENT, ALL FOUR ENGINES EPR
WAS
BETWEEN 1.24 AND 1.26 WITH PARKING BRAKE ON AND WITHOUT GROUND CHOCKS.
THE
ALTERNATE BRAKE PRESSURE WAS NORMAL. (WITH PARKING BRAKE ON, BRAKE
PRESSURE
IS SUPPLIED BY ALTERNATE).
13 SECONDS BEFORE THE IMPACT THE AIRCRAFT STARTED TO MOVE. WITHIN 1 OR 2
SECONDS THE CREW APPLIED BRAKE PEDAL INPUTS AND SELECTED PARKING BRAKE
OFF.
THESE ACTIONS LED THE NORMAL BRAKE PRESSURE TO INCREASE TO ITS NORMAL
VALUE.
2 SECONDS PRIOR BEFORE THE IMPACT, ALL 4 ENGINE THRUST LEVERS WERE
SELECTED
TO IDLE.
THE AIRCRAFT IMPACTED THE CONTAINMENT WALL AT A GROUND SPEED OF 30 KTS.
THERE IS NO EVIDENCE OF ANY AIRCRAFT SYSTEM OR ENGINE MALFUNCTION.
AIRBUS REMINDS ALL OPERATORS TO STRICTLY ADHERE TO AMM PROCEDURES WHEN
PERFORMING ENGINE GROUND RUNS
ENGINE GROUND RUNS AT HIGH POWER ARE NORMALLY CONDUCTED ON A SINGLE
ENGINE
WITH THE ENGINE IN THE SAME POSITION ON THE OPPOSITE WING OPERATED AT A
LIMITED THRUST SETTING TO AVOID DAMAGE TO THE AIFRAME
WHEEL CHOCKS ARE TO BE INSTALLED THROUGHOUT THE TEST.
Yannick MALINGE
Vice President Flight Safety
GSE
AIRBUS Central Entity
Phone : +33 (0)5 61 93 43 60
Fax : +33 (0)5 61 93 44 29
This e-mail is intended only for the above addressee. It may contain
privileged information.
If you are not the addressee you must not copy, distribute, disclose or
use
any of the information in it.
If you have received it in error please delete it and immediately notify
sender.
Security Notice: all e-mail, sent to or from this address, may be
accessed
by someone other than the recipient, for system management and security
reasons. This access is controlled under Regulation of security reasons.
This access is controlled under Regulation of Investigatory Powers Act
2000,
Lawful Business Practises.
Old November 21st 07, 03:04 PM posted to rec.aviation.piloting
Darkwing
airplane.
snip
It is interesting that they recommend running the engine on the opposite
wing to avoid possibly damaging the airframe. Sounds like a rush job caused
this incident, no wheel chocks, running all engine at once. As my grandpa
told me a long time ago, "Haste makes waste."
Old November 21st 07, 05:50 PM posted to rec.aviation.piloting
Jim Stewart
airplane.
Before or after the crash?
The speculation over on pprune was that the
engine controls were sheared along with the
cockpit, leaving no way to shutdown the engines.
One of them ran for several hours before burning
off all the fuel.
It seems amazing that everything needed to
keep the engine running would still be intact
with the cockpit hanging by a few threads.
Wouldn't generators, fuel pumps and/or FADEC
shut the engine down with such a mess?
AIT 2
NOVEMBER 2007
PRODUCTION
IN
WHICH
(BEA).
WAS
THE
PRESSURE
OFF.
VALUE.
SELECTED
TO IDLE.
ENGINE
Yannick MALINGE
GSE
use
sender.
accessed
2000,
Old November 21st 07, 06:23 PM posted to rec.aviation.piloting
Jim Stewart wrote in
the thrust levers, I'm guessing this was not a flight crew, but a
airplane.
They disengaged it and used the toe brakes 11 seconds before impact.
off all the fuel.
Entirely possible.
All the engine needs is fuel.
Nope. All you need is a running engine to keep an engine running.
I hadn't heard that the engine was still running, though.
Remember, anyone can post on PPrune, just like here.
Bertie
Old November 21st 07, 09:43 PM posted to rec.aviation.piloting
Robert M. Gary
airplane.
On the 737 pressing the toe brakes pops the parking brake off. Could
be the same on the Airbus.
-Robert
Old November 21st 07, 10:35 PM posted to rec.aviation.piloting
Dale[_3_]
That's common on multi-engine aircraft. Side-loading the nosewheel is
one thing you want to avoid.
Old November 22nd 07, 12:20 AM posted to rec.aviation.piloting
Bertie the Bunyip's more handsome brother via AviationKB.com
use any of the information in it.
Bunyip, you're a hoot.
Message posted via http://www.aviationkb.com
Old November 22nd 07, 06:43 AM posted to rec.aviation.piloting
"Robert M. Gary" wrote in
close the thrust levers, I'm guessing this was not a flight crew,
but a maintenance crew. The parking brake is either on or off on
that airplane.
No, it isn't. The brakes are a different system completely on the 'bus. The
737's (and in fact all Boeings) is very similar to the Cessna's system as
far as the pilot is concerned. The bus uses a different hyddraulic system
for th eparking brake and it's almost completely independent of the toe
brakes.
Besides, they weren't an issue in this accident.
Bertie
"Bertie the Bunyip's more handsome brother via AviationKB.com" u33403@uwe
wrote in news:7b917a5a932cd@uwe:
I know..
Bertie
PH-GRD braking through the clouds. smaller file AND yEnc-ed Bert-Jan[_5_] Aviation Photos 2 October 6th 07 07:34 PM
PH-GRD braking through the clouds. - 1 attachment (1/8) Herman Aviation Photos 4 October 6th 07 06:18 PM
PH-GRD braking through the clouds. - 1 attachment - Breaking through_lo res.jpg (0/1) Tuomas Aviation Photos 1 October 3rd 07 03:20 PM
Braking in new breaks karl gruber[_1_] Owning 12 July 3rd 07 12:21 PM
An elementary landing / braking doubt Ramapriya Piloting 14 December 26th 04 10:45 PM
