Helicopter trailer
Old November 25th 07, 01:12 AM posted to rec.aviation.rotorcraft
Stuart & Kathryn Fields
Default Helicopter trailer
Is there anyone out there? I have been dissatisfied with my trailer that
I'm using to haul my 1,000 # helicopter around. It is basically a car
hauler that I've stripped the springs down to 1 1/2 leaves and put soft car
tires on it to make the ride a bit softer. Even with the reduced springs, a
4,000 # car didn't bottom out the springs. I also want to be able to fly on
and off the trailer. In the desert this is a big dirt avoider. With the
reduced springs I have had 4 spring failures to date and because it is
always the trailing spring, it has just been a nuisance and hasn't caused
any damage. I've been thinking about designing my own trailer using torsion
bars that is designed just for the helicopter and not a general case utility
trailer.
I had a chance encounter with the president of Kendon Industries. This
company makes ATV and Motorcycle trailers. They are interested in possibly
pursuing a design for a trailer that could be used to haul the helicopters
and provide a soft ride. I'm attaching some of the points to consider in
hopes that someone out there might read this and have some good ideas.
1. Function - land on or load the helicopter in some alternate way? (I'm
biased toward flying on and off with a winch backup)
2. Length - overhang or no overhang? (I want enough overhang for a blade
support structure. I tow with blades installed)
3. Weight capacity - 2,000 lbs? 3,000 lbs? More? (2,000 # limit would
suit me)
4. Accessories - boxes, winches, built in tie down straps and in what
locations, security system, etc? (I can handle this on my own)
5. Purpose - is this best to be a "helicopter-only" trailer, or should it be
appropriate for alternate uses? (I want a trailer designed specifically for
the helicopter)
6. Optimal price?(Less than $4k?)
7. Deck height limitations or preferences? (Accomodate at least a 14" tire)
8. If we could accomplish most of the desired preferences, how likely would
you be to purchase such a trailer? (I want one and will design and build my
own if I can't find an acceptable one)
Other ideas???
Old November 25th 07, 03:36 PM posted to rec.aviation.rotorcraft
Thanks Steve. You've got some good ones and I think that you must have
thought about this sort of thing before. I'm definitely interested in the
tandem axle configuration and yes the ability to winch aboard is a must in
case you have some malfunction thatkeeps you from being able to hover the
bird. I'm thinking of fold down sides that in the vertical position provide
some road scrap protection and in the down position provides some
psychological assistance when flying on and off. Now the factory has just
put a plywood base on the back of their pickup and land the helicopter on it
facing back with the tail boom sticking out over the hood of the truck.
Then the trailer they tow is their camp trailer. This works pretty good for
them but the landing is a bit testy and is made much easier with someone
helping out.
Overhang. I've towed over 100,000 miles going to events in Ohio, Wisconsin,
and Oklahoma with my tailboom sticking out quite a ways beyond the aft end
of the trailer. I had a lite bar with a flashing amber lite mounted near
the end of the tailboom. Don't like the additional mass out there with the
bouncy roads. This would never work for the Rotorways, or the R-22s with
their more fragile tailbooms.
"Steve R" wrote in message
Hi Stuart & Kathryn,
I'll just add some comments/opinions to get this one going. Sounds like
you've got a worthwhile project going here.
"Stuart & Kathryn Fields" wrote in message
possibly pursuing a design for a trailer that could be used to haul the
helicopters and provide a soft ride. I'm attaching some of the points to
consider in hopes that someone out there might read this and have some
good ideas.
I think setting the trailer up to load either way is the best way.
Landing on the trailer would seem to be the most simple way of getting
there, assuming you're flight skills are up to it! ;-) However that
might not always be practical so having some way to winch the bird on is a
definite must. I'm assuming you've got some kind of wheel system employed
so you can move it around on the ground?
Personally, I think overhang, definitely! For one thing, if you're going
to trailer the helicopter with blades installed, you'll needed the added
structure to support them. Beyond that, I wouldn't want "any" part of the
bird sticking out beyond the structure of the trailer when some idiot in
his "monster truck wannabe" can hit it. I know that makes for a really
long trailer but it would make me feel better!
suit me)
I would think that the 2000 # limit would do. Designing the trailer
around a load limit of 2x the expected load weight gives you some reserve
capacity to play with in case you want to add features later, which I
imagine you'll probably do as you refine the system with experience.
Running the trailer at or near it's maximum load all the time is asking
for problems but springing it for too much more than the expected load
might add to the "rough ride" problem you mentioned.
I think these things are a given.
be appropriate for alternate uses? (I want a trailer designed
specifically for the helicopter)
You know the old saying, "Jack of all trades but master of none!" You're
hauling a "helicopter" on a trailer for crying out loud! How many people
do that? I'd design the trailer around the bird. Do anything and
everything you can to maximize the security of the helicopter. I imagine
you'll still be able to haul "stuff" on the trailer when the helicopter's
not on it but considering the investment you've got in the aircraft, it's
security should obviously be the priority. Have you considered a dual
axle design?
I don't know what the company you mentioned would charge for a project
like this. I can tell you that I know some folks who designed and built
from scratch a full length trailer for a Rotorway Exec for significantly
less than $4k. I'll have to ask what the total price was.
tire)
I would think that you'd want the height as low as possible for stability
reasons while towing. However, if you're going to land on the trailer
then you'll need as much width as you can get so keeping the landing deck
above the tires may be a necessity. I'm not sure what to say on this one.
How tall is the helicopter and will it cause problems with roadway
overpasses while on the trailer? This may be a totally moot point but I
can't help but wonder!.
would you be to purchase such a trailer? (I want one and will design and
build my own if I can't find an acceptable one)
"If" I had an experimental helicopter and needed a way to transport it on
the ground, and the preferences noted were met, I'd definitely consider
it. I know that probably most of my answers are pretty obvious ones but
hopefully they'll help you get the conversation started!
Good luck,
Steve R.
Old November 26th 07, 08:35 PM posted to rec.aviation.rotorcraft
Maxwell
"The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in
message news
On Sat, 24 Nov 2007 17:12:11 -0800, "Stuart & Kathryn Fields"
Perhaps something akin to how off road cars/trucks are built, i.e. low
spring rates, high rates of damping.
I'm envisioning something using coil overs, but those tend to be
pretty long so the trailer might sit higher than you'd like.
Maybe use torsion bars instead of traditional springs? I know a lot
of race car trailers use this setup - as do we with our sims in a
trailer - with good result.
Perhaps the folks at Carson Trailer (They're in L.A.) can help with
some basics for a "roll your own" rig...
Maybe heavy trailer frame and light springs. Perhaps springs designed for
less weight, like a boat trailer. I have seen former boat trailers used to
haul ultralights with good results.
I always thought a boat trailer with a telescoping tongue might be good for
a rotor craft. Chock the wheels, pull a pin, and pull forward. You could
park your RV almost a full trailer length away, and never disconnect the
trailer.
Old November 26th 07, 11:02 PM posted to rec.aviation.rotorcraft
Maxwell that is the first time I've heard that idea and it is sure going
into my stew pot. With the trailer length that I'm thinking about being as
long as the helicopter from tailboom to blade tip, it would have room for a
very long telescoping tongue.
Thanks...Stu
"Maxwell" wrote in message
message news
for a rotor craft. Chock the wheels, pull a pin, and pull forward. You
could park your RV almost a full trailer length away, and never disconnect
the trailer.
Old November 26th 07, 11:41 PM posted to rec.aviation.rotorcraft
Maxwell
as long as the helicopter from tailboom to blade tip, it would have room
for a very long telescoping tongue.
Thanks...Stu
Glad to help. I hope to employ the feature myself someday.
Old December 2nd 07, 09:59 PM posted to rec.aviation.rotorcraft
D Peter Maus
trailer.
suit me)
the helicopter)
Other ideas???
Call Ken at Sun Aero Helicopters in Lansing, Illinois. He had one
built for the 206L to haul it to Nascar events. It's fit to the bird,
with supports for the MR blades to prevent flapping in transport, tie
downs, proper suspension, and lift to permit backing up the truck for
hitching.
Ken can fill you in on the structural parameters, and operational
considerations.
My thoughts would be not to do this too cheaply. You've got a
sizeable investment in your aircraft. Cheaping out on the transport
could be your most expensive mistake.
Old December 3rd 07, 04:27 PM posted to rec.aviation.rotorcraft
Peter: Thanks for the contact. I am sure not going to cheap out on the
trailer. I've got way too much time and money invested in the helicopter
and for sure don't want it wrecked due to a pitiful trailer.
Thanks again for the contact.
"D Peter Maus" wrote in message
car tires on it to make the ride a bit softer. Even with the reduced
springs, a 4,000 # car didn't bottom out the springs. I also want to be
able to fly on and off the trailer. In the desert this is a big dirt
avoider. With the reduced springs I have had 4 spring failures to date
and because it is always the trailing spring, it has just been a nuisance
and hasn't caused any damage. I've been thinking about designing my own
trailer using torsion bars that is designed just for the helicopter and
not a general case utility trailer.
good ideas.
suit me)
tire)
Other ideas???
Call Ken at Sun Aero Helicopters in Lansing, Illinois. He had one built
for the 206L to haul it to Nascar events. It's fit to the bird, with
supports for the MR blades to prevent flapping in transport, tie downs,
proper suspension, and lift to permit backing up the truck for hitching.
considerations.
My thoughts would be not to do this too cheaply. You've got a sizeable
investment in your aircraft. Cheaping out on the transport could be your
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 07:50 PM
aero-domains for helicopter pilots and helicopter companies secura Rotorcraft 0 June 26th 04 07:33 AM
Helicopter Trailer John P. Kelly Rotorcraft 2 April 3rd 04 04:14 AM
JAG Helicopter Video, Rinke Aerospace, Spy Photos, JAG Helicopter, Helicopter, Black Ops Dennis Chitwood Rotorcraft 4 January 10th 04 05:34 PM
