New winch height record
Old November 25th 07, 05:24 PM posted to rec.aviation.soaring
Bill Daniels
Default New winch height record
From Europe:
________________________________________________
"On Sun, November 25, 2007 9:31 am, peternarinx wrote:
Yesterday, on the airfield of Weelde ( EBWE) in Belgium, Peter
Mink reached 1718m AGL with an ASK21 and a Mel winch."
"The length of the runway is 3100m including the grass at both ends
and the winch is on the ground. You can see the airfield on google
earth 51 23 48 N , 04 37 77 E. They said that the conditions were
not optimal yesterday......."
_________________________________________________
1718 meters is 5,636 feet AGL. The runway length is 3100 meters or 10,170
feet.
With the new light weight UHMWPE winch rope and a modern high performance
winch, great heights can be achieved.
Bill Daniels
Old November 25th 07, 09:27 PM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
A typical winch launch yeilds about 1/3 of the runway/field available, this is a fantastic result, Bill!
Perhaps we should be measuring the launch as a percentage of field length, then there would actually be a record available for everyone to shoot for, regardless of locality.
So...
With a runway of 3100m and a launch of 1718, the current known record is 55.42%
Get out there and break it!!
bagger
Old November 25th 07, 11:53 PM posted to rec.aviation.soaring
BT
how many glider club or commercial operations have 10,000ft of "runway"
available.
granted.. for most 4000ft runways.. it could prove very beneficial
BT
"Bill Daniels" bildan@comcast-dot-net wrote in message
From Europe:
10,170 feet.
Bill Daniels
Old November 26th 07, 12:22 AM posted to rec.aviation.soaring
Nyal Williams
These coordinates put me on the bridge next to the
Eiffel Tower. I cut and pasted.
At 17:24 25 November 2007, Bill Daniels wrote:
From Europe:
_______________________________________________ _
Peter
Mink reached 1718m AGL with an ASK21 and a Mel winch.'
'The length of the runway is 3100m including the grass
at both ends
on google
were
not optimal yesterday.......'
_______________________________________________ __
feet.
high performance
Bill Daniels
Old November 26th 07, 12:28 AM posted to rec.aviation.soaring
Bill Daniels
Try: 51°23'42.85"N 4°57'41.54"E
Bill Daniels
"Nyal Williams" wrote in message
From Europe:
Peter
at both ends
on google
were
________________________________________________ _
feet.
high performance
Bill Daniels
Old November 26th 07, 02:38 AM posted to rec.aviation.soaring
Bill Daniels
George Moore of Spokane, WA has developed some very convincing math that
says 50% of the initial rope length should be possible as release height
under no wind conditions.
As you go to longer ropes, the percentage used for ground roll and rotation
into the climb becomes less and as you get higher, you may encounter higher
headwinds which also adds to release height. I would expect higher
percentages simply due to longer ropes.
All this depends on several things. Using Spectra or Dyneema rope which is
10 - 12% the weight of steel cable for a given strength, using adequate
power to maintain a rope tension of 1 to 1.5 x glider weight and managing
that tension precisely with a computer.
In this case, they used an ASK-21 which specifies a black 2200 pounds-force
weak link. This allows a lot of power to be transfered to the glider.
Apparently it was flown solo which means a tension factor of ~1.5 x weight
was possible.
All very technical, of course. Where it's a game changer is training,
particularly glider aerobatic training. An aero tow to 1700 meters is way
over 100 Euro. The winch launch was probably less than 10 Euro.
I like to think of quietly lobbing an instructor with a pre-solo student up
over a vertical mile at 6AM for 40 minutes of instruction in glassy smooth
air.
Bill Daniels
"bagmaker" wrote in message
So...
is 55.42%
bagger
bagmaker
Old November 26th 07, 02:51 AM posted to rec.aviation.soaring
Todd
In my corner of the soaring world, we have lots of 1 mile by 1 mile
fields (section lines) so the diagonals area bit under 7500 ft. Still
might be good for an almost 4000 ft launch. Any friendly farmers out
there?
Old November 26th 07, 03:30 AM posted to rec.aviation.soaring
What is a Mel winch?
What does UHMWPE mean?
Michael
Bill Daniels wrote:
From Europe:
feet.
Bill Daniels
Old November 26th 07, 03:35 AM posted to rec.aviation.soaring
Michael
Bill Daniels wrote:
From Europe:
feet.
Bill Daniels
Old November 26th 07, 03:41 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Picture he
http://www.machinefabriek-el.nl/content_6.asp
Ultra High Molecular Weight PolyEthylene
Marc
How to get maximum height on a winch launch? Dan G Soaring 38 December 22nd 16 12:29 AM
Winch launch speed versus height gain Neil Soaring 20 November 9th 07 12:57 AM
Record Highs/Record Lows Jay Honeck Piloting 12 October 12th 06 01:27 AM
Perlan height record in Argentina Charles Yeates Soaring 3 September 1st 06 12:59 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
