WinPilot Themal marker
Old December 3rd 07, 04:39 AM posted to rec.aviation.soaring
Peter[_5_]
Default WinPilot Themal marker
I am using WinPilot Advanced and wondered if it is possible to mark a thermal
waypoint on the fly. Reason I ask is that in a recent contest I flew through a
good thermal a few miles from the next turnpoint. I made the turnpoint and
thought I had flown back to where the lift was. Checking my igc file I see I
was a long way off. If I could have marked the good spot (blue thermal) before
hitting the TP I might not have ended up in a paddock.
I know about the Thermal database feature but I want something like the "Man
Overboard" feature on some Garmin type GPS units.
Old December 3rd 07, 05:28 AM posted to rec.aviation.soaring
Tim Taylor
Peter,
Not sure in advanced if there is function that will work. Do you have
your Trace function "ON"? That will at least get you back to the
track you came into the TP on. In Pro I use the trace function with
the lift dots. I just do a pull in the lift as I go through and it
leaves a nice magenta dot to go back to. Without the function Pro
lift dots you can at least do one 360 with the trace function on or
even an S turn should be enough to mark the spot.
My Colibri has the mark event button so I can hit that as well to get
me back to a specific point in a flight.
I find the Trace with lift dots one of the features I use very often
in WinPilot Pro. I have often done what you are talking about on an
into the wind turnpoint.
Old December 3rd 07, 05:57 AM posted to rec.aviation.soaring
P. Corbett
Peter
In WinPilot Advanced, go to MENU/EDIT. From there, you can assign MARK
POSITION to one of the front buttons.
Paul
Old December 3rd 07, 03:40 PM posted to rec.aviation.soaring
Richard[_1_]
Peter,
The trace function in ADV will trace your track. If you have an
especially good thermal that you want to mark assign one of the front
buttons to the Mark POSition. This will put a O on your trace
track.
It will also put an O on the screen if the trace is OFF.
A button or menu item can be assigned by starting the SIM Go Menu
touch edit at the lower left, then the button below and select the
function from the drop down box. The four buttons below designate the
buttons on the front of the ipaq.
Thanks ,
Richard
www.craggyaero.com
Middle Marker minimums S Herman Instrument Flight Rules 5 June 9th 05 05:28 PM
KR-21 marker beacon pinout JFLEISC Owning 1 March 18th 04 02:23 PM
Outer Marker Barry Instrument Flight Rules 35 March 5th 04 11:07 PM
WinPilot Offers Free WinPilot XP for your Desktop Computer Richard Pfiffner Soaring 0 November 8th 03 04:44 PM
marker beacon Gary Gunn Instrument Flight Rules 5 November 3rd 03 05:20 PM
