Shock! Hana's Diana 2 in service
Old December 5th 07, 09:46 AM posted to rec.aviation.soaring
Andrzej
Default Shock! Hana's Diana 2 in service
You can see pictures of Hana's glider Diana 2 and her "modifications":
http://www.gorpol.pl/powiekszenie.php?id=2817
http://www.gorpol.pl/powiekszenie.php?id=2818
http://www.gorpol.pl/powiekszenie.php?id=2819
http://www.gorpol.pl/powiekszenie.php?id=2820
http://www.gorpol.pl/powiekszenie.php?id=2821
http://www.gorpol.pl/powiekszenie.php?id=2822
http://www.gorpol.pl/powiekszenie.php?id=2823
http://www.gorpol.pl/powiekszenie.php?id=2824
....and whole article from polish service in Bielsko-Biala:
http://www.gorpol.pl/?site=80&artykul=288
No comments needed.
Andy
Old December 5th 07, 10:24 AM posted to rec.aviation.soaring
Jose Jimenez
Could somebody provide a rough translation? My Polish is less than
perfect, and without the comments, I can't interpret the pictures. (And
Babeljoke can't Polish, either.)
Old December 5th 07, 11:08 AM posted to rec.aviation.soaring
Andrzej
-----Wiadomo¶æ oryginalna-----
Od: Andrzej ]
Og³oszono: ¶roda 5 grudnia 2007 10:46
Og³oszone w: rec.aviation.soaring
Konwersacja: Shock! Hana's Diana 2 in service
Temat: Shock! Hana's Diana 2 in service
Diana 2 Hany Zejdovej przyp³ynê³a z Australii - SZOK !!! 4.12.2007 r
Hana's Zejdova Diana 2 just was delivered from Australia - shock!
Super orchidea o znakach VH-VHZ w firmie Bogumi³a Beresia w
Bielsku-Bia³ej.
Super orchidee at signs VH-VHZ in gliders service BB in Bielsko-Biala
Na zewn±trz po³o¿one oryginalne sworznie mocuj±ce p³ytê hamulcow± do
ramienia, wewn±trz ¶ruby które zamontowa³ w australijski mechanik !!!!
Wodoczna tulejka "nie zmie¶ci³a" siê równie¿ mechanikowi na sworzniu
napêdu hamulca, wiêc jej nie by³o - efekt pasowanie godne wozu
drabiniastego.
There are original pivots fastened plate of air brakes to the arm. You
can see screw inside the arm wchich was mounted by australian
mechanician. There isn't muff on the pivot of air brake drive -
mechanician just removed it.
Oryginalny sworzeñ w ramieniu hamulca aerodynamicznego zast±piono
¶rub±
z marketu, otwór siê "trochê rozlajerowa³", wiêc wci¶niêto tulejkê...
Original pivot of air brake's arm was replaced by screw from
supermarket. Hana's mechanisian just pressed muff inside because of gaps
was a liitle bit distroyed.
Stan koñcówki ramienia hamulca aerodynamicznego po technicznej
ingerencji mechanika w Australii....
End of air brake arm after technical intervention.
http://www.gorpol.pl/powiekszenie.php?id=2821\
Another picuture of Hana's and her mechanician work.
Os³ona napêdu klapolotki by³a wy³amywana, byæ mo¿e
z my¶l± obejrzenia rozwi±zania.
Broken aileron cover.
Ta¶ma mylarowa zosta³a zast±piona inn±, szersz±,
nie usuniêty klej zniekszta³ci³ zdecydowanie profil...
Mylar tape was removed and replaced by other, wider tape. Glue was not
removed so it deformed aerofoil.
Insecurited hinge of rudder.
No comments needed.
Andy
Old December 5th 07, 11:20 AM posted to rec.aviation.soaring
Ian
Thanks for the translations. Just one little thing - I think that's a
"bush" you're referring too. "Muff" can mean "bush", but in a rather,
erm, anatomical sense.
Ian
Old December 5th 07, 11:42 AM posted to rec.aviation.soaring
Andrzej
I'm sorry but my english is worse than your polish )
Andy
Old December 5th 07, 02:24 PM posted to rec.aviation.soaring
Udo
Andy
I would like to see the original parts before the so called
modification.
other the the bolts in your first picture.
Udo
Old December 5th 07, 05:00 PM posted to rec.aviation.soaring
Andrzej
modification.
I think producer show more pictures soon. Presented pictures are hot.
Andy
Old December 5th 07, 04:40 PM posted to rec.aviation.soaring
Ian
Impossible!
Ian
Old December 5th 07, 12:16 PM posted to rec.aviation.soaring
Maciek
Perhaps one comment is needed: this is all about the Diana 2 #3 about which
there were many many posts sent by Blue Cumulus to this group, telling about
its unprecise manufacture,horrible flight characteristics, self-deployment
of the flaps and non-symetric deployment of the airbrakes. Off course the
manufacturer was the one to blame for that. Now we all can find what was
really wrong with the glider.
Maciek K.
BTW: The manufacturer obliged himself to fix the glider for free (the owner
only shipped the plane pack to Europe) just to protect his reputation after
all theese lies told about his gliders.
Old December 5th 07, 01:15 PM posted to rec.aviation.soaring
Dan G
Who is this Hana person, and why did she and her "mechanic" (perhaps a
better term would be "moron") feel the need to start fiddling around
with the glider?
Dan
PS I believe there's a Diana 2 entered into the upcoming Sailplane
Grand Prix - could be interesting...
Still in Shock Chuck Owning 19 May 28th 06 04:34 PM
Insurance renewal shock Maule Driver Owning 12 February 2nd 05 10:00 PM
Shock Chord Rings smjmitchell Home Built 1 September 9th 04 07:41 AM
Shock *Heating*? Jay Honeck Owning 48 February 25th 04 03:43 PM
What a shock!!! Lockheed is over budget on the F-35 Mitch Benjamin Military Aviation 37 January 16th 04 08:50 AM
