What/how does compression ratio affect an engine?
Old December 10th 07, 11:25 AM posted to rec.aviation.homebuilt
Default What/how does compression ratio affect an engine?
Hi,
So I was fantasizing the other day (as I do quite a bit) about my
latest dream-plane-to-build: an RV-9A. (Note that this is fantasy in
the extreme as I'm not a pilot yet AND I have no money!)
I was thinking of how to power this plane. A Jet-A burning diesel
would be great but that's another story. I spotted an ad for
Superior's XP-series engines in Kitplanes. The website has a great
"build your own engine" feature where you get to change all the bits
and customize the engine.
One of the things you have to choose is compression ratio: 7:1
(150hp), 8.5:1 (160hp), or 9:1 (165hp).
Going for the 7:1 option (from the default 8.5:1) adds $100 to the
price! I'm assuming this is a supply/demand issue.
So my question (finally) is: what is the effect of a higher or lower
compression ratio? I believe TBO for all three engines is still 2000
hours.
- Is there a difference in wear?
- Would maximum power be produced at the same RPM for all three
engines? In other words is there a relationship like (power) =
(compression ratio) x (RPM) such that these engines all operate at the
same RPM? In which case wear would be the same...(?)
For the RV-9A 150hp would be fine. I guess I'm trying to understand
what benefit is to be had by spending the extra $100 to go for the
lower compression pistons. All in my fantasy
Michael
Old December 10th 07, 11:46 AM posted to rec.aviation.homebuilt
Scott[_1_]
Well, one thing I know, is that with the lower compression ratio (ie 7:1
for the 150HP) is that the engine can run on auto fuel. That's why I'm
planning on a 150 HP in my RV-4. The higher compression engines take 100LL.
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Hi,
hours.
Michael
Old December 10th 07, 11:55 AM posted to rec.aviation.homebuilt
Kyle Boatright
Hi,
hours.
Michael
The extra $100 is probably because the 7:1 pistons are a special order item,
as opposed to the 8.5:1 pistons which are the standard.
Max RPM is the same for all 3 engines, and the only wear difference should
be on the connecting rods. Apparently the difference isn't enough to change
the TBO, which is a theoretical figure anyway.
As to autogas vs 100LL, plenty of people running 8.5:1 compression engines
are running autofuel. A bigger issue with autofuel (at least in engines
with a compression rapto of 8.5:1 or less) is vapor lock, rather than
detonation.
Kyle Boatright
160hp (8.5:1 Lycoming) RV-6
Old December 11th 07, 01:25 AM posted to rec.aviation.homebuilt
Matt Whiting
Connecting rods don't wear. Their bearings wear, but the con-rods don't
wear. I doubt the slight difference in force on the connecting rod and
crank bearings is enough to cause a measurable difference in wear.
Matt
Old December 11th 07, 01:51 AM posted to rec.aviation.homebuilt
Kyle Boatright
"Matt Whiting" wrote in message
should be on the connecting rods. Apparently the difference isn't enough
to change the TBO, which is a theoretical figure anyway.
You're correct. My post was hastily composed and clearly didn't pass peer
review. ;-).
KB
Matt
Old December 11th 07, 01:57 AM posted to rec.aviation.homebuilt
Blueskies
"Matt Whiting" wrote in message ...
Connecting rods don't wear. Their bearings wear, but the con-rods don't wear. I doubt the slight difference in force
on the connecting rod and crank bearings is enough to cause a measurable difference in wear.
Matt
They do experience fatigue cycles. Is that wear?
Old December 11th 07, 02:28 AM posted to rec.aviation.homebuilt
Matt Whiting
Matt
Maybe, maybe not. If the stress in steel remains below a certain
threshold, the fatigue life is essentially infinite. I've never heard
of a life limited con-rod so I suspect the stress levels are
sufficiently low that fatigue isn't an issue. In any event, no, I don't
think fatigue is considered to be wear by the standard definition.
Fatigue is a mode of deterioration, as is rust, but I don't think either
is considered to be wear per se.
Matt
Old December 12th 07, 01:56 AM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On Tue, 11 Dec 2007 01:57:26 GMT, "Blueskies"
Matt
Fatique cycles in a properly designed rod are almost immaterial. There
is virtually NO bending motion, In compression steel is almost totally
unaffected, and the rods are generally designed to take the tension
loading from high RPM - which is not directly affected by higher
compression. High compression engines that are run at extreme speeds
DO need to worry about fatigue cycles. "tractor engines" as a rule
have no such worries. (unless you are talking "pulling tractors")
Posted via a free Usenet account from http://www.teranews.com
Old December 10th 07, 12:47 PM posted to rec.aviation.homebuilt
OK, not cool to reply to my own post, I know. But I just found this
great resource which basically answers all my questions:
http://www.lycoming.textron.com/supp.../key-reprints/
"Lycoming provides helpful information in various publications,
including Lycoming Flyer Key Reprints. Lycoming's Key
Reprints is our effort to continually share our best practices,
key lessons and engines systems knowledge to empower
our customers."
Lower compression = lower chance of preignition = lower octane
required (ie. auto fuel)!
Yes, that would make a difference to the pocket book!
The issue of using auto fuel is addressed in this series also:
"Auto fuel is now being used as a substitute for Grade 80
aviation gasoline under STCs issued by the FAA. Most
major oil companies and engine manufacturers continue
to recommend that aircraft piston engines be operated
only on aviation gasoline. Deterioration of engine and fuel
system parts have been reported in aircraft using auto
fuel. Operators should consider the added risk of using
auto fuel in aircraft. Remember -- a pilot can't pull over
to the side of the road when fuel creates a problem with
the engine."
Old December 10th 07, 01:31 PM posted to rec.aviation.homebuilt
Scott[_1_]
One thing I think "might" be a concern is that burning 100LL (can't get
80 octane avgas these days) in an engine built for 80 octane is the
extra heat. I think valves are most likely to be affected by burning
the 100LL instead of 80. Might be all wet on this, but that's what I've
heard and I'm NOT an engine mechanic...just a user You might try
digging in the Lycoming site and see what they say about 80 vs 100LL...
Scott
our customers."
the engine."
Scott
Wing Tape - Does Thickness Affect Performance? ContestID67 Soaring 87 February 1st 07 03:24 PM
Wing Tape - Does Thickness Affect Performance? Charles McLaurin Soaring 2 January 30th 07 06:00 PM
Recent Political Change May Positively Affect GA Larry Dighera Piloting 98 November 13th 06 01:59 AM
How does spar protrusion affect performance Chris Davison Soaring 19 July 13th 04 12:38 AM
Does WiFi affect your choice of FBO? [email protected] General Aviation 8 October 16th 03 07:22 PM
